Radxa Camera 13M 214
Radxa Cubie A5E's onboard MIPI CSI interface can be used to connect the Radxa Camera 13M 214 for image capture.
Interface specifications​
Camera interface​
The Radxa Camera 13M 214 interface has the following specifications:
Board MIPI CSI interface​
The Radxa Cubie A5E MIPI CSI interface has the following specifications:
  • Connector type: 31-Pin 0.3 mm pitch SMD horizontal FPC connector
Camera FPC cable​
Hardware connection​
Notes
Software enablement​
Use the Rsetup tool provided by the Radxa system to enable the Radxa Camera 13M 214.
Rsetup usage guide
radxa@cubie-a5e$
rsetup
  1. Use the arrow keys to find the [ ] Enable Radxa Camera 13M 214 option.
  2. Press Space so it changes to [*] Enable Radxa Camera 13M 214, indicating that the feature is enabled.
If the board has multiple MIPI CSI interfaces, Rsetup may show options such as [ ] Enable Radxa Camera 13M 214 on CAM *. Select the option corresponding to the MIPI CSI interface you are using.
Install GStreamer​
radxa@cubie-a5e$
sudo apt-get update
Preview the camera​
Use GStreamer to preview the camera image.
radxa@cubie-a5e$
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video0 en-awisp=1 en-largemode=0 ! video/x-raw,format=I420,width=1920,height=1080,framerate=30/1 ! xvimagesink
radxa@cubie-a5e$
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video1 en-awisp=1 en-largemode=1 ! video/x-raw,format=I420,width=3840,height=2160,framerate=30/1 ! xvimagesink
radxa@cubie-a5e$
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video1 en-awisp=1 en-largemode=1 ! video/x-raw,format=I420,width=4208,height=3120,framerate=30/1 ! xvimagesink
