U-boot Development
Using bsp
bsp is a set of tools provided by Radxa to quickly build U-Boot Kernels. It is very easy to build your own U-Boot and Kernel using bsp.
Below is an example of how to build a U-Boot with bsp, using the Radxa CM3 as an example.
bsp environment configuration
The following is the recommended environment for bsp
Hardware: x86_64 PC recommended
System: Ubuntu or Debian
installs dependencies
# Podman (recommended)
# Docker
# sudo apt install docker.io
# Optional dependencies for minor features
Getting the code
bsp
uses the git submodule. Therefore, use the following command to get the code:
Understanding bsp
usage
Once you have the bsp
code on your machine, you can run bsp
to see the built-in help:
cd bsp
. /bsp
Build U-Boot
After configuring the bsp environment, you need to compile U-Boot once before pulling U-Boot code from the repository. Running . /bsp will show you all the parameters and their explanations, and you can see the command "bsp [options] <linux|u-boot> <profile> [product]" from the prompt. Taking Radxa CM3 as an example, the U-Boot profile is **latest**. The following are profiles for other products: | Model | profile | | :--------------: | :-----: | | Radxa ROCK 5A | rknext | | Radxa ROCK 5B | rknext | | Radxa ROCK 5C | rknext | | Radxa ROCK 5 ITX | rknext | | Radxa ROCK 3A | latest | | Radxa ROCK 3B | latest | | Radxa ROCK 3C | latest | | Radxa CM3 Series| latest | | Radxa CM3I Series| latest | | Radxa ROCK PI S | latest | Then fill in the profile parameter of the bsp command with the corresponding product profile **latest** e.g. ". /bsp u-boot latest radxa-cm3-io" to build U-Boot. The path to the U-Boot source code is located in ".src/u-boot" in the bsp directory. After modifying the U-Boot source code, you can build U-Boot again:
cd bsp . /bsp --no-prepare-source u-boot latest radxa-cm3-io Parameter description: --no-prepare-source # Compile with local changes, without this parameter the latest code will be synchronized from the Radxa U-Boot repository and overwrite the local changes.
For more information on how to use the bsp parameter, you can run . /bsp
After compilation, many deb
packages will be generated in the current directory, you just need to install the following deb
packages.
u-boot-latest_2023.10-1_arm64.deb
Copy the above two deb
packages to the board and install them with the dpkg
command to complete the U-Boot installation.
sudo dpkg -i u-boot-latest_2023.10-1_arm64.deb
After the installation is complete, you need to flash U-Boot to the boot media
cd /usr/lib/u-boot/radxa-cm3-io/ sudo . /setup.sh update_bootloader /dev/mmcblk1 #/dev/mmcblk1 is your current boot media, you need to select it according to the actual device you are using. sudo reboot
After reboot, you can observe the U-Boot boot log to see if U-Boot has been updated successfully.
Compile manually
bsp
is the only compilation method currently being maintained, and it makes additional changes to the source code when compiling.
If you want to build on our official releases, you should at least use bsp
to download and configure the code.
If you want to build with a custom make
command, please refer to the Prepare working tree section to configure the code.
