YOLOv8-Seg
此文档讲解如何在安装了瑞莎智核 AX-M1 的 host 设备上运行 YOLOv8-seg 示例应用。
可执行程序的编译方法请参考 AXCL-Samples 编译示例。Python 推理依赖 PyAXEngine。
预编译模型量化方式:w8a16
创建虚拟环境​
Host
下载示例应用仓库​
只下载 AX-M1 需要的三核模型和推理脚本:
Host
hf download AXERA-TECH/YOLOv8-Seg \
AX650/yolov8s-seg_640x640_npu3.axmodel \
ax_infer.py \
bus.jpg \
--local-dir ./YOLOv8-Seg
cd YOLOv8-Seg
示例使用​
安装 Python 依赖​
Host
模型推理​
瑞莎智核 AX-M1 是 M.2 算力卡,需要指定 AXCLRTExecutionProvider。
Host
python3 ax_infer.py --model-path AX650/yolov8s-seg_640x640_npu3.axmodel --test-img bus.jpg --providers AXCLRTExecutionProvider
[YOLOv8-Seg] [10:51:49.774] [DEBUG] Load model time = 635.89 ms
[YOLOv8-Seg] [10:51:49.801] [DEBUG] Pre-process time = 5.27 ms
[YOLOv8-Seg] [10:51:49.840] [DEBUG] Forward time = 38.11 ms
[YOLOv8-Seg] [10:51:49.846] [DEBUG] Post-process time = 5.90 ms
[YOLOv8-Seg] [10:51:49.847] [DEBUG] Proto shape: (32, 160, 160)
[YOLOv8-Seg] [10:51:49.883] [INFO] Draw Results (5 objects):
[YOLOv8-Seg] [10:51:49.883] [INFO] (51, 398, 243, 903) -> person: 0.89
[YOLOv8-Seg] [10:51:49.922] [INFO] (221, 407, 345, 860) -> person: 0.88
[YOLOv8-Seg] [10:51:49.931] [INFO] (669, 393, 809, 879) -> person: 0.88
[YOLOv8-Seg] [10:51:49.937] [INFO] (24, 228, 799, 751) -> bus: 0.86
[YOLOv8-Seg] [10:51:49.953] [INFO] (0, 545, 76, 874) -> person: 0.74
[YOLOv8-Seg] [10:51:49.969] [INFO] Saved to result_yolov8_seg.jpg
[INFO] SOC Name: AX650N
[INFO] Compiler version: 6.0-dirty a498e20d-dirty
yolov8-seg demo output
