AXCL Multistream YOLO
This document describes the axera-multistream-yolo project, a real-time multi-stream video YOLO detection solution based on Radxa AX-M1.
This project depends on AXCL SDK and FFmpeg hardware decoding. Before proceeding, ensure you have configured:
Hardware Environment​
ItemSpecification
DEVICERadxa AX-M1(Rock 5B+ Host)
NPUAX8850(AXCL SDK V3.6.5)
DecodeFFmpeg 7.1(h264_axdec / hevc_axdec)
Project Structure​
axera-multistream-yolo/
├── src/ # Core implementation
│ ├── inference_engine.cpp # NPU inference wrapper(letterbox + AXCL + NMS)
│ ├── pipeline.cpp # StreamWorker × N orchestration
│ ├── stream_source.cpp # FFmpeg hardware decode(RTSP / local file)
├── include/app/ # Header files
├── tools/npu_bench.cpp # NPU performance benchmark tool
├── configs/ # JSON configuration files
└── yolo26_demo/ # AXCL SDK reference implementation(for reference only)
Quick Start​
Clone the repository​
Host
git clone https://github.com/Ronin-1124/axera-multistream-yolo.git
cd axera-multistream-yolo/
Build​
Host
mkdir build && cd build
cmake .. && make -j$(nproc)
Configure​
Edit configs/app_config.json:
"streams": [
{ "id": 0, "url": "./data/test_videos_360P/test1.mp4", "enabled": true },
"id": 1,
"url": "rtsp://user:[email protected]:554/stream",
"enabled": true
"model": {
"path": "./models/yolo26n.axmodel",
"input_h": 640,
"input_w": 640
"output": { "display": true, "mosaic_cols": 2, "queue_depth": 4 }
Run​
Host
LD_LIBRARY_PATH="/usr/lib/axcl/ffmpeg:/usr/lib/axcl:$LD_LIBRARY_PATH" \
./build/axera_multistream_yolo --config ./configs/app_config.json
axcl-multistream-yolo demo output
When display=false, only frame rate monitoring logs are output:
[Collector] S0:14.0 S1:13.0 S2:14.0 S3:13.0 fps (1s)
[Collector] S0:15.0 S1:14.0 S2:14.0 S3:14.0 fps (1s)
NPU Performance Benchmark Tool​
Host
# Stage time breakdown (H2D / NPU kernel / D2H / Post)
./build/tools/npu_bench <model> <image> --stages [N]
# Thread scalability test (1..N threads)
./build/tools/npu_bench <model> <image> --sweep <max_threads> <iters>
# Fixed thread count test
./build/tools/npu_bench <model> <image> --mt <threads> <iters>
Example:
  Stage breakdown (SDK)  (100 iterations, 640x640 input)
avg min max
Pre 5.69 3.82 16.86 ms
H2D 3.27 2.94 3.83 ms
NPU 1.97 1.75 2.20 ms
D2H 6.47 5.38 7.51 ms
Post 5.31 2.20 12.31 ms
Total 22.71 ms
Architecture​
1:1 Fixed Ratio: Each stream = 1 read thread + 1 inference thread, fully independent.
StreamWorker × N(per stream independent)
├─ StreamSource(FFmpeg decode)→ ThreadSafeQueue → InferenceThread
└─────────────────────────────────────────────────────► ResultQueue
ResultCollector
└─ MosaicRenderer → imshow
Performance Data(YOLO26n,640×640)​
ConfigurationFrame Rate
Single stream end-to-end~40 fps
8-stream concurrent(mosaic)53-57 fps mosaic
AXCL multi-thread scaling~120 fps(plateau after 3 threads)
