Radxa Heatsink 5540A
Product Overview​
The Radxa Heatsink 5540A is a passive heatsink designed for Radxa CM3 and CM5.
Version Notes
The Radxa Heatsink 5540A has two versions: the older version is silver, and the newer version is black.
Specifications​
  • Material: Aluminum alloy
  • Dimensions: 55 x 40 x 10 mm
  • Compatible with:
    • Radxa CM3
    • Radxa CM5
Installation Guide​
This section uses Radxa CM3 as an example to demonstrate how to install the 5540A heatsink.
Package Contents​
  • 1x Heatsink
  • 1x Thermal pad
  • 4x CM2 x 4 mm screws
Install the Antenna (Optional)​
If you are using an external antenna, install it on the CM3 before installing the heatsink.
Apply the Thermal Pad​
Place the thermal pad on the SoC of the CM3.
Secure the Heatsink​
Use 4 CM2 x 4 mm screws to fasten the heatsink from the bottom side through the CM3 mounting holes.
Mount the Assembly to the CM3 IO Board​
Install the CM3 with the heatsink attached onto the CM3 IO board.
