DXRT-NPU-Driver
DXRT-NPU-Driver is the driver for Radxa AIcore DX-M1 / DX-M1M. Install this driver on the host machine that has AIcore DX-M1 / DX-M1M installed.
Installation​
Check hardware connectivity​
Follow Hardware installation to install AIcore DX-M1 / DX-M1M.
Host
lspci
0001:11:00.0 Processing accelerators: DEEPX Co., Ltd. DX_M1 (rev 01)
On some systems, the device name is not shown, and you may see the following output instead:
0b:00.0 1200: 1ff4:0000
Install system dependencies​
Host
sudo apt install git gcc g++ cmake ninja-build python3-dev python3-venv kmod libncurses5-dev libncursesw5-dev
Clone the DX-ALL-SUITE repository​
Follow DX-ALL-SUITE to clone the specified version of the DX-ALL-SUITE repository.
Install the driver​
Enter the dx-all-suite/dx-runtime/dx_rt_npu_linux_driver/modules directory.
Host
cd dx-all-suite/dx-runtime/dx_rt_npu_linux_driver/modules
There are three ways to install DXRT-NPU-Driver. Choose any one of them:
  • Install via a deb package
  • Build using the script
  • Build using the Makefile
Install via a deb package​
Host
sudo apt install ./release/latest/dxrt-driver-dkms_1.8.0-2_all.deb
Build using the script​
Build dx-npu-driver using the build.sh script.
Host
sudo ./build.sh -d m1 -m deepx -c install
 Usage:
build.sh <options>
options:
-d, --device [device] select target device: m1 v3
-m, --module [module] select PCIe module: deepx
-k, --kernel [kernel dir] 'KERNEL_DIR=[kernel dir]', The directory where the kernel source is located
default: /lib/modules/6.1.84-7-rk2410/build)
-a, --arch [arch] set 'ARCH=[arch]' Target CPU architecture for cross-compilation, default: aarch64
-t, --compiler [cross tool] 'CROSS_COMPILE=[cross tool]' cross compiler binary, e.g aarch64-linux-gnu-
-i, --install [install dir] 'INSTALL_MOD_PATH=[install dir]', module install directory
install to: [install dir]/lib/modules/[KERNELRELEASE]/extra/
-c, --command [command] clean | install | uninstall
- uninstall: Remove the module files installed on the host PC.
-j, --jops [jobs] set build jobs
-f, --debug [debug] set debug feature [debugfs | log | all]
-v, --verbose build verbose (V=1)
-h, --help show this help
Reboot the host.
Host
sudo reboot
Build using the Makefile​
Build dx-npu-driver with make.
Host
sudo make DEVICE=m1 PCIE=deepx install
Configure the driver to load on boot.
Host
sudo depmod -A
sudo cp dx_dma.conf /etc/modprobe.d/
Reboot the host
Host
sudo reboot
Check driver status​
Host
lsmod | grep dx
rock@rock-5b-plus:~$ lsmod | grep dx
dxrt_driver 45056 2
dx_dma 483328 9 dxrt_driver
Uninstall​
Uninstall (deb package)​
Host
sudo apt remove dxrt-driver-dkms
Uninstall (script build)​
Host
./build.sh -d m1 -m deepx -c uninstall
