Stable Diffusion 1.5 Euler
This document explains how to run the Stable Diffusion 1.5 Euler model for text-to-image inference on a host device equipped with Radxa AX-M1.
This example is based on the solution provided by community user SHANKAR_THAKUR, thanks for their contribution.
Environment Preparation​
Before starting, please ensure:
  • Radxa AX-M1 is properly installed and connected to the host
  • The host (supporting Rock 5B/5B+ or Raspberry Pi 5) has the Radxa official image or other compatible operating system installed
  • Network connection is normal and GitHub and HuggingFace are accessible
Raspberry Pi 5 can also be used as the host, as long as AX-M1 is connected and the AXCLRT runtime can run on that operating system.
caution
Please ensure the AX-M1 hardware connection is stable. If inference fails, first check the hardware connection status and device temperature.
Clone the Project Repository​
Host
git clone https://github.com/Mojo24x7/SD1.5_AXM1-AX8850_Euler && cd SD1.5_AXM1-AX8850_Euler
Create Virtual Environment​
Host
python3 -m venv .venv
Activate Virtual Environment and Upgrade pip​
Host
source .venv/bin/activate && pip install -U pip
Install Project Dependencies​
Host
Download and Install pyaxengine​
pyaxengine is the official Python API library provided by AXERA for running inference on AX-M1.
Host
wget https://github.com/AXERA-TECH/pyaxengine/releases/download/0.1.3.rc3/axengine-0.1.3-py3-none-any.whl
pip install axengine-0.1.3-py3-none-any.whl
Download Pre-trained Model​
First, install git-lfs:
Host
sudo apt update && sudo apt install git-lfs
git lfs install
Clone the model repository from HuggingFace:
Host
git clone https://huggingface.co/Mojo24x7/sd15-axm1-euler512-axmodels hf_axmodels
Copy model files to the specified directory:
Host
mkdir -p axmodels
cp -v hf_axmodels/*.axmodel axmodels/
The model files are large and download may take a long time, please be patient.
Run Text-to-Image Inference​
Host
python3 scripts/txt2img_axengine_euler.py \
--weights_dir ./axmodels \
--tokenizer_dir ./support/tokenizer \
--scheduler_dir ./support/scheduler \
--vae_config ./support/vae/config.json \
--prompt "a cinematic ultra realistic portrait photo" \
--steps 30 \
--out ./out/txt2img_euler_512.png
Parameter Description​
ParameterDescription
--weights_dirModel weights directory
--tokenizer_dirTokenizer directory
--scheduler_dirScheduler configuration directory
--vae_configVAE config file path
--promptInput text prompt
--stepsInference steps
--outOutput image path
Expected Output​
After successful inference, the output image will be saved at ./out/txt2img_euler_512.png.
Run Web UI​
The project also provides a Web UI for interactive image generation:
Host
python run_ui.py --base_dir ./ --out_root ./out --venv_py ~/SD1.5_AXM1-AX8850_Euler/.venv/bin/python --token_max_len 100
Please ensure the virtual environment path matches the actual path. If the path is different, modify the --venv_py parameter to point to the correct Python interpreter path.
FAQ​
How to Troubleshoot Inference Failure?​
  1. Check hardware connection: Ensure the AX-M1 module is properly connected to the M.2 interface
  2. Check device temperature: High temperature may cause performance degradation or inference failure
  3. Check virtual environment: Ensure you are using the Python interpreter from the correct virtual environment
  4. Check log output: Detailed logs usually indicate the specific error cause
What if Model Download Fails?​
  • Check network connection to ensure HuggingFace is accessible
  • Try using a proxy or mirror site
  • You can manually download model files and copy them to the corresponding directory
Slow Inference Speed?​
  • Check AX-M1 heat dissipation, add a heatsink if necessary
  • Confirm the NPU is working properly (can be checked with axcl-smi command)
