Getting started
Using ROCK 5B+ as the primary example, this guide explains how to pair the Radxa AICore AX-M1 with your hardware.
Product overview​
Radxa AICore AX-M1 (front)
Radxa AICore AX-M1 (back)
Requirements​
Prepare the following hardware before using the Radxa AICore AX-M1:
  • AI compute module: Radxa AICore AX-M1
  • BOard kit: compatible Board + power adapter + boot media (e.g., microSD card)
Verified Radxa-compatible boards
- ROCK 2A
- ROCK 2F
- ROCK 3B
- ROCK 3C
- ROCK 4A/4A+/4B/4B+/SE
- ROCK 5A/5B/5B+/5C/5T/5ITX
- Dragon Q6A
- Orion O6
- Orion O6N
- Cubie A5E
- Raspberry Pi 5
Requirements
Your Board must meet all of the following:
  • Boot the operating system normally
  • Provide an available M.2 M Key slot for installing the Radxa AICore AX-M1
Hardware installation​
For ROCK 5B+, follow the hardware installation guide to install the Radxa AICore AX-M1.
Notes
Boards that support M.2 M Key peripherals share similar installation steps. Refer to the same hardware installation guide.
Environment setup​
See environment setup to prepare the software environment for the Radxa AICore AX-M1.
Quick validation​
Use quick validation to confirm that the Radxa AICore AX-M1 NPU can run inference.
