Using with Cubie A5E
This guide explains how to install the Cubie A5E with Radxa Metal Case 7264.
Installation Guide
Parts List
  • ① : 1x Heatsink
  • ② : 1x Right side cover
  • ③ : 1x Left side cover
  • ④ : 1x Bottom cover
  • ⑤ : 1x Thermal pad
  • ⑥ : 1x Set of rod antennas
  • ⑦ : 3x Antenna hole plugs
  • ⑧ : 4x KM243.5 mm screws
  • ⑨ : 4x M2*16.6 mm standoffs
Step 1: Install Thermal Pad
  • Apply the thermal pad to the back of the mainboard at the SoC location
Step 2: Place the Mainboard
  • Align the heatsink so that its side cutouts match the board's ports (USB, HDMI, etc. should be exposed)
  • Gently place the mainboard onto the four raised positioning posts of the heatsink
Step 3: Install Antennas
  • Attach the antennas to the left side cover (do not install the antenna rods yet)
  • Use the antenna hole plugs to cover any unused antenna holes to prevent dust and debris from entering
Step 4: Secure the Right Side Cover
  • Align the antenna IPEX connectors vertically with the WiFi module interface on the mainboard and press down until you hear a "click"
  • Align the holes on the right side cover with the positioning holes on the heatsink
  • Use a flathead screwdriver to tighten 2x M2*16.6 mm standoffs to secure the right side cover
Step 5: Secure the Left Side Cover
  • Align the holes on the left side cover with the positioning holes on the heatsink
  • Use a flathead screwdriver to tighten 2x M2*16.6 mm standoffs to secure the left side cover
Step 6: Secure the Bottom Cover
  • Align the holes on the bottom cover with the standoffs
  • Use a cross-head screwdriver to tighten 4x KM243.5 mm screws in a diagonal sequence to secure the bottom cover
Step 7: Install Antenna Rods
  • Rotate the antenna rod nuts to secure them in place
