YOLOv8-Seg
This document explains how to run the YOLOv8-seg sample application on a host device equipped with the Radxa AICore AX-M1.
For instructions on building the executable, see AXCL-Samples build examples. Python inference depends on PyAXEngine.
Precompiled model quantization format: w8a16.
Create a virtual environment​
Host
Download the demo repository​
Download only the triple-core model and inference script required by the AX-M1:
Host
hf download AXERA-TECH/YOLOv8-Seg \
AX650/yolov8s-seg_640x640_npu3.axmodel \
ax_infer.py \
bus.jpg \
--local-dir ./YOLOv8-Seg
cd YOLOv8-Seg
Example usage​
Install Python dependencies​
Host
Model inference​
The Radxa AICore AX-M1 is an M.2 accelerator card, so you must specify AXCLRTExecutionProvider.
Host
python3 ax_infer.py --model-path AX650/yolov8s-seg_640x640_npu3.axmodel --test-img bus.jpg --providers AXCLRTExecutionProvider
[YOLOv8-Seg] [10:51:49.774] [DEBUG] Load model time = 635.89 ms
[YOLOv8-Seg] [10:51:49.801] [DEBUG] Pre-process time = 5.27 ms
[YOLOv8-Seg] [10:51:49.840] [DEBUG] Forward time = 38.11 ms
[YOLOv8-Seg] [10:51:49.846] [DEBUG] Post-process time = 5.90 ms
[YOLOv8-Seg] [10:51:49.847] [DEBUG] Proto shape: (32, 160, 160)
[YOLOv8-Seg] [10:51:49.883] [INFO] Draw Results (5 objects):
[YOLOv8-Seg] [10:51:49.883] [INFO] (51, 398, 243, 903) -> person: 0.89
[YOLOv8-Seg] [10:51:49.922] [INFO] (221, 407, 345, 860) -> person: 0.88
[YOLOv8-Seg] [10:51:49.931] [INFO] (669, 393, 809, 879) -> person: 0.88
[YOLOv8-Seg] [10:51:49.937] [INFO] (24, 228, 799, 751) -> bus: 0.86
[YOLOv8-Seg] [10:51:49.953] [INFO] (0, 545, 76, 874) -> person: 0.74
[YOLOv8-Seg] [10:51:49.969] [INFO] Saved to result_yolov8_seg.jpg
[INFO] SOC Name: AX650N
[INFO] Compiler version: 6.0-dirty a498e20d-dirty
yolov8-seg demo output
