Hardware Interfaces
This section provides information about the board's hardware interfaces.
System Block Diagram​
Interface Description​
No.DescriptionNo.DescriptionNo.Description
①Wi-Fi / Bluetooth⑧PoE Header⑭LPDDR4 / LPDDR4x RAM
②Antenna Connector⑨Gigabit Ethernet (with PoE)⑮Allwinner A527 / T527
③USB 3.0 Type-A HOST⑩MIPI DSI⑯Onboard eMMC (Reserved)
④HDMI⑪microSD Card Slot⑰40-Pin GPIO Header
⑤SPI Flash⑫MIPI CSI⑱USB Type-C (5V Power & OTG)
⑥UBOOT Button⑬M.2 M Key 2230 Slot⑲Gigabit Ethernet (without PoE)
⑦Status LED
Onboard eMMC
If you have purchased the Cubie A5E model without onboard eMMC, the eMMC position on the motherboard will be reserved with no components installed.
  • Status LED Indicators
    • Solid Green: System power is normal
    • Blinking Blue: System has booted successfully
