快速验证
当用户根据 环境安装 安装完 AXCL 驱动后,用户可以使用根据此文档使用瑞莎智核 AX-M1 快速进行模型推理和 Benchmark。
axcl-smi 工具详细使用,请参考 AXCL-SMI 工具使用
推理测试
这里简单的使用瑞莎智核 AX-M1 进行 YOLOv8 推理验证,详细代码请参考 ax_yolov8_steps.cc
Host
pip3 install -U "huggingface_hub[cli]"
huggingface-cli download AXERA-TECH/YOLOv8 --local-dir ./YOLOv8
Host
cd YOLOv8
./axcl_yolov8 --model ./ax650/yolov8s.axmodel --image ./football.jpg
(.venv) rock@rock-5b-plus:~/ssd/axera/YOLOv8$ ./axcl_yolov8 --model ./ax650/yolov8s.axmodel --image ./football.jpg
model file : ./ax650/yolov8s.axmodel
image file : ./football.jpg
img_h, img_w : 640 640
axclrtEngineCreateContextt is done.
axclrtEngineGetIOInfo is done.
grpid: 0
input size: 1
1 x 640 x 640 x 3
output size: 3
1 x 80 x 80 x 144
1 x 40 x 40 x 144
1 x 20 x 20 x 144
Engine push input is done.
post process cost time:5.02 ms
Repeat 1 times, avg time 4.54 ms, max_time 4.54 ms, min_time 4.54 ms
detection num: 7
0: 93%, [ 757, 215, 1131, 1156], person
0: 93%, [ 0, 354, 311, 1104], person
0: 93%, [1351, 342, 1627, 1032], person
0: 91%, [ 488, 478, 661, 998], person
32: 87%, [ 773, 889, 829, 939], sports ball
32: 77%, [1231, 876, 1280, 922], sports ball
0: 60%, [1840, 690, 1906, 809], person
yolov8 demo output
模型 Benchmark
axcl_run_model 工具可以直接推理任何编译好的 axmodel, 使用方法请参考以下说明。
Host
axcl_run_model --help
rock@rock-5b-plus:~$ axcl_run_model --help
usage: axcl_run_model --model=string [options] ...
options:
-m, --model path to a model file (string)
-r, --repeat repeat times running a model (int [=1])
-w, --warmup repeat times before running a model to warming up (int [=1])
-s, --sleep sleep millisecond after running a model once (int [=0])
-v, --vnpu type of Visual-NPU inited {0=Disable, 1=STD, 2=BigLittle, 3=LittleBig} (int [=0])
-a, --affinity npu affinity when running a model (int [=7])
-p, --parallel parallel run model using all affinity npu cores (int [=0])
-b, --batch the batch will running (int [=0])
-g, --group the selected group of shapes (int [=0])
-i, --input-folder the folder of each inputs (folders) located (string [=])
-o, --output-folder the folder of each outputs (folders) will saved in (string [=])
-l, --list the list of inputs which will test (string [=])
-c, --config axcl config file "axcl.json" path (string [=/usr/local/axcl/axcl.json])
-d, --device axcl device index (int [=0])
-x, --api api, 0="axcl runtime", 1="axcl native" (int [=0])
--verify verify outputs after running model
-?, --help print this message
下载预编译模型
以测试一个模型的运行速度为例,在 AXERA Huggingface 上下载预编译好的 yolov8 axmodel 模型。
Host
wget https://huggingface.co/AXERA-TECH/YOLOv8/resolve/main/ax650/yolov8s.axmodel
对模型进行 Benchmark
使用 axcl_run_model 工具对指定模型进行指定数量的循环推理,即可得出模型的推理时间。
Host
axcl_run_model --model yolov8s.axmodel -r 100
rock@rock-5b-plus:~$ axcl_run_model --model yolov8s.axmodel -r 100
Run AxModel:
model: yolov8s.axmodel
type: 3 Core
vnpu: Disable
warmup: 1
repeat: 100
batch: { auto: 1 }
axclrt ver: 1.0.0
pulsar2 ver: 3.2-patch1 34eb86c7
tool ver: 0.0.1
cmm size: 11821670 Bytes
min = 4.222 ms max = 4.787 ms avg = 4.562 ms median = 4.547 ms
5% = 4.379 ms 90% = 4.698 ms 95% = 4.726 ms 99% = 4.787 ms
