AXCL SDK FFmpeg
This document describes how to use the FFmpeg hardware encoder/decoder in the AXCL SDK, based on FFmpeg 7.1.
Overview​
AXCL SDK provides a hardware encode/decode solution based on FFmpeg 7.1, with built-in support for hardware decoding/encoding on AX650N and other devices. The shared libraries and executables are pre-compiled and ready to use.
ItemPath
Shared Libraries/usr/lib/axcl/ffmpeg/
Executable/usr/bin/axcl/ffmpeg/ffmpeg
Supported Hardware Decoders:
DecoderFormatOutput Pixel Format
h264_axdecH.264NV12
hevc_axdecHEVC/H.265NV12
Supported Hardware Encoders (if available):
EncoderFormatInput Pixel Format
h264_axencH.264NV12
hevc_axencHEVC/H.265NV12
Environment Setup​
Set Shared Library Path​
Before using AXCL FFmpeg, you must set LD_LIBRARY_PATH, otherwise the runtime will fail to find the .so files:
Host
export LD_LIBRARY_PATH="/usr/lib/axcl/ffmpeg:$LD_LIBRARY_PATH"
It is recommended to add this line to ~/.bashrc or your startup script.
Verify Installation​
Host
/usr/bin/axcl/ffmpeg/ffmpeg -version
You should see FFmpeg 7.1 version information.
List Available Codecs​
Host
/usr/bin/axcl/ffmpeg/ffmpeg -decoders | grep ax
/usr/bin/axcl/ffmpeg/ffmpeg -encoders | grep ax
Command Line Usage​
Hardware Decoding​
H.264 Local File Decoding​
Host
/usr/bin/axcl/ffmpeg/ffmpeg \
-c:v h264_axdec \
-i input.mp4 \
-frames:v 10 \
output_%03d.yuv
HEVC Local File Decoding​
Host
-c:v hevc_axdec \
-i input.hevc \
-frames:v 10 \
output_%03d.yuv
RTSP Stream Decoding​
Host
-rtsp_transport tcp \
-c:v h264_axdec \
-i rtsp://192.168.1.100:8554/stream \
-frames:v 100 \
-pix_fmt nv12 \
output.yuv
For RTSP, TCP transport (-rtsp_transport tcp) is recommended for better stability.
Decoding to Raw Pixel Files​
Host
# Output NV12 format YUV
-c:v h264_axdec \
-i input.mp4 \
-frames:v 10 \
-pix_fmt nv12 \
output.yuv
# Output RGB24
-c:v h264_axdec \
-i input.mp4 \
-frames:v 10 \
-pix_fmt rgb24 \
output.rgb
Decoding to Image Sequence​
Host
-c:v h264_axdec \
-i input.mp4 \
Verify Decoding Correctness (null output)​
Host
-c:v h264_axdec \
-i input.mp4 \
-frames:v 5 \
-f null -
Hardware Encoding​
H.264 Encoding​
Host
/usr/bin/axcl/ffmpeg/ffmpeg -hide_banner -y \
-init_hw_device axmm=ax:,device_index=0,alloc_blk=1 \
-f rawvideo \
-pix_fmt yuv420p \
-s 1920x1080 \
-r 24000/1001 \
-i input.yuv \
-frames:v 300 \
-pix_fmt nv12 \
-c:v h264_axenc \
-b:v 2M \
output.h264
HEVC Encoding​
Host
-f rawvideo \
-pix_fmt yuv420p \
-s 1280x720 \
-r 24000/1001 \
-i input.yuv \
-frames:v 300 \
-pix_fmt nv12 \
-c:v hevc_axenc \
-b:v 2M \
output.hevc
Encoding Parameter Tuning​
Host
-i input.yuv \
-c:v h264_axenc \
-b:v 4M \
-maxrate 6M \
-bufsize 8M \
-g 30 \
-preset fast \
output.mp4
ParameterDescription
-b:v 4MTarget bitrate 4Mbps
-maxrate 6MMaximum bitrate
-bufsize 8MRate control buffer
-g 30GOP size (keyframe interval)
-preset fastEncoding speed preset
Version Notes​
The FFmpeg in AXCL SDK is based on FFmpeg 7.1. Pay attention to the following version compatibility issues:
Header Files Must Match the Runtime Version​
The AXCL FFmpeg runtime library (.so files) is v61 (FFmpeg 7.1). If you compile your C/C++ code using v59 (FFmpeg 5.x) header files, the struct layouts are incompatible between versions, which will cause runtime crashes (e.g., accessing AVStream.codecpar fails).
Recommended approach: Download the corresponding source code (n7.1) from the FFmpeg website, and add the header directory to your compile include path:
Host
wget https://ffmpeg.org/releases/ffmpeg-7.1.tar.xz
tar xf ffmpeg-7.1.tar.xz
# Compile with -I/path/to/ffmpeg-7.1
API Changes​
Some FFmpeg 7.x API parameter types differ from 5.x. Note the following:
Functionv5.xv7.x
avcodec_free_contextavcodec_free_context(AVCodecContext* ctx)avcodec_free_context(AVCodecContext** ctx)
av_frame_freeav_frame_free(AVFrame* frame)av_frame_free(AVFrame** frame)
av_packet_freeav_packet_free(AVPacket* pkt)av_packet_free(AVPacket** pkt)
caution
Note the address-of operator (&) is required in v7.x.
Recompiling FFmpeg​
If you need to customize and recompile FFmpeg, follow the steps below.
Obtain Source Code​
Download FFmpeg n7.1 source from GitHub:
Host
wget https://github.com/FFmpeg/FFmpeg/archive/refs/tags/n7.1.tar.gz
Copy the source package to the SDK directory:
Host
cp n7.1.tar.gz ${AXCL_SDK}/axcl/3rdparty/ffmpeg/
cd ${AXCL_SDK}/axcl/3rdparty/ffmpeg
tar -zxvf n7.1.tar.gz
Apply Patch​
The SDK provides a patch for AX650N hardware adaptation:
Host
patch -p3 < FFmpeg-n7.1.patch
Build​
ARM64 target (for AX650N):
Host
make host=arm64 clean all install
Output files:
lib: ${AXCL_SDK}/axcl/out/axcl_linux_arm64/lib/ffmpeg/
bin: ${AXCL_SDK}/axcl/out/axcl_linux_arm64/bin/ffmpeg
x86 target (for development host cross-compilation):
Host
make host=x86 clean all install
Output files:
lib: ${AXCL_SDK}/axcl/out/axcl_linux_x86/lib/ffmpeg/
bin: ${AXCL_SDK}/axcl/out/axcl_linux_x86/bin/ffmpeg
FAQ​
Q1: error while loading shared libraries at runtime​
Shared library not found. Verify LD_LIBRARY_PATH is set:
Host
Q2: RTSP stream connection timeout​
  • Verify the RTSP URL is accessible (test with VLC or similar)
  • Try specifying TCP transport: -rtsp_transport tcp
  • Increase timeout: -timeout 10000000 (microseconds)
Q3: Decoded video looks abnormal (corruption/green screen)​
  • Verify the input file codec matches the decoder (use h264_axdec for H.264, hevc_axdec for HEVC)
  • Verify the output pixel format is correctly specified (h264_axdec outputs NV12)
Q4: Struct access crash at compile time​
This is likely caused by a mismatch between header file and runtime library versions. Use FFmpeg 7.1 header files for compilation. See Section 5.1 of this document.
Q5: Compile error undefined reference to swr_*​
Library linking order issue. The order of FFmpeg libraries affects symbol resolution. Ensure -lswresample comes after -lavcodec:
-lavcodec -lavformat -lavutil -lswscale -lswresample
