InternVL2_5-1B
This document explains how to run the InternVL2_5-1B sample application on a host device equipped with the Radxa AICore AX-M1.
Precompiled model quantization format: w8a16.
Create a virtual environment​
Host
Download the demo repository​
Host
hf download AXERA-TECH/InternVL2_5-1B --local-dir ./InternVL2_5-1B
cd InternVL2_5-1B
Example usage​
Install Python dependencies​
Host
pip3 install transformers==4.53.3 jinja2==3.1.6
Start the Tokenizer service​
Host
python3 internvl2_5_tokenizer_448.py --port 12345 > /dev/null 2>&1 &
warning
To stop the background Tokenizer service, use jobs to view the background job number, then use kill %N to terminate the background process, where %N is the corresponding job number.
(.venv) rock@rock-5b-plus:~/ssd/axera/InternVL2_5-1B$ python3 internvl2_5_tokenizer_448.py --port 12345
None None 151645 <|im_end|>
[151644, 8948, 198, 56568, 104625, 100633, 104455, 104800, 101101, 32022, 102022, 99602, 100013, 9370, 90286, 21287, 42140, 53772, 35243, 26288, 104949, 3837, 105205, 109641, 67916, 30698, 11, 54851, 46944, 115404, 42192, 99441, 100623, 48692, 100168, 110498, 1773, 151645, 151644, 872, 198, 151665, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151667, 151666, 198, 5501, 7512, 279, 2168, 19620, 13, 151645, 151644, 77091, 198]
310
[151644, 8948, 198, 56568, 104625, 100633, 104455, 104800, 101101, 32022, 102022, 99602, 100013, 9370, 90286, 21287, 42140, 53772, 35243, 26288, 104949, 3837, 105205, 109641, 67916, 30698, 11, 54851, 46944, 115404, 42192, 99441, 100623, 48692, 100168, 110498, 1773, 151645, 151644, 872, 198, 14990, 1879, 151645, 151644, 77091, 198]
47
http:""//0.0.0.0:12345
Model inference​
Host
chmod +x main_axcl_aarch64
bash run_internvl2_5_448_axcl_aarch64.sh
warning
Please check whether the tokenizer_model port in the run_xxx.sh script matches the Tokenizer service port.
(.venv) rock@rock-5b-plus:~/ssd/axera/InternVL2_5-1B$ cat run_internvl2_5_448_axcl_aarch64.sh
./main_axcl_aarch64 \
--template_filename_axmodel "internvl2_5_1b_448_ax650/qwen2_p320_l%d_together.axmodel" \
--axmodel_num 24 \
--filename_image_encoder_axmodedl "internvl2_5_1b_448_ax650/vit_intern_2_5_sim_space2depth_nhwc.axmodel" \
--tokenizer_type 2 \
--bos 0 --eos 0 \
--use_mmap_load_embed 0 \
--filename_tokenizer_model "http:""//127.0.0.1:12345" \
--filename_post_axmodel "internvl2_5_1b_448_ax650/qwen2_post.axmodel" \
--filename_tokens_embed "internvl2_5_1b_448_ax650/model.embed_tokens.weight.bfloat16.bin" \
--tokens_embed_num 151674 \
--tokens_embed_size 896 \
--live_print 1 \
--devices "0" \
--continue 1 \
--prompt "" --image ""
(.venv) rock@rock-5b-plus:~/ssd/axera/InternVL2_5-1B$ bash run_internvl2_5_448_axcl_aarch64.sh
[I][ Init][ 128]: LLM init start
[I][ Init][ 321]: connect http:""//127.0.0.1:12345 ok
bos_id: -1, eos_id: 151645
7% | ███ | 2 / 27 [0.33s<4.40s, 6.13 count/s] embed_selector init ok
[I][ run][ 30]: AXCLWorker start with devid 0
100% | ████████████████████████████████ | 27 / 27 [17.43s<17.43s, 1.55 count/s] init post axmodel ok,remain_cmm(6433 MB)6574 MB)
[I][ Init][ 225]: image_encoder_height : 448, image_encoder_width: 448
[I][ Init][ 227]: max_token_len : 1023
[I][ Init][ 230]: kv_cache_size : 128, kv_cache_num: 1023
[I][ Init][ 238]: prefill_token_num : 320
[I][ Init][ 240]: prefill_max_token_num : 320
________________________
| ID| remain cmm(MB)|
| 0| 6066|
[E][ load_config][ 278]: config file(post_config.json) open failed
[W][ Init][ 333]: load postprocess config(post_config.json) failed
[I][ Init][ 337]: LLM init ok
Type "q" to exit, Ctrl+c to stop current running
prompt >
Performance reference​
ModelQuantizationhost devicetoken/s
InternVL2_5-1Bw8a16ROCK 5B+17.52
