Radxa Camera 8M 219
Radxa Cubie A5E's onboard MIPI CSI interface can be used to connect the Radxa Camera 8M 219 for image capture.
Interface specifications​
Camera interface​
The Radxa Camera 8M 219 interface has the following specifications:
  • Connector type: 15-pin 1.0 mm pitch SMD Horizontal FPC connector
Board MIPI CSI interface​
The Radxa Cubie A5E MIPI CSI interface has the following specifications:
  • Connector type: 31-Pin 0.3 mm pitch SMD horizontal FPC connector
Camera FPC cable​
Use a 15-Pin 1.0 mm pitch to 31-Pin 0.3mm pitch same side FPC cable.
Hardware connection​
Insert the 15-pin metal contacts of the FPC cable into the camera connector, and insert the 31-Pin metal contacts of the FPC cable into the board MIPI CSI connector.
Notes
Software enablement​
Use the Rsetup tool provided by the Radxa system to enable the Radxa Camera 8M 219.
Rsetup usage guide
radxa@cubie-a5e$
rsetup
  1. Use the arrow keys to find the [ ] Enable Radxa Camera 8M 219 option.
  2. Press Space so it changes to [*] Enable Radxa Camera 8M 219, indicating that the feature is enabled.
If the board has multiple MIPI CSI interfaces, Rsetup may show options such as [ ] Enable Radxa Camera 8M 219 on CAM *. Select the option corresponding to the MIPI CSI interface you are using.
Install GStreamer​
radxa@cubie-a5e$
sudo apt-get update
Preview the camera​
Use GStreamer to preview the camera image.
radxa@cubie-a5e$
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video0 en-awisp=1 en-largemode=0 ! video/x-raw,format=I420,width=1920,height=1080,framerate=30/1 ! xvimagesink
radxa@cubie-a5e$
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video0 en-awisp=1 en-largemode=0 ! video/x-raw,format=I420,width=3280,height=2464,framerate=30/1  ! xvimagesink
