Radxa Metal Case 7264
Introduction​
The Radxa Metal Case 7264 is an ultra-compact mini case specifically designed for the Cubie A5E single-board computer, providing a perfect fit for the Cubie A5E.
While ensuring durability and efficient heat dissipation, it also features an extremely compact design, lightweight portability, and meets industrial-grade thermal requirements, making it ideal for edge computing and other space-constrained applications.
Empower your Cubie A5E to achieve great things in small spaces!
Key Features​
  • Custom-fit for CUBIE A5E - Precise cutouts and structural design ensure perfect compatibility with all interfaces and expansion capabilities.
  • Extremely Compact Design - Case dimensions approximately 72.6 mm*63.4 mm*30 mm, lightweight and portable, about the size of a palm, perfect for deployment in tight spaces.
  • Industrial-grade Thermal Solution - All-metal body with 3D cooling fins, operates with zero fan noise.
  • PoE-ready (module not included) - Supports 802.3af/at standards, providing both power and network connectivity through a single cable.
  • Triple Wireless Expansion - Features 3 x SMA interfaces, supporting WiFi / Bluetooth / Cellular module expansion (additional expansion board required).
