Conda 使用
主要介绍一些常用的 Conda 命令。
查看帮助
打开终端,使用 conda --help
命令查看 Conda 所有命令的使用方法。
conda --help
终端会输出类似如下的信息:
usage: conda [-h] [-v] [--no-plugins] [-V] COMMAND ...
conda is a tool for managing and deploying applications, environments and packages.
options:
-h, --help Show this help message and exit.
-v, --verbose Can be used multiple times. Once for detailed output, twice for INFO logging, thrice for DEBUG logging, four times for TRACE
logging.
--no-plugins Disable all plugins that are not built into conda.
-V, --version Show the conda version number and exit.
commands:
The following built-in and plugins subcommands are available.
COMMAND
activate Activate a conda environment.
build Build conda packages from a conda recipe.
clean Remove unused packages and caches.
commands List all available conda subcommands (including those from plugins). Generally only used by tab-completion.
compare Compare packages between conda environments.
config Modify configuration values in .condarc.
content-trust Signing and verification tools for Conda
convert Convert pure Python packages to other platforms (a.k.a., subdirs).
create Create a new conda environment from a list of specified packages.
deactivate Deactivate the current active conda environment.
debug Debug the build or test phases of conda recipes.
develop Install a Python package in 'development mode'. Similar to `pip install --editable`.
doctor Display a health report for your environment.
env Create and manage conda environments.
export Export a given environment
index Update package index metadata files.
info Display information about current conda install.
init Initialize conda for shell interaction.
inspect Tools for inspecting conda packages.
install Install a list of packages into a specified conda environment.
list List installed packages in a conda environment.
metapackage Specialty tool for generating conda metapackage.
notices Retrieve latest channel notifications.
pack See `conda pack --help`.
package Create low-level conda packages. (EXPERIMENTAL)
remove (uninstall) Remove a list of packages from a specified conda environment.
rename Rename an existing environment.
render Expand a conda recipe into a platform-specific recipe.
repo See `conda repo --help`.
repoquery Advanced search for repodata.
run Run an executable in a conda environment.
search Search for packages and display associated information using the MatchSpec format.
server See `conda server --help`.
skeleton Generate boilerplate conda recipes.
token See `conda token --help`.
tos A subcommand for viewing, accepting, rejecting, and otherwise interacting with a channel's Terms of Service (ToS). This plugin
periodically checks for updated Terms of Service for the active/selected channels. Channels with a Terms of Service will need to
be accepted or rejected prior to use. Conda will only allow package installation from channels without a Terms of Service or with
an accepted Terms of Service. Attempting to use a channel with a rejected Terms of Service will result in an error.
update (upgrade) Update conda packages to the latest compatible version.
查看版本信息
打开终端,使用 conda --version
命令查看 Conda 版本。
conda --version
终端会输出类似如下的信息:
conda 24.9.2
查看当前环境
打开终端,使用 conda info
命令查看当前环境信息。
conda info
终端会输出类似如下的信息:
active environment : base
active env location : /home/radxa/anaconda3
shell level : 1
user config file : /home/radxa/.condarc
populated config files : /home/radxa/anaconda3/.condarc
conda version : 25.5.1
conda-build version : 25.5.0
python version : 3.13.5.final.0
solver : libmamba (default)
virtual packages : **archspec=1=aarch64
**conda=25.5.1=0
**glibc=2.36=0
**linux=5.15.147=0
\_\_unix=0=0
base environment : /home/radxa/anaconda3 (writable)
conda av data dir : /home/radxa/anaconda3/etc/conda
conda av metadata url : None
channel URLs : https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/main/linux-aarch64
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/main/noarch
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/r/linux-aarch64
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/r/noarch
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/msys2/linux-aarch64
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/msys2/noarch
package cache : /home/radxa/anaconda3/pkgs
/home/radxa/.conda/pkgs
envs directories : /home/radxa/anaconda3/envs
/home/radxa/.conda/envs
platform : linux-aarch64
user-agent : conda/25.5.1 requests/2.32.3 CPython/3.13.5 Linux/5.15.147 debian/11.11 glibc/2.36 solver/libmamba conda-libmamba-solver/25.4.0 libmambapy/2.0.5 aau/0.7.1 c/. s/. e/.
UID:GID : 1001:1001
netrc file : None
offline mode : False
查看所有环境
打开终端,使用 conda env list
命令查看所有环境。
conda env list
终端会输出类似如下的信息:表示当前系统只有 base 环境。
# conda environments:
base \* /home/radxa/anaconda3
创建环境
创建新环境
conda create --name <env_name>
# 示例:创建一个名为 my_env 的环境
conda create --name my_env
创建环境后,终端会输出类似如下的信息:创建过程中需要确认是否继续。
Channels:
- defaults
Platform: linux-aarch64
Collecting package metadata (repodata.json): done
Solving environment: done
## Package Plan
environment location: /home/radxa/anaconda3/envs/my_env
Proceed ([y]/n)? y
Downloading and Extracting Packages:
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
# To activate this environment, use
# $ conda activate my_env
# To deactivate an active environment, use
# $ conda deactivate
创建指定 Python 版本的环境
conda create --name <env_name> python=<python_version>
# 示例:创建一个名为 my_env_py39 的 Python 3.9 环境
conda create --name my_env_py39 python=3.9
创建环境后,终端会输出类似如下的信息:创建过程中需要输入 y
确认是否继续操作。
Channels:
- defaults
## Package Plan
environment location: /home/radxa/anaconda3/envs/my_env_py39
added / updated specs: - python=3.9
The following packages will be downloaded:
package | build
_libgcc_mutex-0.1 | main 2 KB defaults
_openmp_mutex-5.1 | 51_gnu 1.4 MB defaults
bzip2-1.0.8 | h998d150_6 210 KB defaults
ca-certificates-2025.2.25 | hd43f75c_0 129 KB defaults
expat-2.7.1 | h419075a_0 161 KB defaults
libffi-3.4.4 | h419075a_1 140 KB defaults
libgcc-ng-11.2.0 | h1234567_1 1.3 MB defaults
libgomp-11.2.0 | h1234567_1 466 KB defaults
libstdcxx-ng-11.2.0 | h1234567_1 779 KB defaults
libxcb-1.17.0 | hf66535e_0 433 KB defaults
ncurses-6.4 | h419075a_0 1.1 MB defaults
openssl-3.0.16 | h998d150_0 5.2 MB defaults
pip-25.1 | pyhc872135_2 1.3 MB defaults
pthread-stubs-0.3 | hfd63f10_1 7 KB defaults
python-3.9.23 | h89e7a61_0 24.2 MB defaults
readline-8.2 | h998d150_0 381 KB defaults
setuptools-78.1.1 | py39hd43f75c_0 1.6 MB defaults
sqlite-3.45.3 | h998d150_0 1.5 MB defaults
tk-8.6.14 | hb5ae6a8_1 3.5 MB defaults
tzdata-2025b | h04d1e81_0 116 KB defaults
wheel-0.45.1 | py39hd43f75c_0 114 KB defaults
xorg-libx11-1.8.12 | hf66535e_1 928 KB defaults
xorg-libxau-1.0.12 | hf66535e_0 14 KB defaults
xorg-libxdmcp-1.1.5 | hf66535e_0 19 KB defaults
xorg-xorgproto-2024.1 | h998d150_1 582 KB defaults
xz-5.6.4 | h998d150_1 573 KB defaults
zlib-1.2.13 | h998d150_1 113 KB defaults
Total: 47.1 MB
The following NEW packages will be INSTALLED:
\_libgcc_mutex anaconda/pkgs/main/linux-aarch64::\_libgcc_mutex-0.1-main
\_openmp_mutex anaconda/pkgs/main/linux-aarch64::\_openmp_mutex-5.1-51_gnu
bzip2 anaconda/pkgs/main/linux-aarch64::bzip2-1.0.8-h998d150_6
ca-certificates anaconda/pkgs/main/linux-aarch64::ca-certificates-2025.2.25-hd43f75c_0
expat anaconda/pkgs/main/linux-aarch64::expat-2.7.1-h419075a_0
libgcc-ng anaconda/pkgs/main/linux-aarch64::libgcc-ng-11.2.0-h1234567_1
libgomp anaconda/pkgs/main/linux-aarch64::libgomp-11.2.0-h1234567_1
libstdcxx-ng anaconda/pkgs/main/linux-aarch64::libstdcxx-ng-11.2.0-h1234567_1
libxcb anaconda/pkgs/main/linux-aarch64::libxcb-1.17.0-hf66535e_0
ncurses anaconda/pkgs/main/linux-aarch64::ncurses-6.4-h419075a_0
openssl anaconda/pkgs/main/linux-aarch64::openssl-3.0.16-h998d150_0
pip anaconda/pkgs/main/noarch::pip-25.1-pyhc872135_2
pthread-stubs anaconda/pkgs/main/linux-aarch64::pthread-stubs-0.3-hfd63f10_1
python anaconda/pkgs/main/linux-aarch64::python-3.9.23-h89e7a61_0
readline anaconda/pkgs/main/linux-aarch64::readline-8.2-h998d150_0
setuptools anaconda/pkgs/main/linux-aarch64::setuptools-78.1.1-py39hd43f75c_0
sqlite anaconda/pkgs/main/linux-aarch64::sqlite-3.45.3-h998d150_0
tk anaconda/pkgs/main/linux-aarch64::tk-8.6.14-hb5ae6a8_1
tzdata anaconda/pkgs/main/noarch::tzdata-2025b-h04d1e81_0
wheel anaconda/pkgs/main/linux-aarch64::wheel-0.45.1-py39hd43f75c_0
xorg-libx11 anaconda/pkgs/main/linux-aarch64::xorg-libx11-1.8.12-hf66535e_1
xorg-libxau anaconda/pkgs/main/linux-aarch64::xorg-libxau-1.0.12-hf66535e_0
xorg-libxdmcp anaconda/pkgs/main/linux-aarch64::xorg-libxdmcp-1.1.5-hf66535e_0
xorg-xorgproto anaconda/pkgs/main/linux-aarch64::xorg-xorgproto-2024.1-h998d150_1
xz anaconda/pkgs/main/linux-aarch64::xz-5.6.4-h998d150_1
zlib anaconda/pkgs/main/linux-aarch64::zlib-1.2.13-h998d150_1
Proceed ([y]/n)? y
# $ conda activate my_env_py39
激活环境
conda activate <env_name>
# 示例:激活 my_env_py39 环境
激活环境后,终端用户名前会提示当前的 conda 环境名称。
退出环境
conda deactivate
删除环境
conda remove --name <env_name> --all
# 示例:删除 my_env_py39 环境
conda remove --name my_env_py39 --all
删除环境后,终端会输出类似如下的信息:中间需要您输入 y
确认删除操作。
Remove all packages in environment /home/radxa/anaconda3/envs/my_env_py39:
## Package Plan
The following packages will be REMOVED:
libffi-3.4.4-h419075a_1
xz-5.6.4-h998d150_1
Proceed ([y]/n)? y
Everything found within the environment (/home/radxa/anaconda3/envs/my_env_py39), including any conda environment configurations and any non-conda files, will be deleted. Do you wish to continue?
(y/[n])? y
