Use System
This guide explains how to use the system.
Booting the System​
After completing the system installation, install the boot media to the corresponding position on the motherboard, then power on the board using the power adapter to start the system.
Boot Priority
If you have multiple boot media installed on the motherboard, the system will boot from the media with the highest priority by default. To boot from a lower priority media, you can remove the higher priority boot media.
System Startup Priority: microSD Card > NVMe SSD > eMMC
System Information​
When using our provided system image for the first time, you will need to log in with the following default credentials:
  • Debian Linux
    • Username: radxa
    • Password: radxa
Using the System​
Here are some recommendations for users in both display and display-less modes to help you get started with our motherboard more easily.
With Display Mode​
Display mode refers to connecting the motherboard to a monitor using an HDMI cable, allowing you to view the system interface on the display and use a mouse and keyboard for graphical interface operations.
Headless Mode​
Headless mode refers to using the system without a monitor. Users are recommended to access and control the system through serial console login or SSH login.
