AXCL-SMI Tool Usage
Overview​
The AXCL-SMI (System Management Interface) tool is used for collecting device information and configuring the device. It supports collecting the following device information:
  • Hardware model
  • Firmware version
  • Driver version
  • Device utilization
  • Memory usage
  • Device junction temperature
  • Other information
Usage​
After installing the AXCL driver package correctly, axcl-smi is available. Run axcl-smi to display the following information:
Host
axcl-smi
rock@rock-5b-plus:~$ axcl-smi
| AXCL-SMI V3.6.5_20250908154509 Driver V3.6.5_20250908154509 |
| Card Name Firmware | Bus-Id | Memory-Usage |
| Fan Temp Pwr:Usage/Cap | CPU NPU | CMM-Usage |
| 0 AX650N V3.6.5 | 0001:11:00.0 | 152 MiB / 945 MiB |
| -- 81C -- / -- | 1% 0% | 18 MiB / 7040 MiB |
| Processes: |
| Card PID Process Name NPU Memory Usage |
Field description
FieldDescriptionFieldDescription
CardDevice index (not the PCIe device no.)Bus-IdDevice Bus ID
NameDevice nameCPUAverage CPU usage
FanFan speed ratio (not supported)NPUAverage NPU usage
TempDevice junction temperatureMemory-UsageSystem memory: used/total
FirmwareDevice firmware versionCMM-UsageMedia memory: used/total
Pwr: Usage/CapPower (not supported)
PIDMain process PID
Process NameMain process name
NPU Memory UsageCMM memory used by the device NPU
Help (-h) and Version (-v)​
axcl-smi -h to view help information
Host
axcl-smi -h
rock@rock-5b-plus:~$ axcl-smi -h
usage: axcl-smi [<command> [<args>]] [--device] [--version] [--help]
axcl-smi System Management Interface V3.6.5_20250908154509
Commands
info Show device information
--temp Show SoC temperature
--mem Show memory usage
--cmm Show CMM usage
--cpu Show CPU usage
--npu Show NPU usage
proc cat device proc
--vdec cat /proc/ax_proc/vdec
--venc cat /proc/ax_proc/venc
--jenc cat /proc/ax_proc/jenc
--ivps cat /proc/ax_proc/ivps
--rgn cat /proc/ax_proc/rgn
--ive cat /proc/ax_proc/ive
--pool cat /proc/ax_proc/pool
--link cat /proc/ax_proc/link_table
--cmm cat /proc/ax_proc/mem_cmm_info
set Set
-f[MHz], --freq=[MHz] Set CPU frequency in MHz. One of: 1200000, 1400000, 1700000
log Dump logs from device
-t[mask], --type=[mask] Specifies which logs to dump by a combination (bitwise OR) value of blow:
-1: all (default) 0x01: daemon 0x02: worker 0x10: syslog 0x20: kernel
-o[path], --output=[path] Specifies the path to save dump logs (default: ./)
sh Execute a shell command
cmd Shell command
args... Shell command arguments
reboot reboot device
-d, --device Card index [0, connected cards number - 1]
-v, --version Show axcl-smi version
-h, --help Show this help menu
axcl-smi -v to view the AXCL-SMI tool version
Host
axcl-smi -v
rock@rock-5b-plus:~$ axcl-smi -v
AXCL-SMI V3.6.5_20250908154509 BUILD: Sep 8 2025 16:14:02
Options​
Device index (-d, --device)​
[-d, --device] specifies the device index, range: [0, number of connected devices - 1]. The default is device 0.
Information query (info)​
axcl-smi info displays detailed device information. Supported subcommands:
SubcommandDescription
tempShow the device SoC junction temperature, unit is Celsius x1000.
memShow detailed system memory usage.
cmmShow media (CMM) memory usage. For more detailed media memory, run axcl-smi sh cat /proc/ax_proc/mem_cmm_info -d xx (xx is PCIe id).
cpuShow device CPU utilization.
npuShow device NPU utilization.
Example: Query media (CMM) memory usage for device index 0:
Host
axcl-smi info --cmm -d 0
rock@rock-5b-plus:~$ axcl-smi info --cmm -d 0
Device ID : 17 (0x11)
CMM Total : 7208960 KiB
CMM Used : 18876 KiB
CMM Remain : 7190084 kiB
PROC query (proc)​
axcl-smi proc queries proc information for device modules. Supported subcommands:
--vdecQuery VDEC module proc (cat /proc/ax_proc/vdec)
--vencQuery VENC module proc (cat /proc/ax_proc/venc)
--jencQuery JENC module proc (cat /proc/ax_proc/jenc)
--ivpsQuery IVPS module proc (cat /proc/ax_proc/ivps)
--rgnQuery RGN module proc (cat /proc/ax_proc/rgn)
--iveQuery IVE module proc (cat /proc/ax_proc/ive)
--poolQuery POOL module proc (cat /proc/ax_proc/pool)
--linkQuery LINK module proc (cat /proc/ax_proc/link_table)
--cmmQuery CMM module proc (cat /proc/ax_proc/mem_cmm_info)
Example: Query VDEC proc information for device 0
Host
axcl-smi proc --vdec -d 0
rock@rock-5b-plus:~$ axcl-smi proc --vdec -d 0
--------AX VDEC VERSION ------------------------
[Axera version]: ax_vdec V3.6.5_20250908154509 Sep 8 2025 16:05:36 JK
Parameter settings (set)​
axcl-smi set configures device parameters. Supported subcommands:
-f[MHz], --freq=[MHz]Set device CPU frequency; supports 1200000, 1400000, 1700000
Example: Set CPU frequency of device index 0 to 1200 MHz
Host
axcl-smi set -f 1200000 -d 0
rock@rock-5b-plus:~$ axcl-smi set -f 1200000 -d 0
set cpu frequency 1200000 to device 1 succeed.
Download logs (log)​
axcl-smi log downloads device logs to the host. Supported options:
OptionDescription
-t[mask], --type=[mask]Specify which logs to download. On device:
-1: all logs (recommended)
0x01: daemon
0x02: worker
0x10: syslog
0x20: kernel
-o[path], --output=[path]Path to save logs; supports absolute and relative paths, default is current directory. Ensure the directory is writable.
Example: Download all logs from device index 0 and save to the current directory
Host
axcl-smi log -d 0
rock@rock-5b-plus:~$ axcl-smi log -d 0
[2025-07-22 07:31:59.215][1858][C][log][dump][73]: log dump finished: ./dev1_log_20250722122146.tar.gz
Shell command (sh)​
axcl-smi sh supports running shell commands to query device information, typically to read device-side proc details. Example: query CMM info of device index 0
Host
axcl-smi sh cat /proc/ax_proc/mem_cmm_info -d 0
rock@rock-5b-plus:~$ axcl-smi sh cat /proc/ax_proc/mem_cmm_info -d 0
--------------------SDK VERSION-------------------
[Axera version]: ax_cmm V3.6.5_20250908154509 Sep 8 2025 16:04:54 JK
+---PARTITION: Phys(0x148000000, 0x2FFFFFFFF), Size=7208960KB(7040MB), NAME="anonymous"
nBlock(Max=0, Cur=23, New=0, Free=0) nbytes(Max=0B(0KB,0MB), Cur=19329024B(18876KB,18MB), New=0B(0KB,0MB), Free=0B(0KB,0MB)) Block(Max=0B(0KB,0MB), Min=0B(0KB,0MB), Avg=0B(0KB,0MB))
|-Block: phys(0x148000000, 0x148013FFF), cache =non-cacheable, length=80KB(0MB), name="TDP_DEV"
|-Block: phys(0x148014000, 0x148014FFF), cache =non-cacheable, length=4KB(0MB), name="TDP_CMODE3"
|-Block: phys(0x148015000, 0x148015FFF), cache =non-cacheable, length=4KB(0MB), name="TDP_CMODE3_CPU"
|-Block: phys(0x148016000, 0x148029FFF), cache =non-cacheable, length=80KB(0MB), name="TDP_DEV"
|-Block: phys(0x14802A000, 0x14802AFFF), cache =non-cacheable, length=4KB(0MB), name="TDP_CMODE3"
|-Block: phys(0x14802B000, 0x14802BFFF), cache =non-cacheable, length=4KB(0MB), name="TDP_CMODE3_CPU"
|-Block: phys(0x14802C000, 0x14862BFFF), cache =non-cacheable, length=6144KB(6MB), name="vdec_ko"
|-Block: phys(0x14862C000, 0x148647FFF), cache =non-cacheable, length=112KB(0MB), name="VGP_DEV"
|-Block: phys(0x148648000, 0x148648FFF), cache =non-cacheable, length=4KB(0MB), name="VGP_CMODE3"
|-Block: phys(0x148649000, 0x148649FFF), cache =non-cacheable, length=4KB(0MB), name="VGP_CMODE3_CPU"
|-Block: phys(0x14864A000, 0x148665FFF), cache =non-cacheable, length=112KB(0MB), name="VPP_DEV"
|-Block: phys(0x148666000, 0x148666FFF), cache =non-cacheable, length=4KB(0MB), name="VPP_CMODE3"
|-Block: phys(0x148667000, 0x148667FFF), cache =non-cacheable, length=4KB(0MB), name="VPP_CMODE3_CPU"
|-Block: phys(0x148668000, 0x1487E7FFF), cache =non-cacheable, length=1536KB(1MB), name="h26x_ko"
|-Block: phys(0x1487E8000, 0x148967FFF), cache =non-cacheable, length=1536KB(1MB), name="h26x_ko"
|-Block: phys(0x148968000, 0x148968FFF), cache =non-cacheable, length=4KB(0MB), name="h26x_ko"
|-Block: phys(0x148969000, 0x148AE8FFF), cache =non-cacheable, length=1536KB(1MB), name="jenc_ko"
|-Block: phys(0x148AE9000, 0x148C68FFF), cache =non-cacheable, length=1536KB(1MB), name="jenc_ko"
|-Block: phys(0x148C69000, 0x148C69FFF), cache =non-cacheable, length=4KB(0MB), name="jenc_ko"
|-Block: phys(0x148C6A000, 0x148C6AFFF), cache =non-cacheable, length=4KB(0MB), name="GDC_CMDA3"
|-Block: phys(0x148C6B000, 0x148C6BFFF), cache =non-cacheable, length=4KB(0MB), name="GDC_CMDA3_CPU"
|-Block: phys(0x148C6C000, 0x148C6EFFF), cache =non-cacheable, length=12KB(0MB), name="GDC_CMD"
|-Block: phys(0x148C6F000, 0x14926EFFF), cache =non-cacheable, length=6144KB(6MB), name="vdec_ko"
---CMM_USE_INFO:
total size=7208960KB(7040MB),used=18876KB(18MB + 444KB),remain=7190084KB(7021MB + 580KB),partition_number=1,block_number=23
Reboot (reboot)​
The axcl-smi reboot command resets the specified device and then automatically loads the firmware. Example:
Host
axcl-smi reboot -d 0
rock@rock-5b-plus:~$ axcl-smi reboot -d 0
Do you want to reboot device 0 ? (y/n): y
