Qwen2.5-VL-3B-Instruct
This document explains how to run the Qwen2.5-VL-3B-Instruct sample application on a host device equipped with the Radxa AICore AX-M1.
Precompiled model quantization format: w8a16.
Create a virtual environment​
Host
Download the demo repository​
Host
hf download AXERA-TECH/Qwen2.5-VL-3B-Instruct --local-dir ./Qwen2.5-VL-3B-Instruct
cd Qwen2.5-VL-3B-Instruct
Example usage​
Install Python dependencies​
Host
pip3 install transformers==4.53.3 jinja2==3.1.6
Start the Tokenizer service​
Host
python3 qwen2_tokenizer_images.py --port 12345 > /dev/null 2>&1 &
(.venv) rock@rock-5b-plus:~/ssd/axera/Qwen2.5-VL-3B-Instruct$ python3 qwen2_tokenizer_images.py --port 12345
None None 151645 <|im_end|>
[151644, 8948, 198, 2610, 525, 264, 10950, 17847, 13, 151645, 198, 151644, 872, 198, 151652, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151653, 74785, 419, 2168, 13, 151645, 198, 151644, 77091, 198]
281
[151644, 8948, 198, 2610, 525, 264, 10950, 17847, 13, 151645, 198, 151644, 872, 198, 14990, 1879, 151645, 198, 151644, 77091, 198]
21
http://localhost:12345
warning
To stop the background Tokenizer service, use jobs to view the background job number, then use kill %N to terminate the background process, where %N is the corresponding job number.
Model inference​
Host
chmod +x main_axcl_aarch64
bash run_qwen2_5_vl_image_axcl_aarch64.sh
(.venv) rock@rock-5b-plus:~/ssd/axera/Qwen2.5-VL-3B-Instruct$ bash run_qwen2_5_vl_image_axcl_aarch64.sh
[I][ Init][ 162]: LLM init start
[I][ Init][ 34]: connect http://127.0.0.1:12345 ok
bos_id: -1, eos_id: 151645
img_start_token: 151652
img_context_token: 151655
2% | █ | 1 / 39 [0.00s<0.16s, 250.00 count/s] tokenizer init ok[I][ Init][ 45]: LLaMaEmbedSelector use mmap
5% | ██ | 2 / 39 [0.00s<0.08s, 500.00 count/s] embed_selector init ok
[I][ run][ 30]: AXCLWorker start with devid 0
12% | █████ | 4 / 39 [11.15s<86.99s, 0.45 count/s] init 24 axmodel ok,devid(0) remain_cmm(-1 MB) 100% | ████████████████████████████████ | 39 / 39 [54.60s<57.55s, 0.68 count/s] init post axmodel ok,remain_cmm(3220 MB)545 MB))
input size: 1
name: hidden_states [unknown] [unknown]
1 x 1024 x 392 x 3 size:1204224
output size: 1
256 x 2048 size:2097152
[I][ Init][ 267]: IMAGE_CONTEXT_TOKEN: 151655, IMAGE_START_TOKEN: 151652
[I][ Init][ 328]: image encoder output float32
[I][ Init][ 340]: max_token_len : 1023
[I][ Init][ 343]: kv_cache_size : 256, kv_cache_num: 1023
[I][ Init][ 351]: prefill_token_num : 128
[I][ Init][ 355]: grp: 1, prefill_max_token_num : 1
[I][ Init][ 355]: grp: 2, prefill_max_token_num : 128
[I][ Init][ 355]: grp: 3, prefill_max_token_num : 256
[I][ Init][ 355]: grp: 4, prefill_max_token_num : 384
[I][ Init][ 355]: grp: 5, prefill_max_token_num : 512
[I][ Init][ 359]: prefill_max_token_num : 512
________________________
| ID| remain cmm(MB)|
| 0| 2286|
[E][ load_config][ 278]: config file(post_config.json) open failed
[W][ Init][ 452]: load postprocess config(post_config.json) failed
[I][ Init][ 456]: LLM init ok
Type "q" to exit, Ctrl+c to stop current running
prompt >> Describe the image
image >> image/ssd_car.jpg
[I][ Encode][ 539]: image encode time : 787.804993 ms, size : 524288
[I][ Run][ 625]: input token num : 280, prefill_split_num : 3
[I][ Run][ 659]: input_num_token:128
[I][ Run][ 659]: input_num_token:24
[I][ Run][ 796]: ttft: 1964.38 ms
This image shows a busy city street. In the foreground, a woman stands on the sidewalk wearing a black coat and smiling. Next to her is a red double-decker bus with an advertisement reading "THINGS GET MORE EXCITING WHEN YOU SAY 'YES'". The bus license plate is "L15". A black van is parked beside the bus. In the background, there are shops and pedestrians, and modern glass buildings line the street. The overall atmosphere feels busy and vibrant.
[N][ Run][ 949]: hit eos,avg 4.95 token/s
warning
Please check whether the tokenizer_model port in the run_xxx.sh script matches the Tokenizer service port.
Performance reference​
ModelQuantizationhost devicetoken/s
Qwen2.5-VL-3B-Instructw8a16ROCK 5B+4.95
