Docker Install
Docker Installation
The Radxa Debian system has Docker-related configurations enabled in the kernel. You only need to install the Docker application to start using it.
Currently, users in China cannot access Docker Hub directly. You need to configure a Docker mirror source or use a proxy for access.
Features of Docker
  • Easy Management
Lightweight containerization technology. Use Docker commands to manage containers and images, isolate dependencies, and simplify deployment processes.
  • Cross-Platform
Supports Windows, macOS, and Linux systems, allowing containers to run and deploy on various platforms.
  • Portability
Ensures consistent environments through Dockerfiles and images, making it easy to migrate and deploy quickly on different machines or cloud platforms.
  • Efficient Resource Utilization
Based on containerization technology, Docker shares the host kernel, resulting in low resource usage and fast startup speeds, making it ideal for microservices architectures.
Install Docker
Enter the following commands in the terminal to install Docker:
sudo apt install docker.io
Configure iptables
Restart the system for the Docker configuration to take effect.
Verify Installation
docker --version
Add Access Permissions
Enter the following command in the terminal to grant the current system user access to the Docker daemon. This allows you to use Docker commands without needing sudo.
sudo usermod -aG docker $USER
