Radxa CM3J + Raspberry Compute Module 4 IO Board
Preparation
  • Radxa CM3J Core Board + Raspberry Pi Compute Module 4 IO Base Board
cm3j
  • To start the Radxa CM3J + Raspberry Pi Compute Module 4 IO Board, the following items are also required:
    • DC 12V/3A Adapter.
    • An HDMI cable and a display that supports HDMI, with a recommended resolution of 1080P or higher. A 4K display will provide the best experience.
    • A set of USB mouse and keyboard, with common USB input devices supporting plug-and-play.
    • An Ethernet cable, as an internet connection is required for system updates.
It is recommended to use the official power adapter Power DC12 36W
Assembly
First, align the four mounting holes on the core board with the four mounting holes on the io board. Then, gently press down one side to about halfway, followed by pressing the other side to halfway as well. After confirming that all slots are aligned, press down each side to the bottom in sequence.
Note: When pressing, do not forcefully press down on the suspended area in the middle, as this may cause stress on the PCB, leading to component loosening or damage, such as DDR loosening or resistor breakage.
Precautions
Choose Boot Method
Please refer to the Install System section to choose the method for booting your system according to your needs.
Wiring and Powering On
  1. Insert the SD card with the operating system flashed (using SD card boot as an example).
cm3j sdcard
  1. Connect the HDMI0 output port of the Raspberry Pi Compute Module 4 IO Board to an HDMI display using an HDMI cable.
cm3j hdmi
  1. Connect the USB mouse and keyboard to any USB 2.0 port on the Raspberry Pi Compute Module 4 IO Board.
cm3j usb
  1. Connect the Ethernet cable to the Ethernet port.
cm3j ethernet
  1. Plug the power adapter into the power interface of the Raspberry Pi Compute Module 4 IO Board. When the device is powered on, the green power indicator on the core board will light up.
cm3j pwr
The system takes approximately 40 seconds to boot up after powering on. Once the system successfully starts, the green indicator light on the core board will change from a steady light to a blinking state.
LogIn to the System
After the system boots, the HDMI display shows the desktop.
cm3j login
Log in using the username radxa and the password radxa.
