Radxa Heatsink 6530B
Product Introduction​
The Radxa Heatsink 6530B is an aluminum active heatsink designed to provide more stable cooling performance for the board.
  • High-efficiency cooling design
    • Aluminum alloy with excellent thermal conductivity
    • 3D fin structure to effectively increase the heat dissipation area
  • Smart PWM speed control
    • Adjusts fan speed in real time
    • Improves airflow efficiency and balances cooling performance with operating noise
Specifications​
  • Material: Aluminum alloy
  • Dimensions: 65 × 30 × 11.5 mm
  • Compatible with:
    • Radxa Cubie A7Z
Installation Guide​
This guide uses Radxa Cubie A7Z as an example for installing the 6530B heatsink.
Notes​
  • Power off the device before installation, and avoid plugging/unplugging the fan connector while the board is powered.
  • Tighten the screws gradually in a diagonal pattern to avoid uneven pressure that can cause poor contact with the SoC.
  • If the thermal pad has protective films, remove the films on both sides before applying the pad.
  • Tighten the screws until they are secure. Avoid overtightening to prevent stripped threads or board damage.
Package Contents​
  • 1× Heatsink
  • 2× Thermal pads
  • 4× Screws (CM2 × 4 × 4 mm)
Note: One of the thermal pads is a spare and can be used as needed.
Place the Thermal Pad​
Align the thermal pad to the SoC coverage area and apply it flat onto the SoC.
Place the Heatsink​
Align the heatsink with the mounting holes and place it onto the board, ensuring the heatsink base fully contacts the thermal pad.
Secure the Heatsink​
Secure the heatsink to the board using the four screws. It is recommended to tighten them gradually in a diagonal pattern to ensure even pressure.
Connect the Fan​
Connect the fan cable to the board's fan header, and make sure the connector orientation is correct and firmly seated.
