40-PIN Functional Testing
GPIO
GPIO Introduction
General Purpose Inputs/Outputs (GPIOs) are non-dedicated digital signal pins on the circuit board of an integrated circuit or electronic circuit (e.g., MCU/MPU) that can be used as inputs or outputs, or both, and can be controlled by software.
Preparations
- One Radxa CM3 IO
- One LED
Connection
Connecting PIN_3 of Radxa CM3 IO as shown
Test
Input Tests
Ground 3 or connect to 3.3V,
radxa@radxa-cm3-io:~$ gpioget gpiochip0 14
This command outputs 0 if ground is connected and 1 if 3.3V is connected.
Output Test
radxa@radxa-cm3-io:~$ sudo gpioset -m signal $(sudo gpiofind PIN_3)=0 # Output low, Led off radxa@radxa-cm3-io:~$ sudo gpioset -m signal $(sudo gpiofind PIN_3)=1 # Output high, Led on
The same GPIO cannot be used by two processes at the same time, otherwise it will indicate resource usage. Therefore, you need to wait for the first command to finish executing before you can execute the second command.
I2C
I2C 简介
I2C (Inter-Integrated Circuit; pronounced "eye-squared-see" or "eye-two-see"), also known as I2C or IIC, is a synchronous, multi-controller/multi-destination (historically known as master/slave), single-ended, serial communications bus invented by Philips Semiconductors in 1982.
Preparations
- One Radxa CM3 IO
- One OLED
Enable Overlay
Please refer to Device Tree Configuration to enable I2C Related Overlay, eg: "Enable I2C2".
Connection
Connect Radxa CM3 IO and OLED as follows
Radxa CM3 IO | <--> | OLED |
PIN_5 | <--> | SCL |
PIN_3 | <--> | SDA |
PIN_1 | <--> | VCC |
PIN_9 | <--> | GND |
Test
Open a terminal and install the Python library python3-periphery by typing the following command in the terminal
Create a new Python file called Oled.py and paste the following code into it:
Oled.py
from periphery import I2C
import time
I2C_ADDR = 0x3c
I2C_BUS = "/dev/i2c-8"
i2c = I2C(I2C_BUS)
# SSD1306 init_cmds
init_cmds = [
0xAE, # Display off
0xB0, # Set page address
0x81, # Set contrast control
0xCF,
0xA1, # Set segment remap
0xA6, # Normal display
0xA8, # Set multiplex ratio
0x3F,
0xD3, # Set display offset
0x00,
0x80,
0xD9, # Set pre-charge period
0xF1,
0x12,
0x40,
0x14,
0xAF # Display on
for cmd in init_cmds:
def oled_clear():
for page in range(8):
for _ in range(128):
char_map = {
def string_to_bytes(string):
bytes_list = []
for char in string:
bytes_list.extend(char_map.get(char, [0x00] * 4))
bytes_list.append(0x00)
return bytes_list
oled_clear()
i2c.close()
This script is only an example, you need to modify the variable I2C_BUS according to the actual situation.
- In a terminal, execute the following command to test
sudo python3 Oled.py
After executing the above command, Oled will display the characters "Hello, Radxa".
One Wire
One Wire Introduction
The 1-wire bus is a simple master-slave bus that communicates via a single signal wire (plus ground, so two wires).
Preparation
- One Radxa CM3 IO Board
- One One-Wire Sensor
开启 Overlay
Please refer to Device Tree configurationEnable One Wire Related Overlay, eg: "Enable Enable 1-Wire on GPIO3_D1"。
Connection
Connect Radxa CM3 IO Board and One Wire device as follows
Radxa CM3 IO Board | <--> | One Wire |
PIN_40 | <--> | One Wire Pin |
Test
After booting up the Radxa CM3 IO Board, check the /sys/bus/w1/devices/ directory - there should be a device starting with '28-'
Create a new file called 'w1_test.py', then copy and paste the following code into that file and save it
w1_test.py
import os
import glob
import time
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
#open the file /sys/bus/w1/devices/28*/w1_slave
base_dir = '/sys/bus/w1/devices/'
device_folder = glob.glob(base_dir + '28*')[0]
device_file = device_folder + '/w1_slave'
# read the file line by line
def read_temp_raw():
f = open(device_file, 'r')
lines = f.readlines()
f.close()
return lines
#6e 01 ff ff 7f ff ff ff ae : crc=ae YES
#6e 01 ff ff 7f ff ff ff ae t=22875
def read_temp():
lines = read_temp_raw()
while lines[0].strip()[-3:] != 'YES':
time.sleep(0.2)
equals_pos = lines[1].find('t=')
if equals_pos != -1:
temp_string = lines[1][equals_pos+2:]
temp_c = float(temp_string) / 1000.0
temp_f = temp_c * 9.0 / 5.0 + 32.0
return temp_c, temp_f
# (Celsius, Fahrenheit)
while True:
print(read_temp())
time.sleep(1) -
Run the program
sudo python3 w1_test.py
If the program runs correctly, it will output the current temperature.
PWM
PWM Introduction
Pulse Width Modulation (PWM) is a modulation technique that produces variable width pulses to represent the amplitude of an analog input signal. For high amplitude signals, the output switching transistor is on more of the time, while for low amplitude signals, the output switching transistor is off more of the time.
Preparations
- One Radxa CM3 IO
- One LED
Enable Overlay
Please refer to DeviceTree configuration to enable PWM-related Overlay.
eg: "Enable PWM1-M0.
Connection
As shown in the picture,connect Radxa CM3 IO's 15
Test
- Open a terminal and install the Python library for python3-periphery by typing the following command in the terminal
sudo apt-get install python3-periphery
- Create a new Python file called Pwm_led_test.py and paste the following code into the file:
Pwm_led_test.py
#!/usr/bin/env python3
# -- encoding: utf-8 --
from periphery import PWM
import time
step = 0.05
Range = int(1/0.05)
pwmchip = int(input("pwmchip:"))
channel = int(input("channel:"))
pwm = PWM(pwmchip, channel)
try:
pwm.frequency = 1e3
pwm.duty_cycle = 0.00
pwm.enable()
while True:
for i in range(0,Range):
time.sleep(step)
pwm.duty_cycle = round(pwm.duty_cycle+step,2)
if pwm.duty_cycle == 1.5:
time.sleep(1.5)
time.sleep(step)
pwm.duty_cycle = round(pwm.duty_cycle-step,2)
except:
print("Error !\n")
finally:
pwm.duty_cycle = 1.0
pwm.close()
radxa@radxa-cm3-io:~$ sudo python3 Pwm_led_test.py pwmchip:1 channel:0
After executing the above commands, Led will have a gradient effect (dark to light, light to dark).
SPI
Introduction to SPI
The Serial Peripheral Interface (SPI) is the de facto standard for synchronous serial communication (there are many variants), primarily used for short-range wired communication between integrated circuits in embedded systems.
Preparation
- One radxa-cm3-io
- One female-to-female Dupont wire
Enable Overlay
Please refer to Device Tree configuration Enable SPIDEV Related Overlay, eg: "Enable spidev on SPI3-M1 over CS0"。
Connection
Short 19 and 21 as shown
Test
- Open a terminal and enter the following command in the terminal to install the compilation tool
sudo apt-get install build-essential
- Create a new C file called spidev_test.c and paste the following code into the file:
spidev_test.c
* SPI testing utility (using spidev driver)
* Copyright (c) 2007 MontaVista Software, Inc.
* Copyright (c) 2007 Anton Vorontsov <[email protected]>
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License.
* Cross-compile with cross-gcc -I/path/to/cross-kernel/include
#include <stdint.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <getopt.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/ioctl.h>
#include <sys/stat.h>
#include <linux/types.h>
#include <linux/spi/spidev.h>
static void pabort(const char *s)
perror(s);
abort();
static const char *device = "/dev/spidev0.0";
static uint32_t mode;
static uint8_t bits = 8;
static char *input_file;
static char *output_file;
static uint16_t delay;
static int verbose;
uint8_t default_tx[] = {
0xFF FF FF FF FF FF,
0x40 00 00 00 00 95,
0xF0 0D,
char *input_tx;
char *prefix)
int i = 0;
unsigned char c;
printf("%s | ", prefix);
while (length-- > 0) {
printf("%02X ", *address++);
if (length == 0) {
while (i++ % line_size)
printf("__ ");
while (line < address) {
c = *line++;
printf("\n");
if (length > 0)
* Unescape - process hexadecimal escape character
* converts shell input "\x23" -> 0x23
static int unescape(char *_dst, char *_src)
int ret = 0;
int match;
char *src = _src;
char *dst = _dst;
unsigned int ch;
while (*src) {
if (!match)
src += 4;
*dst++ = (unsigned char)ch;
} else {
*dst++ = *src++;
ret++;
return ret;
int ret;
int out_fd;
.tx_buf = (unsigned long)tx,
.rx_buf = (unsigned long)rx,
.len = len,
.delay_usecs = delay,
.speed_hz = speed,
.bits_per_word = bits,
if (mode & SPI_TX_QUAD)
tr.tx_nbits = 4;
else if (mode & SPI_TX_DUAL)
tr.tx_nbits = 2;
if (mode & SPI_RX_QUAD)
tr.rx_nbits = 4;
else if (mode & SPI_RX_DUAL)
tr.rx_nbits = 2;
if (!(mode & SPI_LOOP)) {
tr.rx_buf = 0;
tr.tx_buf = 0;
if (ret < 1)
if (verbose)
hex_dump(tx, len, 32, "TX");
if (output_file) {
if (out_fd < 0)
ret = write(out_fd, rx, len);
if (ret != len)
close(out_fd);
if (verbose || !output_file)
hex_dump(rx, len, 32, "RX");
static void print_usage(const char *prog)
" -d --delay delay (usec)\n"
" -b --bpw bits per word\n"
" -l --loop loopback\n"
" -H --cpha clock phase\n"
" -O --cpol clock polarity\n"
" -2 --dual dual transfer\n"
exit(1);
static void parse_opts(int argc, char *argv[])
while (1) {
{ "device", 1, 0, 'D' },
{ "speed", 1, 0, 's' },
{ "delay", 1, 0, 'd' },
{ "bpw", 1, 0, 'b' },
{ "input", 1, 0, 'i' },
{ "output", 1, 0, 'o' },
{ "loop", 0, 0, 'l' },
{ "cpha", 0, 0, 'H' },
{ "cpol", 0, 0, 'O' },
{ "lsb", 0, 0, 'L' },
{ "cs-high", 0, 0, 'C' },
{ "3wire", 0, 0, '3' },
{ "no-cs", 0, 0, 'N' },
{ "ready", 0, 0, 'R' },
{ "dual", 0, 0, '2' },
{ "verbose", 0, 0, 'v' },
{ "quad", 0, 0, '4' },
{ NULL, 0, 0, 0 },
int c;
lopts, NULL);
if (c == -1)
break;
switch (c) {
case 'D':
device = optarg;
break;
case 's':
speed = atoi(optarg);
break;
case 'd':
delay = atoi(optarg);
break;
case 'b':
bits = atoi(optarg);
break;
case 'i':
input_file = optarg;
break;
case 'o':
output_file = optarg;
break;
case 'l':
mode |= SPI_LOOP;
break;
case 'H':
mode |= SPI_CPHA;
break;
case 'O':
mode |= SPI_CPOL;
break;
case 'L':
mode |= SPI_LSB_FIRST;
break;
case 'C':
mode |= SPI_CS_HIGH;
break;
case '3':
mode |= SPI_3WIRE;
break;
case 'N':
mode |= SPI_NO_CS;
break;
case 'v':
verbose = 1;
break;
case 'R':
mode |= SPI_READY;
break;
case 'p':
input_tx = optarg;
break;
case '2':
mode |= SPI_TX_DUAL;
break;
case '4':
mode |= SPI_TX_QUAD;
break;
default:
print_usage(argv[0]);
break;
if (mode & SPI_LOOP) {
mode |= SPI_RX_DUAL;
mode |= SPI_RX_QUAD;
size_t size = strlen(str);
uint8_t *tx;
uint8_t *rx;
tx = malloc(size);
if (!tx)
rx = malloc(size);
if (!rx)
transfer(fd, tx, rx, size);
free(rx);
free(tx);
ssize_t bytes;
struct stat sb;
int tx_fd;
uint8_t *tx;
uint8_t *rx;
if (tx_fd < 0)
tx = malloc(sb.st_size);
if (!tx)
rx = malloc(sb.st_size);
if (!rx)
if (bytes != sb.st_size)
free(rx);
free(tx);
close(tx_fd);
int main(int argc, char *argv[])
int ret = 0;
int fd;
parse_opts(argc, argv);
fd = open(device, O_RDWR);
if (fd < 0)
pabort("can't open device");
* spi mode
if (ret == -1)
pabort("can't set spi mode");
if (ret == -1)
pabort("can't get spi mode");
* bits per word
if (ret == -1)
if (ret == -1)
* max speed hz
if (ret == -1)
if (ret == -1)
if (input_tx && input_file)
if (input_tx)
else if (input_file)
else
close(fd);
return ret;
- View added spidev devices
ls /dev/spidev*
- Modify the line
static const char *device = ‘/dev/spidev0.0’;
according to the actual spidev device.
For example, if the actual spidev is /dev/spidev1.0, then static const char *device = ‘/dev/spidev1.0’;
- In a terminal, compile by typing the following command
gcc spidev_test.c
- In the terminal, enter the following command to test
sudo ./a.out
- Check the output
If the output is consistent with default_tx (if the output is consistent with the following), then the spi loopback test was successful
spi mode: 0x0
bits per word: 8
