Hardware Information
Chip Block Diagram
Rockchip RK3576 Block Diagram
System Block Diagram
CM4 System Block Diagram
Interface Information
CM4 Module Interface Diagram
No.DescriptionNo.DescriptionNo.DescriptionNo.Description
LPDDR4X RAMSoC: Rockchip RK3576(J)Antenna ConnectorOnboard eMMC
Maskrom ButtonSPI FlashWiFi/BT Chip3x 100 Pin B2B Connectors
Power Indicator
When powering the Radxa CM4 with a power adapter, the power indicator (red) on the CM4 IO Board will light up, indicating normal power supply.
The CM4's indicator will light up green when powered on. After the system runs normally, it will turn off for a few seconds, then blink in sync with the user indicator (green) on the CM4 IO Board.
User Indicator
The user indicator (green) on the Radxa CM4 blinks to indicate normal system operation.
