Radxa 23W PoE HAT
Radxa 23W PoE HAT
Radxa 23W PoE HAT is a HAT accessory designed for Raspberry Pi, Radxa ROCK 3 and 4 series, and Jetson Nano. The 23W PoE HAT allows you to power your Raspberry Pi, ROCK 3 and 4 series or Jetson Nano using Power over Ethernet–enabled networks; for this product to be used, the network it is connected to needs to have power-sourcing equipment installed.
Hardware Introduction​
Supported Products​
ModelSupported Products
F3Raspberry Pi 3B+, Raspberry Pi 4, ROCK Pi X, ROCK 3A, ROCK 3C, ROCK 4C+, Jetson Nano
F3LF3 with 40PIN GPIO pass-through exported
F4ROCK Pi 4A / 4B / 4A+ / 4B+ / 4SE
F4LF4 with 40PIN GPIO pass-through exported
The difference between F3 and F4 are: F3 and F4 use different GPIO for fan control. F4 uses ADC for temperature detection, while F3 uses DS18B20. F3 and F4 use different PoE pins. As the picture following: Difference between F3 and F4
The difference between Fx and FxL: FxL has the 40 pins GPIO pin-out, you can also use the 40 pins GPIO, but you can't while using Fx. As the picture following: Fx and FxL
Features​
  • 802.3at up to 23W(5V/4.6A)
  • PWM control FAN up to 12000RPM
  • Temperature sensor DS18B20
  • Optional 40PIN GPIO pass-through exported
  • Compatible with Radxa ROCK, Raspberry Pi 3B+ and Raspberry Pi 4
  • Clean design by hiding the fan and the big transformer inside
  • EEPROM for HAT identity and driver probe
Hardware Information​
PoE HAT for Raspberry Pi 3B+/4/Jetson Nano ROCK 3A 3C and 4C+.
DescriptionFunctionPin#Pin#FunctionDescription
12
34
56
get data from DS18B20BCM478
910
1112
1314
enable/disable fan motor driver chipBCM221516
1718
1920
2122
2324
2526ADC_IN0Get ADC value to get the temperature value
connect to EEPROM SDA pinI2C0_SDA2728I2C0_SCLconnect to EEPROM SCL pin
2930
3132
control fan speedPWM13334
3536
3738
3940
2D file​
You can download the 2D file(.dwg format) on Radxa 23W PoE HAT 2D file
