LocateAnything-3B
This guide explains how to run LocateAnything-3B on a host fitted with an 8 GB Radxa AICore AX-M1. The model locates objects in an image from a category or natural-language description and returns bounding boxes or points.
The precompiled model uses W4A16 quantization with a 560 × 560 image input and takes approximately 3.2 GiB of storage. It requires approximately 2.9 GiB of CMM at runtime, so the 8 GB AX-M1 is recommended.
  • An 8 GB AX-M1 installed in an AArch64 Linux host.
  • The AXCL driver and firmware installed according to Environment Installation, with axcl-smi able to detect the AX-M1.
  • Access to GitHub and Hugging Face, and at least 4 GiB of free storage on the host.
  • A user account that can use sudo to install axllm.
Steps​
Check AX-M1 CMM​
Check the total and remaining CMM before loading the model:
Host
axcl-smi info --cmm
The 8 GB AX-M1 should report a total close to:
CMM Total           :  7208960 KiB
Ensure that CMM Remain is greater than 3 GiB. Stop other applications using the AX-M1 if there is not enough free CMM.
Install axllm​
axllm is the AXERA LLM/VLM inference tool. It supports an interactive terminal and an OpenAI-compatible API. Clone the official repository and run its installer:
Host
cd ~
git clone -b axllm https://github.com/AXERA-TECH/ax-llm.git
cd ax-llm
./install.sh
axllm --version
Confirm that the backend and platform in the version output match the host:
backend          : AXCL
platform : Linux aarch64
Download the model​
Create a Python virtual environment, install the Hugging Face CLI, and download the model:
Host
mkdir -p ~/ax-m1-models
cd ~/ax-m1-models
python3 -m venv .venv
source .venv/bin/activate
pip install -U huggingface_hub
hf download AXERA-TECH/LocateAnything-3B --local-dir ./locate-anything-3b
Confirm that the main runtime files were downloaded:
Host
cd ~/ax-m1-models/locate-anything-3b
test -f config.json
test -f image_encoder_mlp.axmodel
test -f qwen2_post.axmodel
test -f qwen2_5_tokenizer.txt
Run interactive inference​
Start the model:
Host
axllm run .
After the model loads, enter a prompt and the path to the test image:
prompt >> Find the people in the image
media >> ./test_data/locate-anything-online.jpg
The model returns a <ref> tag and one or more <box> tags:
<ref>...</ref><box><342><0><399><55></box><box><646><45><971><1000></box><box><842><0><950><200></box>
Coordinates use a normalized range from 0 to 1000. A bounding box has the following format:
<x_min><y_min><x_max><y_max>
Enter /q to exit the interactive program.
Start the OpenAI-compatible API​
Start the service from the model directory:
Host
axllm serve . --port 8010
After loading the model, the service displays these endpoints:
GET  /health
GET /v1/models
POST /v1/chat/completions
Open another terminal and check the service status and model ID:
Host
API_BASE="http:"'//127.0.0.1:8010'
curl --fail "${API_BASE}/health"
curl --fail "${API_BASE}/v1/models"
The health endpoint should return "status": "healthy", and the model list should contain:
The current service supports a maximum concurrency of 1. Applications can send OpenAI-compatible multimodal requests to /v1/chat/completions.
Start the lightweight WebUI​
Keep axllm serve running and start the WebUI included in the model package from another terminal:
Host
python3 ./locateanything_webui.py \
--host 0.0.0.0 \
--port 7861 \
--serve-url "${API_BASE}" \
--image-dir ./pexels-images \
--model AXERA-TECH/LocateAnything-3B
From a browser on the same LAN, open port 7861 on the host device's IP address. The UI supports image uploads, object detection, phrase grounding, text-region localization, document layout analysis, and GUI element localization. It draws the boxes or points returned by the model on a canvas.
After selecting a task and detection categories, preview the image to be processed:
LocateAnything WebUI before inference
The page provides the person category by default; this example also adds a shoes category. After you click Detect, the result shows that the model can also locate the shoes accurately:
LocateAnything WebUI detection result
note
In the current model package, locateanything_webui.py is in the model directory. If the model README still uses scripts/locateanything_webui.py, use the path of the file that was actually downloaded.
Other run modes
The model package also provides a single-process WebUI and a command-line inference mode based on pyaxengine. See the model repository README for their dependencies, parameters, and latest usage.
Expected Output​
After axllm run loads the model, it displays prompt >> and returns <ref> and <box> tags after inference. After axllm serve loads the model, it listens on port 8010, the health endpoint returns "status": "healthy", and the model list contains AXERA-TECH/LocateAnything-3B.
The following results were obtained on a ROCK 5B+ with an 8 GB AX-M1 using the test image included with the model. They are provided for performance reference only:
MetricReference value
Full model initializationApproximately 73 seconds
Input length431 tokens
Prefill chunks4
TTFT2385.18 ms
Decode rate3.60 tokens/s
CMM Used while the model is loaded2861176 KiB (approximately 2.73 GiB)
CMM Used after the model exits18876 KiB (approximately 18 MiB)
The TTFT result used the vision cache for the test image. Processing a new image for the first time usually produces a higher TTFT. Performance varies with the host, runtime version, prompt length, and image-cache state.
Validation​
Complete these checks to confirm a successful deployment:
  1. axllm run loads all model components and returns <ref> and <box> tags.
  2. The health check command returns a healthy status.
  3. /v1/models returns the model ID AXERA-TECH/LocateAnything-3B.
  4. Check CMM again after exiting axllm:
Host
axcl-smi info --cmm
CMM Used should return to its pre-launch baseline. If it does not, check whether an axllm or WebUI process is still running.
Stop the services​
Press Ctrl+C in the terminals running axllm serve and the WebUI. Confirm that the ports are no longer in use:
Host
ss -ltnp | grep -E ':(7861|8010)'
No output means that neither port is being listened on.
