ROS2 Install
This document provides a guide for setting up the ROS2 Humble environment.
- It is recommended to perform the following operations using VNC remote desktop or a connected display.
- The ROS2 environment is set up in a Docker container. It is recommended to install and learn how to use Docker first.
- Ubuntu is the officially preferred and primarily supported distribution for ROS2. We will set up the ROS2 environment using a Docker Ubuntu image.
Pull Docker Image
Use the docker pull
command to download the Ubuntu 22.04 Docker image.
docker pull ubuntu:22.04
Create Docker Script
Start an Ubuntu 22.04 Docker container using a script.
You need to create a startup script named ros_humble.sh
vi ros_humble.sh
Add the following content to the script:
#!/bin/bash
xhost +
docker run -it \
--net=host \
--env="DISPLAY" \
--env="QT_X11_NO_MITSHM=1" \
ubuntu:22.04 /bin/bash
Parameter explanation:
xhost +
: Allows Docker container to access the X11 server-it
: Run the container in interactive mode--net=host
: Use the host's network stack--env="DISPLAY"
: Set environment variable for X11 graphical interface display--env="QT_X11_NO_MITSHM=1"
: Set environment variable for Qt application display-v /tmp/.X11-unix:/tmp/.X11-unix
: Mount X11 Unix domain socket for X11 graphical interface displayubuntu:22.04
: Use Ubuntu 22.04 image/bin/bash
: Start Bash shell inside the container
Start Docker Container
Use the bash
command to run the script.
bash ros_humble.sh
Install Humble
Check Encoding Environment
Ensure the environment for installing Humble supports UTF-8 encoding.
locale
If the system encoding format is UTF-8, you should see output similar to the following in the terminal:
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_ALL=
If the terminal output is not UTF-8 encoding, you can install and modify the encoding environment by running the following commands in the terminal:
locale-gen en_US en_US.UTF-8
source ~/.bashrc
Set up Software Sources and Keys
Ensure your system is up to date, then enable the Ubuntu Universe repository and add the ROS2 key.
apt-cache policy | grep universe
apt install software-properties-common curl -y
add-apt-repository universe
curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg
If you encounter the error: curl: (7) Failed to connect to raw.githubusercontent.com port 443 after 43 ms: Connection refused
Solution: Visit https://www.ipaddress.com/
and search for raw.githubusercontent.com
, then add the IP address to your /etc/hosts file.
vi /etc/hosts
Add the following line:
Then run the ROS2 key addition command again:
Add the repository to your sources list:
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] http://packages.ros.org/ros2/ubuntu $(. /etc/os-release && echo $UBUNTU_CODENAME) main" | tee /etc/apt/sources.list.d/ros2.list > /dev/null
Install Humble
Use the following command to install the full desktop version of Humble:
apt update && apt upgrade
apt install ros-humble-desktop-full -y
Install ROS2 Development Tools
Use the following command to install ROS2 development tools:
apt install ros-dev-tools -y
Set Environment Variables
Set up the environment variables with the following commands:
echo "source /opt/ros/humble/setup.bash" >> ~/.bashrc
source ~/.bashrc
Save Docker Image
Currently, our modifications are based on the Ubuntu22.04 Docker container. We need to save this modified container as an image for future use.
Note: If you don't save it as an image, you'll need to reinstall the ROS environment the next time you start a container.
View Running Containers
In a new terminal on Cubie A7A (not inside the Docker container), run the following command to view running containers:
docker ps
Commit Container as Image
In a new terminal on Cubie A7A (not inside the Docker container), run the following command to commit the container as a new image.
You'll need to modify the command based on the container ID from the docker ps
output.
docker commit [CONTAINER ID] [NEW NAME]
# Example
docker commit 937a98f8ad9e ros_humble:1.0
After the commit is complete, it will output similar information:
sha256:32288d439ffab73505d0754d4c43d8aad83210441b41553118e81ff6ab2887af
Modify Start Script
Modify the ros_humble.sh
script to use the saved image name:
#!/bin/bash
xhost +
docker run -it \
--net=host \
--env="DISPLAY" \
ros_humble:1.0 /bin/bash
