DX Model Zoo
DX Model Zoo provides a collection of pre-compiled DXNN models for tasks such as image classification, object detection, image segmentation, face recognition, and image denoising. Each model includes the original model source, the ONNX model, the compiled DXNN model, downloadable compilation configuration files, and related data such as benchmarks and accuracy.
Link: DX Model Zoo
DX Model Zoo
Installation​
info
DX-Model-Zoo is only supported on x86 Ubuntu 20.04 LTS or 22.04 LTS.
Clone the DX-ALL-SUITE repository​
Follow DX-ALL-SUITE to clone the specified version of the DX-ALL-SUITE repository.
Install DXMZ (Deepx Model Zoo)​
Manual installation​
Enter the dx-all-suite/dx-modelzoo directory.
X86 Ubuntu PC
cd dx-all-suite/dx-modelzoo
./install.sh
After installation, a virtual environment named ./venv-dx-modelzoo-local will be created in the current directory.
X86 Ubuntu PC
source ./venv-dx-modelzoo-local/bin/activate
CLI usage​
List models​
Command:
dxmz models
Description: List models available in Deepx Model Zoo.
X86 Ubuntu PC
dxmz models
Evaluate model accuracy​
Command:
dxmz eval <model_name> [--onnx <path> | --dxnn <path>] --data_dir <dataset_path>
Description: Measure the accuracy of a specified model.
# To use onnx runtime:
dxmz eval <Model Name> --onnx <onnx file path> --data_dir <dataset root dir path>
# Example:
dxmz eval ResNet18 --onnx ./ResNet18.onnx --data_dir ./datasets/ILSVRC2012/val
# To use DX-Runtime:
dxmz eval <Model Name> --dxnn <dxnn file path> --data_dir <dataset root dir path>
# Example:
dxmz eval ResNet18 --dxnn ./ResNet18.dxnn --data_dir ./datasets/ILSVRC2012/val
Build DX-Model-Zoo documentation​
For more details on how to use DX-Model-Zoo, build the full documentation and refer to it.
Install MkDocs​
X86 Ubuntu PC
pip install mkdocs mkdocs-material mkdocs-video pymdown-extensions mkdocs-with-pdf markdown-grid-tables
Build the docs​
X86 Ubuntu PC
cd docs
mkdocs build
After the build finishes, dx-modelzoo_v0.1.0.pdf will be generated under output_web.
Serve the docs​
You can access the documentation website in a browser.
X86 Ubuntu PC
mkdocs serve
