Using an M.2 NVMe SSD Enclosure
This guide explains how to install the system onto an NVMe SSD using an M.2 NVMe SSD enclosure.
warning
Installing the system will format the NVMe SSD. Please back up any important data in advance!
Prerequisites
Hardware Requirements
You will need the following hardware devices:
  • M.2 NVMe SSD enclosure
  • Bootable storage medium: M.2 NVMe SSD
Hardware Connection
Install the M.2 NVMe SSD into the M.2 NVMe SSD enclosure, then connect the enclosure to your computer.
System Installation
Download System Image
Use a PC to access the Resource Downloads page and download the system image file locally.
Image Note
Install System Image
You can use Balena Etcher software to install the system image onto the M.2 NVMe SSD.
Balena Etcher
For Balena Etcher installation and usage instructions, please refer to the Etcher Guide tutorial.
Select System Image
Click the Flash from file option and select the system image file you have downloaded and extracted.
Selecting system image in Etcher
Select Storage Device
Click the Select target option and choose your M.2 NVMe SSD device.
Selecting target device in Etcher - Step 1
Selecting target device in Etcher - Step 2
Start Flashing
Click the Flash! option to begin writing the system image to the M.2 NVMe SSD.
Starting the flashing process in Etcher
Wait for the system installation to complete
Etcher flashing progress
Wait for the system verification to complete
Etcher validation in progress
Etcher flash completed successfully
