MediaPipe Example
This document provides examples of MediaPipe's face detection, hand detection, pose detection, holistic detection, background segmentation, and 3D object detection features.
Face Detection
This example captures video from the camera, detects faces, and draws bounding boxes around them.
To run this example:
- Create a new file named
face_detection.py
- Copy the following code into
face_detection.py
- Run the example with
python3 face_detection.py
- Click on the preview window and press 'q' to quit
face_detection.py
#!/usr/bin/env python3
# -_- encoding: utf-8 -_-
import cv2
import mediapipe as mp
mp_face_detection = mp.solutions.face_detection
mp_drawing = mp.solutions.drawing_utils
cap = cv2.VideoCapture(0)
with mp_face_detection.FaceDetection(
model_selection=0, min_detection_confidence=0.5) as face_detection:
while cap.isOpened():
success, image = cap.read()
if not success:
print("Ignoring empty camera frame.") # If loading a video, use 'break' instead of 'continue'.
continue
# To improve performance, optionally mark the image as not writeable to
# pass by reference.
image.flags.writeable = False
image = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)
results = face_detection.process(image)
# Draw the face detection annotations on the image.
image.flags.writeable = True
image = cv2.cvtColor(image, cv2.COLOR_RGB2BGR)
if results.detections:
for detection in results.detections:
mp_drawing.draw_detection(image, detection)
# Flip the image horizontally for a selfie-view display.
cv2.imshow('MediaPipe Face Detection', cv2.flip(image, 1))
break
cap.release()
cv2.destroyAllWindows()
Preview:
Face Mesh
This example captures video from the camera, detects faces, and applies a mesh overlay on detected faces.
face_mesh.py
face_mesh.py
python3 face_mesh.py
face_mesh.py
import cv2
mp_drawing_styles = mp.solutions.drawing_styles
mp_face_mesh = mp.solutions.face_mesh
drawing_spec = mp_drawing.DrawingSpec(thickness=1, circle_radius=1)
with mp_face_mesh.FaceMesh(
max_num_faces=1,
refine_landmarks=True,
min_detection_confidence=0.5,
min_tracking_confidence=0.5) as face_mesh:
if not success:
continue
results = face_mesh.process(image)
# Draw the face mesh annotations on the image.
if results.multi_face_landmarks:
for face_landmarks in results.multi_face_landmarks:
mp_drawing.draw_landmarks(
image=image,
landmark_list=face_landmarks,
connections=mp_face_mesh.FACEMESH_TESSELLATION,
landmark_drawing_spec=None,
connection_drawing_spec=mp_drawing_styles
.get_default_face_mesh_tessellation_style())
image=image,
connections=mp_face_mesh.FACEMESH_CONTOURS,
.get_default_face_mesh_contours_style())
image=image,
connections=mp_face_mesh.FACEMESH_IRISES,
.get_default_face_mesh_iris_connections_style())
cv2.imshow('MediaPipe Face Mesh', cv2.flip(image, 1))
break
cap.release()
Preview:
Hand Detection
Read the camera image and perform hand detection, drawing the skeleton on the detected hand.
Run the example steps:
hand_detection.py
- Copy the code into
hand_detection.py
python3 hand_detection.py
hand_detection.py
import cv2
mp_hands = mp.solutions.hands
with mp_hands.Hands(
model_complexity=0,
min_tracking_confidence=0.5) as hands:
if not success:
continue
results = hands.process(image)
# Draw the hand annotations on the image.
if results.multi_hand_landmarks:
for hand_landmarks in results.multi_hand_landmarks:
image,
hand_landmarks,
mp_hands.HAND_CONNECTIONS,
mp_drawing_styles.get_default_hand_landmarks_style(),
mp_drawing_styles.get_default_hand_connections_style())
cv2.imshow('MediaPipe Hands', cv2.flip(image, 1))
break
cap.release()
Preview:
骨骼检测
读取摄像头画面并进行人体检测,在检测出来的人体上绘制骨骼。
pose_detection.py
pose_detection.py
python3 pose_detection.py
pose_detection.py
import cv2
mp_pose = mp.solutions.pose
with mp_pose.Pose(
min_tracking_confidence=0.5) as pose:
if not success:
continue
results = pose.process(image)
# Draw the pose annotation on the image.
image,
results.pose_landmarks,
mp_pose.POSE_CONNECTIONS,
landmark_drawing_spec=mp_drawing_styles.get_default_pose_landmarks_style())
cv2.imshow('MediaPipe Pose', cv2.flip(image, 1))
break
cap.release()
Preview:
Holistic Detection
Read the camera image and perform holistic detection, drawing the skeleton and mask on the detected human body.
holistic_detection.py
python3 holistic_detection.py
import cv2
mp_holistic = mp.solutions.holistic
with mp_holistic.Holistic(
min_tracking_confidence=0.5) as holistic:
if not success:
continue
results = holistic.process(image)
# Draw landmark annotation on the image.
image,
results.face_landmarks,
mp_holistic.FACEMESH_CONTOURS,
image,
mp_holistic.POSE_CONNECTIONS,
cv2.imshow('MediaPipe Holistic', cv2.flip(image, 1))
break
cap.release()
Preview:
Background Segmentation
Read the camera image and perform background segmentation, replacing the background with a solid color.
back_seg.py
back_seg.py
python3 back_seg.py
back_seg.py
import cv2
import numpy as np
mp_selfie_segmentation = mp.solutions.selfie_segmentation
BG_COLOR = (192, 192, 192) # gray
with mp_selfie_segmentation.SelfieSegmentation(
model_selection=1) as selfie_segmentation:
bg_image = None
if not success:
continue
# Flip the image horizontally for a later selfie-view display, and convert
# the BGR image to RGB.
image = cv2.cvtColor(cv2.flip(image, 1), cv2.COLOR_BGR2RGB)
results = selfie_segmentation.process(image)
# Draw selfie segmentation on the background image.
# To improve segmentation around boundaries, consider applying a joint
# bilateral filter to "results.segmentation_mask" with "image".
condition = np.stack(
(results.segmentation_mask,) * 3, axis=-1) > 0.1
# The background can be customized.
# a) Load an image (with the same width and height of the input image) to
# be the background, e.g., bg_image = cv2.imread('/path/to/image/file')
# b) Blur the input image by applying image filtering, e.g.,
# bg_image = cv2.GaussianBlur(image,(55,55),0)
if bg_image is None:
bg_image = np.zeros(image.shape, dtype=np.uint8)
bg_image[:] = BG_COLOR
output_image = np.where(condition, image, bg_image)
cv2.imshow('MediaPipe Selfie Segmentation', output_image)
break
cap.release()
Preview:
3D Object Detection
Read the camera feed and perform 3D object detection (supports four models: shoe, chair, cup, and camera), then draw 3D bounding boxes around the detected objects.
3d_object_detection.py
python3 3d_object_detection.py
# -_- coding: utf-8 -_-
import cv2
# Initialize MediaPipe components
mp_objectron = mp.solutions.objectron
# Available models
MODELS = ['Shoe', 'Chair', 'Cup', 'Camera']
current_model = 0 # Start with first model
# Initialize video capture
# Create initial Objectron instance
objectron = mp_objectron.Objectron(
static_image_mode=False,
max_num_objects=5,
min_tracking_confidence=0.99,
model_name=MODELS[current_model]
if not success:
continue
# Process image
results = objectron.process(image)
# Draw results
if results.detected_objects:
for detected_object in results.detected_objects:
image, detected_object.landmarks_2d, mp_objectron.BOX_CONNECTIONS)
mp_drawing.draw_axis(image, detected_object.rotation,
detected_object.translation)
# # First flip the image for display
# image = cv2.flip(image, 1)
# Then add text to the already-mirrored image
# Note: We adjust the x-position to account for mirroring
text_x = image.shape[1] - 200 # Right side position
cv2.putText(image, f"Model: {MODELS[current_model]}", (text_x, 30),
cv2.FONT_HERSHEY_SIMPLEX, 0.7, (0, 255, 0), 2)
# Show final view
cv2.imshow('MediaPipe Objectron', image)
# Key handling
key = cv2.waitKey(5) & 0xFF
if key == 27 or key == ord('q'): # ESC or 'q' to quit
break
elif key == ord('f'): # 'f' for next model
current_model = (current_model + 1) % len(MODELS)
max_num_objects=5,
print(f"Switched to model: {MODELS[current_model]}")
cap.release()
Preview:
