Radxa Heatsink 6240B
Product Introduction​
The Radxa Heatsink 6240B is specifically designed for the Radxa ROCK 5B / 5B+ / 5T series.
Product Specifications​
Material: Aluminum
Dimensions: 62 mm * 40 mm * 9 mm
Speed: 7000 RPM ± 10%
Interface: 2-Pin 1.25mm pitch connector
Operating Voltage: 5V DC
Compatible with: Radxa ROCK 5B / 5B+ / 5T boards
Installation Guide​
Package Contents​
① : Heatsink
② : 2x Thermal pad (22 mm * 22 mm * 0.8 mm)
③ : 1x Thermal pad (40 mm * 40 mm * 1.0 mm)
Installing Thermal Pads​
Apply the 22 mm * 22 mm * 0.8 mm and 40 mm * 40 mm * 1.0 mm thermal pads onto the board's SoC and surrounding areas.
Installation Tip
Make sure the thermal pads do not cover the mounting holes for the heatsink on the board!
Installing the Heatsink​
Place the heatsink onto the board, ensuring the round-headed pegs align with the mounting holes. Gently press down on the pegs to secure the heatsink in place.
Compatible with the fixed holes on the board
NumberBoard Model
①ROCK 5B
②ROCK 5B+
③ROCK 5T
④ROCK 5T (Industrial Version)
Connecting the Fan​
Connect the heatsink's fan connector to the board's fan connector.
