DX-RT runtime
DX-RT (runtime software) is the runtime used to interact with DEEPX NPU hardware. It provides pre-processing and post-processing during inference and manages NPU inputs and outputs. DX-RT supports running inference with DXNN models compiled by DX-COM.
Installation​
Clone the DX-ALL-SUITE repository​
Follow DX-ALL-SUITE to clone the specified version of the DX-ALL-SUITE repository.
Build DX-RT​
Enter the dx-all-suite/dx-runtime/dx_rt directory.
Host
cd dx-all-suite/dx-runtime/dx_rt
Create a Python virtual environment​
This virtual environment is used to install the DXRT Python API. You can create a Python virtual environment in any directory.
Host
python3 -m venv .venv
source .venv/bin/activate
pip3 install --upgrade pip
Install required dependencies​
Host
./install.sh --all
Usage: ./install.sh [OPTIONS]
Install necessary components and libraries for the project.
System Requirements:
• Architecture: x86_64 or aarch64
• RAM: 8GB or more
Options:
--help Display this help message and exit.
--arch <ARCH> Specify the target CPU architecture. Valid options: [x86_64, aarch64].
--dep Install core dependencies such as cmake, gcc, ninja, etc and python3.
--onnxruntime (Optional) Install the ONNX Runtime library.
--all Install all dependencies and the ONNX Runtime library.
--python_version <VERSION> Specify the Python version to install (e.g., 3.10.4).
* Minimum supported version: .
* If not specified:
- For Ubuntu 20.04+, the OS default Python 3 will be used.
- For Ubuntu 18.04, Python will be source-built.
--venv_path <PATH> Specify the path for the virtual environment.
* If this option is omitted, no virtual environment will be created.
Build and install DX-RT​
The DX-RT installation script will automatically install the dx-engine Python API.
Host
./build.sh --install /usr/local
Register the dxrt-service service​
DX-RT supports background multi-threaded operations. To enable multi-threading, you need to register dxrt-service.
Host
sudo cp ./service/dxrt.service /etc/systemd/system
sudo systemctl start dxrt.service
sudo systemctl enable dxrt.service
Install the DX-RT Python library​
Host
cd python_package
pip3 install .
Uninstall DX-RT​
Host
./build.sh --uninstall
Usage​
dxrt-cli​
dxrt-cli can read Radxa AIcore DX-M1 / DX-M1M device status. Source file: dx_rt/cli/dxrt-cli.cpp
dxrt-cli <option> <argument>
OptionDescription
-s, --statusGet device status information
-i, --infoGet detailed device information
-m, --monitor <seconds>Monitor device status at the specified interval (seconds)
-r, --reset <option>Reset device:
0 - reset NPU only (default)
1 - reset the entire device
-d, --device <device_id>Specify device ID to run the command. If omitted, the command will be sent to all devices (default: -1)
-u, --fwupdate <firmware_file>Update firmware using a DeepX firmware file. Sub-options:
force - force update
unreset - do not reset the device (default will reset)
-g, --fwversion <firmware_file>Read firmware version info from the specified DeepX firmware file
-C, --fwconfig_json <json_file>Update firmware settings from a JSON file
-v, `--versionPrint the minimum required versions for driver, firmware, and model compiler
-h, --helpShow help and usage
Examples​
Check Radxa AIcore DX-M1 / DX-M1M device status​
Host
dxrt-cli -s
rock@rock-5b-plus:~$ dxrt-cli -s
DXRT v3.1.0
* Device 0: M1, Accelerator type
--------------------- Version ---------------------
* RT Driver version : v1.8.0
* PCIe Driver version : v1.6.0
* FW version : v2.4.0
--------------------- Device Info ---------------------
* Memory : LPDDR5 5600 Mbps, 3.92GiB
* Board : M.2, Rev 1.0
* Chip Offset : 0
* PCIe : Gen3 X2 [17:00:00]
NPU 0: voltage 750 mV, clock 1000 MHz, temperature 41'C
NPU 1: voltage 750 mV, clock 1000 MHz, temperature 41'C
NPU 2: voltage 750 mV, clock 1000 MHz, temperature 41'C
Reset Radxa AIcore DX-M1 / DX-M1M NPU​
Host
dxrt-cli --reset
rock@rock-5b-plus:~$ dxrt-cli --reset
DXRT v3.1.0
Device 0 reset by option 0
Host
dxrt-cli -m 1
rock@rock-5b-plus:~$ dxrt-cli -m 1
DXRT v3.1.0
====================== Device 0 =======================
NPU 1: voltage 750 mV, clock 1000 MHz, temperature 40'C
NPU 2: voltage 750 mV, clock 1000 MHz, temperature 40'C
Update Radxa AIcore DX-M1 / DX-M1M firmware​
info
If the DX-M1 / DX-M1M firmware version is lower than v2.4.0, please upgrade to v2.4.0. Use dxrt-cli -s to check the current firmware version.
The latest firmware is hosted in the dx-fw repository. Upgrade carefully.
Host
cd dx-all-suite/dx-runtime/dx_fw
View firmware file version information
Host
dxrt-cli -g m1/latest/mdot2/fw.bin
rock@rock-5b-plus:~/dx-all-suite/dx-runtime/dx_fw$ dxrt-cli -g m1/latest/mdot2/fw.bin
DXRT v3.1.0
fwFile:m1/latest/mdot2/fw.bin
============ FW Binary Information ============
Signature : DEEPX GENESIS-M
Board Type : M.2
DDR Type : LPDDR5
Firmware Ver: 2.4.0
Update DX-M1 / DX-M1M firmware
Host
dxrt-cli -u m1/latest/mdot2/fw.bin
parse_model​
parse_model parses a DXNN model and prints detailed model information.
Source file: dx_rt/cli/parse_model.cpp
parse_model -m <dxnn_model_path>
OptionDescription
-m, --model FILEDXNN model path (required)
-v, --verboseShow detailed task dependencies and memory usage
-o, --output FILESave output to a file
-j, --jsonSave binary data (graph_info, rmap_info) in JSON format
Host
parse_model -m ResNet50-1.dxnn
rock@rock-5b-plus:/mnt/ssd/deepx/v2.1.0/model_zoo_v2.1.0$ parse_model -m ResNet50-1.dxnn
===================== Model Information ======================
Model File Path : ResNet50-1.dxnn
.dxnn Format Version : v7
DX-COM Version : v2.0.0-rc-20250814
Model Input Tensors:
- input.1
Model Output Tensors:
- 495
Model Memory Usage:
- Total : 34.79 MB (36,477,760 bytes)
- Buffers : 10.11 MB (10,604,544 bytes)
- NPU Tasks Count : 1
- Buffer Pool Size : x6
================== Task Graph Information ====================
-------------------- Task Dependencies -----------------------
npu_0 [NPU] (model input) (model output)
---------------------- Task Details --------------------------
Task[0]: npu_0 [NPU] (model input) (model output)
+- Inputs:
| +- input.1
+- Outputs:
+- 495
run_model​
run_model runs inference on a DXNN model, measures inference time, and checks model outputs. It can be used to benchmark DXNN models.
Source file: dx_rt/cli/run_model.cpp
OptionDescription
-b, --benchmarkRun benchmark
-s, --singleRun a single test
-v, --verboseShow NPU processing time and latency
-n, --npu argNPU core (default: 0)
-l, --loops argNumber of inference loops (default: 30)
-t, --time argInference duration (seconds)
-w, --warmup-runs argNumber of warmup runs (default: 0)
-d, --devices argSpecify NPU devices (default: all)
-f, --fps argTarget FPS
--use-ortEnable ONNX Runtime to execute the CPU operator graph
Host
run_model -m ./ResNet50-1.dxnn -b -l 100 -v
rock@rock-5b-plus:/mnt/ssd/deepx/v2.1.0/model_zoo_v2.1.0$ run_model -m ./ResNet50-1.dxnn -b -l 100 -v
Runtime Framework Version: v3.1.0
Device Driver Version: v1.8.0
PCIe Driver Version: v1.6.0
--- CPU Information ---
Architecture: aarch64
CPU(s): 8
Vendor ID: ARM
Model name: -
--- Architecture Information ---
System Name: Linux
Node Name: rock-5b-plus
Release: 6.1.84-7-rk2410
Version: #7 SMP Wed Jun 18 13:39:58 UTC 2025
Machine: aarch64
--- Memory Information ---
Total Physical Memory: 7.75 GB
Available Physical Memory: 6.30 GB
Total Swap Space: 3.88 GB
Free Swap Space: 3.88 GB
modelFile: ./ResNet50-1.dxnn
inputFile:
outputFile: output.bin
benchmark: 1
loops: 100
Device specification: 'all' (default)
Run model target mode : Benchmark Mode
Inference by loops: count=100
=== Model File: /mnt/ssd/deepx/v2.1.0/model_zoo_v2.1.0/ResNet50-1.dxnn ===
- input.1
- 495
Tasks:
[ ] -> npu_0 -> []
Task[0] npu_0, NPU, NPU memory usage 36477760 bytes (input 150528 bytes, output 4000 bytes)
Inputs
- input.1, UINT8, [1, 224, 224, 3 ]
Outputs
- 495, FLOAT, [1, 1000 ]
* Benchmark Result (100 inputs)
- NPU Processing Time Average : 2.900 ms (Actual NPU core computation time for a single request)
- Latency Average : 6.415 ms (End-to-end time per request including data transfer and overheads)
- FPS : 915.25 (Overall user-observed inference throughput (inputs/second), reflecting perceived speed)
dxtop​
dxtop is a DEEPX device status monitoring tool. It monitors each NPU status in real time, including NPU memory usage, per-core utilization, temperature, voltage, and frequency.
Host
dxtop
[DX-TOP]  (q) Quit   (n) Next Page   (p) Prev Page   (h) Help
Thu Dec 25 07:24:04 2025
DX-RT: v3.1.0 NPU Device driver: v1.8.0 DX-TOP: v1.0.1
Device :0 Variant: M1 PCIe Bus Number: 17:00:00 Firmware: v2.4.0
NPU Memory: [ ] 3.56 KiB / 3.92 GiB (0.00%)
Core :0 Util: 0.0% Temp: 41 °C Voltage: 750 mV Clock: 1000 MHz
Core :1 Util: 0.0% Temp: 40 °C Voltage: 750 mV Clock: 1000 MHz
Core :2 Util: 0.0% Temp: 40 °C Voltage: 750 mV Clock: 1000 MHz
C++/Python example code​
DXRT C++/Python example code is available under the cpp and python directories in dx-all-suite/dx-runtime/dx_rt/examples.
├── CMakeLists.txt
├── cpp
│   ├── check_versions
│   │   ├── check_versions.cpp
│   │   └── CMakeLists.txt
│   ├── CMakeLists.txt
│   ├── display_async_models_1
│   │   ├── CMakeLists.txt
│   │   └── display_async_models_1.cpp
│   ├── display_async_models_2
│   │   └── display_async_models_2.cpp
│   ├── display_async_pipe
│   │   ├── concurrent_queue.h
│   │   ├── display_async_pipe.cpp
│   │   └── simple_circular_buffer_pool.h
│   ├── display_async_thread
│   │   └── display_async_thread.cpp
│   ├── display_async_wait
│   │   ├── display_async_wait.cpp
│   ├── include
│   │   └── logger.h
│   ├── multi_input_model_inference
│   │   ├── multi_input_model_inference.cpp
│   │   └── README_multi_input_model_inferenece.md
│   ├── run_async_model
│   │   └── run_async_model.cpp
│   ├── run_async_model_bound
│   │   └── run_async_model_bound.cpp
│   ├── run_async_model_conf
│   │   └── run_async_model_conf.cpp
│   ├── run_async_model_output
│   │   ├── run_async_model_output.cpp
│   ├── run_async_model_profiler
│   │   └── run_async_model_profiler.cpp
│   ├── run_async_model_thread
│   │   └── run_async_model_thread.cpp
│   ├── run_async_model_wait
│   │   └── run_async_model_wait.cpp
│   ├── run_batch_model
│   │   └── run_batch_model.cpp
│   ├── run_sync_model
│   │   └── run_sync_model.cpp
│   ├── run_sync_model_bound
│   │   └── run_sync_model_bound.cpp
│   └── run_sync_model_output
│   ├── run_sync_model_output.cpp
└── python
├── logger.py
├── multi_input_model_inference.py
├── run_async_model_callback.py
├── run_async_model_conf.py
├── run_async_model_profiler.py
├── run_async_model.py
├── run_async_model_thread.py
├── run_async_model_wait.py
├── run_batch_model.py
├── run_sync_model_bound.py
└── run_sync_model.py
C++ API reference manual​
The C++ API reference manual can be built with Doxygen.
Host
sudo apt install doxygen graphviz
Host
cd dx-all-suite/dx-runtime/dx_rt/docs/cpp_api
doxygen Doxyfile
The API manual will be saved under ./html and ./latex. You can open ./html/index.html in a browser to view it.
Build DX-RT documentation​
For more details on how to use DX-RT and the DX-RT Python API, build the full documentation and refer to it.
Install MkDocs​
Host
pip install mkdocs mkdocs-material mkdocs-video pymdown-extensions mkdocs-with-pdf markdown-grid-tables
Build the docs​
Host
cd docs
mkdocs build
After the build finishes, DEEPX_DX-APP_UM_v2.1.0.pdf will be generated in the current directory.
Serve the docs​
You can access the documentation website in a browser.
Host
mkdocs serve
