Hardware installation
This guide explains how to install AIcore DX-M1 / DX-M1M onto a host board.
Installation notes
AIcore DX-M1 / DX-M1M uses an M.2 M Key connector, and must be installed into the host board's M.2 M Key slot.
Install the module​
Install AIcore DX-M1 / DX-M1M with the power disconnected. Do not install AIcore DX-M1 / DX-M1M while the system is powered on.
Pre-install AIcore DX-M1 / DX-M1M​
Tilt the M.2 M Key edge of AIcore DX-M1 at an angle (about 15 degrees), align it with the host board's M.2 M Key slot, and gently insert it.
Secure the module​
After confirming AIcore DX-M1 is properly pre-installed, press the other end down and secure it to the host board using a screw.
Thermal notes​
Radxa AIcore DX-M1 / DX-M1M can generate significant heat under load. To ensure proper cooling, we recommend active cooling or passive cooling using a metal enclosure (see 2.1 for an example active cooler).
Installation example​
Radxa AIcore DX-M1 with a metal enclosure: Make sure the thermal pads on both sides are positioned symmetrically to avoid uneven stress that could deform the module.
