DX-COM model compiler
Introduction​
DX-COM (model compiler) generates an NPU instruction set based on the provided ONNX model and configuration file, compiling the ONNX model into the DXNN model format executable on the NPU. A DXNN file contains the generated instruction set and weight information.
System requirements​
CPUx86(x64)
Memory (RAM)≥ 16GB
Storage≥ 8GB
OSUbuntu 18.04, 20.04, 22.04 (x64)
LDD version≥ 2.28
Installation​
Install required libraries​
  • libgl1-mesa-glx
  • libglib2.0-0
Use the following command to install the required libraries.
X86 PC
sudo apt-get install -y --no-install-recommends libgl1-mesa-glx libglib2.0-0 make
Download the DX-COM package​
Download the DX-COM package from the DX-M1 / DX-M1M SDK Downloads page and extract it.
DEEPX Developers is open for public registration. After registering and logging in, you can download all SDK software from S/W Download.
X86 PC
tar -xvf dx_com_M1_v2.1.0.tar.gz
Usage​
Model configuration​
Parameters used for model compilation must be configured in a JSON file.
Model input configuration​
Specify the ONNX model input names and input shapes.
inputs : ONNX input name shape info
Example:
"inputs": {
"input.1": [ # ONNX input's name
1, # Batch Size(MUST BE SET AS 1)
3, # ONNX input's shape
512,
512
Model calibration configuration​
Configure the calibration method parameters.
calibration_num: Number of images used for calibration.
To minimize accuracy degradation, try different values of calibration_num. You can compile the model with different settings (such as calibration_num=1, 5, 10, 100, or 1000), measure the accuracy for each setting, and choose the value that yields the best accuracy.
calibration_method: Calibration method.
Options: ["ema", "minmax"]
In most cases, "ema" provides better accuracy, but in some cases "minmax" may work better.
Example:
"calibration_num": 100,
"calibration_method": "ema",
Data loader configuration​
Configure calibration dataset parameters. It is recommended to use the same dataset that will be used for training or inference for calibration.
  • dataset_path: Root directory path of the calibration dataset (files will be searched recursively).
  • file_extensions: File extensions of target images.
  • preprocessings: Image preprocessing methods.
Example:
"default_loader": {
"dataset_path": "/datasets/ILSVRC2012/",
"file_extensions": [
"jpeg",
"jpg",
"png",
"JPEG"
"preprocessings":
...continued in next step...
Input image preprocessing configuration
The preprocessing pipeline required before feeding images into the ONNX model. These configurations are used to preprocess the calibration dataset during model compilation. Items marked with (*) will be executed on the NPU side to reduce CPU workload. Therefore, preprocessing operations offloaded to the NPU should be omitted in the runtime software. If preprocessing is not needed, you can skip this section.
Preprocessing itemParameter/sub-optionDescriptionExample
convertColorRGB2BGR, BGR2RGB, BGR2GRAY, BGR2YCrCbConvert color channel order"RGB2BGR"
resizemodedefault (opencv) or torchvision"default" / "torchvision"
width, heightTarget image size (default mode only)width: 224, height: 224
sizeTarget short-side length (torchvision mode only)size: 256
interpolationInterpolation method (optional)
default mode: "NEAREST", "LINEAR"(default), "AREA", "CUBIC", "LANCZOS4"
torchviion mode:
"NEAREST", "LANCZOS", "BILINEAR"(default), "BICUBIC", "BOX", "HAMMING"
LINEAR, BILINEAR
centercropwidth, heightCrop the image from the center to the specified sizewidth: 224, height: 224
transposeaxisDimension transpose order[2, 0, 1]
normalize (*)mean, stdNormalization; supports scalar or arrays[0.5,0.5,0.5]
mul (*)xMultiply all pixels by a valuex: 255
add (*)xAdd a value to all pixelsx: 0.1
subtract (*)xSubtract a value from all pixelsx: 0.1
div (*)xDivide all pixels by a valuex: 255.0
expandDimaxisExpand a dimension at the specified positionaxis: 0
info
Items marked with (*) will be executed on the NPU side.
Model configuration example​
"preprocessings": [               # Set pre-processings for Inference in order.
"convertColor": {
"form": "BGR2RGB" # Color Converter Format
"resize": { # Resize Size
"mode": "default", # can be omitted (default)
"width": 380,
"height": 380 # this resize makes image shape into (380, 380, 3)
"centercrop": { # Center crop the image
"width": 320,
"height": 320 # this centercrop makes image shape into (320, 320, 3)
"div": { # Division parameter
"x": 255
"normalize": { # mean, std for Normalization.
"mean": [ # Dimension: 3D or single Value
0.486, # 3D: [0.486, 0.456, 0.406]
0.456, # single Value: [0.456] or 0.456
0.406
"std": [
0.229,
0.224,
0.225
"transpose": { # Transpose(permute) Axis Parameter
"axis": [ # ex) HWC -> CHW : [2,0,1]
2,
0,
1
"expandDim": { # Expand Dimension
"axis": 0
Accuracy enhancement scheme configuration​
To further improve model accuracy, you can choose to use an Enhanced Scheme named DXQ-P0 ~ DXQ-P5.
  • Each scheme is independent, so you can enable multiple schemes at the same time.
  • These schemes do not necessarily improve accuracy in every case. Evaluate the effect based on your actual workload.
  • Enabling these schemes in a CPU-only environment can significantly increase compilation time.
SchemeNameParameter description
DXQ-P0Fusing operationsalpha: fusion ratio, range 0 < alpha < 1.0, recommended: 0.5
DXQ-P1Search optimal parameterstrue/false. Enabling this will significantly increase CPU compilation time
DXQ-P2Relax calibration range to search optimal parametersalpha: min ratio of calibration range, 0 < alpha < beta, recommended: 0.1; beta: max ratio of calibration range, alpha < beta < ∞, recommended: 1.0
DXQ-P3Parameter fine-tuning (method 1)num_samples: number of samples used for calibration, 0 < num_samples < ∞, recommended: 1024
DXQ-P4Parameter fine-tuning (method 2)Same as DXQ-P3
DXQ-P5Parameter fine-tuning (method 3)Same as DXQ-P3
DXQ-P3, DXQ-P4, and DXQ-P5 use the same parameters, but apply different fine-tuning methods.
Enhanced scheme configuration example
  "enhanced_scheme": {
"DXQ-P0": {
"alpha": 0.5
"DXQ-P1": true,
"DXQ-P2": {
"alpha": 0.1,
"beta": 1,
"cosim_num": 2
"DXQ-P3": {
"num_samples": 1024
"DXQ-P4": {
"num_samples": 1024
"DXQ-P5": {
"num_samples": 1024
Enhanced scheme single-switch configuration example
"DXQ-P0": false, # this line can be remove for not using 'DXQ-P0' scheme
"DXQ-P1": false,
"DXQ-P2": false,
"DXQ-P3": true, # only 'DXQ-P3' scheme works
"DXQ-P4": false,
"DXQ-P5": false
NameCompile speedLikelihood of accuracy improvement
DXQ-P0Very fastLow
DXQ-P1FastLow-Medium
DXQ-P2SlowMedium-High
DXQ-P3Very slowHigh
DXQ-P4Very slowHigh
DXQ-P5Very slowHigh
PPU post-processing acceleration​
PPU (Post-Processing Unit) provides hardware-accelerated post-processing for object detection models. If your model uses a YOLO-family architecture, you can add PPU configuration parameters to the model compilation config file.
Supported PPU types​
There are two object detection model architectures that support PPU.
  • Type 0 (Anchor-Based YOLO)
    Designed for anchor-based models such as YOLOv3, YOLOv4, YOLOv5, and YOLOv7.
  • Type 1 (Anchor-Free YOLO)
    Designed for anchor-free models such as YOLOX.
Identify ONNX nodes that can use PPU​
Trace back from the model outputs and locate the output heads where the Conv output shape is [1, num_anchors*(5+num_classes), H, W]. After these conv layers, reshape, permute, and other post-processing operations are typically applied.
Take yolo5s.onnx as an example. For yolov5s, num_anchors is 3 and num_classes is 80, so you should find Conv nodes with a [1, 255, H, W] output feature. By tracing back from the model outputs, you can identify the three Conv nodes: Conv_196, Conv_308, and Conv_420, and configure these node names in the PPU section of the compilation config file.
Yolov5s PPU Conv node
"ppu": {
"type":0,
"conf_thres":0.25,
"activation": "Sigmoid",
"num_classes": 80,
"layer": {
"Conv_196": {
"num_anchors": 3
"Conv_308": {
"num_anchors": 3
"Conv_420": {
"num_anchors": 3
Parameter description​
ParameterTypeDescription
typeintModel type identifier. Set to 1 for Anchor-Free YOLO models
conf_thresfloatConfidence threshold for filtering detection results.
Note: This value is fixed at compile time and cannot be changed at runtime.
num_classesintNumber of object categories supported by the model
layerlistDetection layer configuration list. Each element corresponds to one detection head and contains the following fields:
layer.bboxstringLayer name that outputs bounding box coordinates (Bounding Box)
layer.obj_confstringLayer name that outputs object confidence (Object Confidence)
layer.cls_confstringLayer name that outputs class confidence (Class Confidence)
Run model compilation​
After completing the model configuration file, use the following command to compile the model.
X86 PC
dx_com  -m <MODEL_PATH> -c <CONFIG_PATH> -o <OUTPUT_DIR>
-m or --model_path <MODEL_PATH>: Path to Onnx Model[*.onnx]
-c or --config_path <CONFIG_PATH>: Path to Model Config[*.json]
-o or –output_dir <OUTPUT_PATH>: Path to Output Data Save Directory
(optional) --shrink : only including compiled model to run NPU
Compilation example​
The sample directory under dx-com contains multiple example compilation configuration files.
X86 PC
$./dx_com/dx_com    \
-m sample/MobilenetV1.onnx \
-c sample/MobilenetV1.json \
-o output/mobilenetv1
# shrink option
$./dx_com/dx_com \
-o output/mobilenetv1 \
--shrink
DX-COM only supports models with batch size 1. If your model input shape is (batchsize,C,H,W) or (batchsize,H,W,C), make sure batchsize is 1.
After successful compilation, the DXNN model will be saved under the output/mobilenetv1 directory.
Build DX-COM documentation​
For more details on how to use DX-COM, build the full documentation and refer to it.
Clone the DX-ALL-SUITE repository​
Follow DX-ALL-SUITE to clone the specified version of the DX-ALL-SUITE repository.
Install MkDocs​
Host
pip install mkdocs mkdocs-material mkdocs-video pymdown-extensions mkdocs-with-pdf markdown-grid-tables
Build the docs​
Host
cd dx-all-suite/dx-compiler
mkdocs build
After the build finishes, DEEPX_DX-COM_UM_v2.1.0_Nov_2025.pdf will be generated in the current directory.
Serve the docs​
You can access the documentation website in a browser.
Host
mkdocs serve
