InternVL3-2B
This document explains how to run the InternVL3-2B sample application on a host device equipped with the Radxa AICore AX-M1. For model conversion, please refer to here.
Precompiled model quantization format: w8a16.
Create a virtual environment​
Host
Download the demo repository​
Host
hf download AXERA-TECH/InternVL3-2B --local-dir ./InternVL3-2B
cd InternVL3-2B
Example usage​
Install Python dependencies​
Host
pip3 install transformers==4.53.3 jinja2==3.1.6
Start the Tokenizer service​
Host
python3 internvl3_tokenizer.py --port 12345 > /dev/null 2>&1 &
warning
To stop the background Tokenizer service, use jobs to view the background job number, then use kill %N to terminate the background process, where %N is the corresponding job number.
(.venv) rock@rock-5b-plus:~/ssd/axera/InternVL3-2B$ python3 internvl3_tokenizer.py --port 12345
None of PyTorch, TensorFlow >= 2.0, or Flax have been found. Models won't be available and only tokenizers, configuration and file/data utilities can be used.
None None 151645 <|im_end|> 151665 151667
context_len is 256
prompt is <|im_start|>system
Model inference​
Host
chmod +x main_axcl_aarch64
./main_axcl_aarch64 --template_filename_axmodel "./internvl3_2b_axmodel/qwen2_p128_l%d_together.axmodel" --axmodel_num 28 --filename_image_encoder_axmodedl "./vit_axmodel/internvl3_2b_vit_slim.axmodel" --use_mmap_load_embed 1 --filename_tokenizer_model "http://0.0.0.0:12345" --filename_post_axmodel "./internvl3_2b_axmodel/qwen2_post.axmodel" --filename_tokens_embed "./internvl3_2b_axmodel/model.embed_tokens.weight.bfloat16.bin" --tokens_embed_num 151674 --tokens_embed_size 1536 --devices 0 --live_print
warning
Please check whether the --url_tokenizer_model port in the run_xxx.sh script matches the Tokenizer service port.
(.venv) rock@rock-5b-plus:~/ssd/axera/InternVL3-2B$ ./main_axcl_aarch64 \
--template_filename_axmodel "./internvl3_2b_axmodel/qwen2_p128_l%d_together.axmodel" \
--axmodel_num 28 \
--filename_image_encoder_axmodedl "./vit_axmodel/internvl3_2b_vit_slim.axmodel" \
--use_mmap_load_embed 1 \
--filename_tokenizer_model "http://0.0.0.0:12345" \
--filename_post_axmodel "./internvl3_2b_axmodel/qwen2_post.axmodel" \
--filename_tokens_embed "./internvl3_2b_axmodel/model.embed_tokens.weight.bfloat16.bin" \
--tokens_embed_num 151674 \
--tokens_embed_size 1536 \
--devices 0 \
--live_print 1
[I][ Init][ 160]: LLM init start
[I][ Init][ 34]: connect http://0.0.0.0:12345 ok
bos_id: -1, eos_id: 151645
img_start_token: 151665
img_context_token: 151667
3% | ██ | 1 / 31 [0.00s<0.09s, 333.33 count/s] tokenizer init ok[I][ Init][ 45]: LLaMaEmbedSelector use mmap
6% | ███ | 2 / 31 [0.00s<0.05s, 666.67 count/s] embed_selector init ok
[I][ run][ 30]: AXCLWorker start with devid 0
100% | ████████████████████████████████ | 31 / 31 [45.01s<45.01s, 0.69 count/s] init post axmodel ok,remain_cmm(3371 MB)3614 MB)
input size: 1
name: image [unknown] [unknown]
1 x 3 x 448 x 448 size:2408448
output size: 1
1 x 256 x 1536 size:1572864
[I][ Init][ 265]: IMAGE_CONTEXT_TOKEN: 151667, IMAGE_START_TOKEN: 151665
[I][ Init][ 290]: image encoder input nchw@float32
[I][ Init][ 320]: image encoder output float32
[I][ Init][ 330]: image_encoder_height : 448, image_encoder_width: 448
[I][ Init][ 332]: max_token_len : 2559
[I][ Init][ 335]: kv_cache_size : 256, kv_cache_num: 2559
[I][ Init][ 343]: prefill_token_num : 128
[I][ Init][ 347]: grp: 1, prefill_max_token_num : 1
[I][ Init][ 347]: grp: 2, prefill_max_token_num : 128
[I][ Init][ 347]: grp: 3, prefill_max_token_num : 256
[I][ Init][ 347]: grp: 4, prefill_max_token_num : 384
[I][ Init][ 347]: grp: 5, prefill_max_token_num : 512
[I][ Init][ 347]: grp: 6, prefill_max_token_num : 640
[I][ Init][ 347]: grp: 7, prefill_max_token_num : 768
[I][ Init][ 347]: grp: 8, prefill_max_token_num : 896
[I][ Init][ 347]: grp: 9, prefill_max_token_num : 1024
[I][ Init][ 347]: grp: 10, prefill_max_token_num : 1152
[I][ Init][ 347]: grp: 11, prefill_max_token_num : 1280
[I][ Init][ 347]: grp: 12, prefill_max_token_num : 1408
[I][ Init][ 347]: grp: 13, prefill_max_token_num : 1536
[I][ Init][ 347]: grp: 14, prefill_max_token_num : 1664
[I][ Init][ 347]: grp: 15, prefill_max_token_num : 1792
[I][ Init][ 347]: grp: 16, prefill_max_token_num : 1920
[I][ Init][ 347]: grp: 17, prefill_max_token_num : 2048
[I][ Init][ 351]: prefill_max_token_num : 2048
________________________
| ID| remain cmm(MB)|
| 0| 2996|
[I][ load_config][ 282]: load config:
"enable_repetition_penalty": false,
"enable_temperature": true,
"enable_top_k_sampling": true,
"enable_top_p_sampling": false,
"penalty_window": 20,
"repetition_penalty": 1.2,
"temperature": 0.9,
"top_k": 10,
"top_p": 0.8
[I][ Init][ 448]: LLM init ok
Type "q" to exit, Ctrl+c to stop current running
prompt >>
Performance reference​
ModelQuantizationhost devicetoken/s
InternVL3-2Bw8a16ROCK 5B+8.28
