Radxa 25W PoE+ HAT for X4
The Radxa 25W PoE+ HAT for X4 is specifically designed for Radxa X4, providing Power over Ethernet (PoE+) functionality that enables both data communication and power transmission through a single network cable.
info
Requires the use of a compatible Power over Ethernet device.
25W PoE for X4
Compatibility​
Radxa 25W PoE+ HAT for X4 is designed for the following products:
  • Radxa X4
  • Radxa Dragon Q6A
Features​
  • Compliant with IEEE 802.3at standards
  • Wide input voltage range: 37V ~ 57V
  • Output: 5V/4.8A, 12V/2.1A
    • When only a 5V load is connected, the PoE output is up to 5V DC / 4.8A
    • When only a 12V load is connected, the PoE output is up to 12V DC / 2.1A
  • Features a programmable temperature sensor
  • Equipped with a customizable Cooling Fan delivering 1.45CFM for processor cooling
    • Size: 20 x 20 mm
    • Speed: 15000 ± 15%RPM
  • 12V DC Output
    • 1x 2-Pin 3.5mm Plug-in PCB Terminal Block
  • Operating Temperature Range: 0°C to +50°C
Interface​
  • ①: 12V DC Output
  • ②: PoE Header
  • ③: 40-Pin GPIO Header
25W PoE for X4 pinout
Usage​
The package list of Radxa 25W PoE+ HAT for X4 is as follows:
  • Radxa 25W PoE+ HAT for X4
  • 4x M2.5x9+6 Copper Pillars
  • 4x M2.5x4+6 Copper Pillars
  • 4x M2.5x5 Copper Pillars
If you want to use it together with Radxa Heatsink for X4, then you only need to replace the M2.5x9 + 6 copper pillar with the M2.5x9 + 3 copper pillar.
Installation Steps​
  1. Pass four M2.5x9+6 Copper Pillars or M2.5x9+3 Copper Pillars (if using heatsink) through the four positioning holes of the SBC, and secure them from the bottom.
  2. Align the Radxa 25W PoE+ HAT for X4 with the PoE interface and the 40-Pin interface, ensuring the 12V power interface is aligned, and insert it carefully, ensuring that it passes through the four Copper Pillars.
  3. On top of the Radxa 25W PoE+ HAT for X4, use M2.5x4+6 Copper Pillars or M2.5x5 Copper Pillars to secure it in place.
  4. Connect an Ethernet cable to the PoE interface, ensuring the other end is connected to a PoE+ compatible switch.
25W PoE x4
Downloads​
Product Information​
