Using with ROCK 5T
This guide provides installation instructions for the ROCK 5T with the Radxa Metal Case 1290.
Installation Guide​
Package List​
① : 1x Top Cover
② : 1x Bottom Cover
③ : 2x Rubber Antennas
④ : 5x Snap-in Plugs
⑤ : 4x CM2.5 * 6 mm Standoffs
⑥ : 4x CM2.5 * 4 mm Screws
⑦ : 9x KM2.5 * 4 mm Screws
⑧ : 2x Thermal Pads
⑨ : 1x Silicone Feet (contains 4 individual feet)
Step 1: Install Thermal Pads​
If using an M.2 NVMe SSD, apply the thermal pad to the surface of the SSD to enhance heat conduction and dissipation.
Step 2: Install Motherboard Standoffs​
Use 4 CM2.5 * 6 mm brass standoffs and 4 CM2.5 * 4 mm screws to secure the motherboard standoffs to the bottom cover.
Step 3: Install the Motherboard​
Gently place the motherboard onto the standoffs on the bottom cover and secure it using 4 KM2.5 * 4 mm screws.
Step 4: Secure the Antenna Mounts​
Install the antenna mounts into the antenna slots on the top cover.
Installation Note
You can choose which antenna mount interfaces to use. For unused antenna interfaces, use the snap-in plugs to prevent dust from entering.
Step 5: Connect the Antennas​
Align the antenna connectors vertically with the WiFi/BT module interfaces on the motherboard and press down until you hear a "click" sound, indicating they are properly connected.
Step 6: Secure the Top Cover​
Align the top cover with the bottom cover and secure it using 5 KM2.5 * 4 mm screws.
Step 7: Install the Rubber Antennas​
Attach the rubber antennas to the antenna mounts.
Step 8: Install the Rubber Feet​
Attach the 4 rubber feet to the designated positions on the bottom cover (they can be installed on the motherboard's screw holes).
