YOLO-World-V2
此文档讲解如何在安装了瑞莎智核 AX-M1 的 host 设备上运行 YOLO-World-V2 示例应用。
创建虚拟环境​
Host
下载示例应用仓库​
Host
hf download AXERA-TECH/YOLO-World-V2 --local-dir ./YOLO-World-V2
cd YOLO-World-V2
示例使用​
安装 python 依赖​
Host
pip install -r pyyoloworld/requirements.txt
模型推理​
Host
cp install/lib/axcl_aarch64/libyoloworld.so ./pyyoloworld/
cd pyyoloworld/
python gradio_example.py --yoloworld ../models/yolo_u16_ax650.axmodel --tenc ../models/clip_b1_u16_ax650.axmodel --vocab ../vocab.txt
(.venv) rock@rock-5b-plus:~/ssd/axera/YOLO-World-V2/pyyoloworld$ python gradio_example.py --yoloworld ../models/yolo_u16_ax650.axmodel --tenc ../models/clip_b1_u16_ax650.axmodel --vocab ../vocab.txt
Trying to load: /home/radxa/AXERA-TECH/YOLO-World-V2/pyyoloworld/aarch64/libyoloworld.so
❌ Failed to load: /home/radxa/AXERA-TECH/YOLO-World-V2/pyyoloworld/aarch64/libyoloworld.so
/home/radxa/AXERA-TECH/YOLO-World-V2/pyyoloworld/aarch64/libyoloworld.so: cannot open shared object file: No such file or directory
🔍 File not found. Please verify that libclip.so exists and the path is correct.
Trying to load: /home/radxa/AXERA-TECH/YOLO-World-V2/pyyoloworld/libyoloworld.so
open libax_sys.so failed
open libax_engine.so failed
✅ Successfully loaded: /home/radxa/AXERA-TECH/YOLO-World-V2/pyyoloworld/libyoloworld.so
可用设备: {'host': {'available': False, 'version': '', 'mem_info': {'remain': 0, 'total': 0}}, 'devices': {'host_version': 'V3.6.4_20250819020149', 'dev_version': 'V3.6.4_nt': 1, 'devices_info': [{'temp': 45, 'cpu_usage': 2, 'npu_usage': 0, 'mem_info': {'remain': 7022, 'total': 7040}}]}}
axcl device available, use device-0
[I][ run][ 31]: AXCLWorker start with devid 0
input size: 2
name: images [unknown] [unknown]
1 x 640 x 640 x 3 size: 1228800
name: txt_feats [unknown] [unknown]
1 x 4 x 512 size: 8192
output size: 3
1 x 80 x 80 x 68 size: 1740800
1 x 40 x 40 x 68 size: 435200
1 x 20 x 20 x 68 size: 108800
[I][ yw_create][ 408]: num_classes: 4, num_features: 512, input w: 640, h: 640
is_output_nhwc: 1
input size: 1
name: text_token [unknown] [unknown]
1 x 77 size: 308
output size: 1
1 x 1 x 512 size: 2048
[I][ load_text_encoder][ 44]: text feature len 512
[I][ load_tokenizer][ 60]: text token len 77
* Running on local URL: http://192.168.1.100:7860
* Running on local URL: http://0.0.0.0:7860
* To create a public link, set `share=True` in `launch()`.
yolo_world_v2 demo output
如果您的主板 IP Address 是 192.168.1.100, 那么使用浏览器访问以下链接 http://192.168.1.100:7860.
