Environment setup
Follow the hardware installation guide to install the Radxa AICore AX-M1 on the host device.
Check the device connection​
  • Use lspci to confirm that the Radxa AICore AX-M1 is detected.
Host
lspci
0000:01:00.0 Multimedia video controller: Axera Semiconductor Co., Ltd Device 0650 (rev 01)
Install the driver​
  • Install dependencies
Host
sudo apt install gcc linux-headers-$(uname -r) make
  • Install the AXCL driver
Go to the Downloads page to download the required software packages, and place them in the same directory. Choose the 4GB or 8GB version according to the memory capacity of your Radxa AICore AX-M1.
Host
sudo dpkg -i axclhost-firmware_3.6.5-1_all_4gb.deb
sudo dpkg -i task-axclhost_3.6.5-1_all.deb
sudo dpkg -i axclhost-dkms_3.6.5-1_all.deb
sudo systemctl restart systemd-modules-load
  • Verify the installation
Host
axcl-smi
rock@rock-5b-plus:~$ axcl-smi
| AXCL-SMI V3.6.5_20250908154509 Driver V3.6.5_20250908154509 |
| Card Name Firmware | Bus-Id | Memory-Usage |
| Fan Temp Pwr:Usage/Cap | CPU NPU | CMM-Usage |
| 0 AX650N V3.6.5 | 0001:11:00.0 | 148 MiB / 945 MiB |
| -- 54C -- / -- | 2% 0% | 18 MiB / 7040 MiB |
| Processes: |
| Card PID Process Name NPU Memory Usage |
Uninstall the driver​
If you need to uninstall the AXCL driver, run the following command.
Host
sudo apt remove axclhost
