Radxa 10-inch Display
Radxa Cubie A5E's onboard MIPI DSI interface can be used to connect the Radxa 10-inch Display for video output.
Interface Specifications​
Display Interface​
The Radxa 10-inch Display interface specifications are as follows:
  • Interface type: 40-Pin 0.5 mm pitch SMD horizontal FPC connector
  • Connection method: Flip-lock, bottom contact
Board MIPI DSI Interface​
Radxa Cubie A5E's board MIPI DSI interface specifications are as follows:
  • Interface type: 39-Pin 0.3 mm pitch SMD horizontal FPC connector
Display FPC Cable​
Uses a 40-Pin 0.5 mm pitch to 39-Pin 0.3mm pitchopposite side FPC cable
Hardware Connection​
Insert the 40-Pin metal contact end of the FPC cable into the display interface, and insert the 39-Pin metal contact end of the FPC cable into the board's MIPI DSI interface.
Precautions
  • Ensure both cable edges are flush with the socket edges, with no skew or partially exposed contacts
  • Confirm the cable has no creases, is not loose, and the lock is in the closed position
Software Enable​
Use the Rsetup tool included with the Radxa system to enable the Radxa 10-inch Display.
Rsetup Usage Guide
  • Select option: Corresponding option will be highlighted
  • Confirm selection: Press Enter
  • Cancel selection: Press ESC
  • Switch options: Use Up, Down, Left, Right keys to navigate
  • Multi-select interface: Press Space to select, press Enter to confirm selection; when a function is selected, an * will appear in the corresponding option box indicating the option is enabled
Run the rsetup command in the terminal to launch the Rsetup tool:
radxa@cubie-a5e$
rsetup
In the Rsetup tool, navigate to Overlays -> Manage overlays.
  1. Use arrow keys to locate the [ ] Enable Radxa Display 10FHD option
  2. Press Space to show [*] Enable Radxa Display 10FHD, indicating the feature is selected
  3. Press Enter to confirm and save the settings, enabling the display
  4. Restart the system to apply the configuration
