40 Pin GPIO Interface
The Radxa Cubie A5E features an onboard 40-pin GPIO (General Purpose Input/Output) interface, providing highly flexible hardware expansion capabilities.
Users can connect various sensors, actuators, communication modules, displays, and other embedded peripherals through the 40-pin GPIO interface, enabling rapid prototyping and functional verification in fields such as IoT, robotics control, and industrial automation.
danger
When using the 40-pin GPIO interface, please pay attention to pin connections and peripheral wiring. Ensure all connections are correct, as improper operation may cause hardware damage to the device.
GPIO Features​
The Cubie A5E supports connecting external devices to its onboard GPIO pins, with support for UART, SPI, I2C, ADC, and more.
Function7Function6Function5Function4Function3Function2Function1Pin#Pin#Function1Function2Function3Function4Function5Function6Function7
+3.3V
1
2
+5.0V
PB-EINT5HDMI-SDAPWM0-9TRACE-CLKI2S0-BCLKTWI1-SDAPB5
3
4
+5.0V
PB-EINT4HDMI-SCLPWM0-8TRACE-DATA2I2S0-MCLKTWI1-SCKPB4
5
6
GND
PI-EINT7SPI2-CLKPWM0-8UART4-CTSUART6-RXPI7
7
8
PB9UARTO-TXTWIO-SCKTRACE-DATA1I2S0-DIN2I2S0-DOUBT2PB-EINT9
GND
9
10
PB10UARTO-RXTWIO-SDAPWM0-1I2S0-DIN3I2S0-DOUBT3PB-EINT10
PI-EINT9PWM0-10DMIC-DATA2TWI5-SDAPI9
11
12
PI2UART5-TXSPI1-CSOPWM0-3I2S2-BCLKI2S2-BCLKPI-EINT2
PI-EINT10I2S2-MCLKPWM0-11DMIC-DATA1OWA-OUTPI10
13
14
GND
S-PL-EINT12S-SPI0-MOSIDMIC-DATA2S-UART0-TXMCU-PWM0-6S-TWI2-SCKPL12
15
16
PI11UART3-TXDMIC-DATA0PWM0-12PI-EINT11
+3.3V
17
18
PI14UART6-RTSDMIC-CLKPWM0-15PI-EINT14
SPI1-MOSIPI-EINT13PWM0-4UART7-TXTWI4-SCKPB13
19
20
GND
PB-EINT14PWM0-5SPI1-MISOUART7-RXTWI4-SDAPB14
21
22
PL13S-TWI2-SDAMCU-PWM0-7S-UARTO-RXDMIC-DATA3S-SPI-MISOS-PL-EINT13
PB-EINT12PWM0-3SPI1-CLKUART7-CTSTWI5-SDAPB12
23
24
PB11TWI5-SCKUART7-RTSPWM0-2SPI1-CSOPB-EINT11
GND
25
26
PI0TWI4-SCKUART4-TXPWM0-1I2S2-DIN3I2S2-DOUBT3PI-EINTO
(USB2-DM)PI-EINT16PWM1-1TWI2-SDAUART3-CTSPI16
27
28
PI15TWI2-SCKUART3-RTSPWM1-0PI-EINT15(USB2-DM)
PI-EINT8SPI2-MOSIPWM0-9IR-RXTWI5-SCKPI8
29
30
GND
PI-EINT12SPI2-MISOPWM0-13UART3-RXPI12
31
32
PI1TWI4-SDAUART4-RXPWM0-2I2S2-DIN2I2S2-DOUBT2PI-EINT1
PI-EINT6SPI2-CSOPWM0-7UART6-TXUART4-RTSPI6
33
34
GND
PI-EINT13I2S2-MCLKPWM0-14DMIC-DATA3UART6-CTSPI13
35
36
PI3UART5-RXPWM0-4I2S2-LRCKSPI1-CLKPI-EINT3
GPADC2
37
38
PI5UART5-CTSSPI1-MISOPWM0-6I2S2-DINOI2S2-DOUBT1PI-EINT5
GND
39
40
PI4UART5-RTSSPI1-MOSIPWM0-5I2S2-DOUBT0I2S2-DIN1PI-EINT4
GPIO Pin Numbering​
To control a specific pin, you need to calculate the pin number using the following formula:
GPIO ChipPin NumberCalculation Formula
GPIOCHIP1A ~ KNUM + 32 * (A ~ K)
GPIOCHIP0L ~NUM + 32 * (L ~ )
Calculation Example:
  • PI4
GPIOCHIP1 -> 4 + 32 * (A ~ K) -> 4 + 32 * 8 -> 260
GPIO Usage​
Through the 40-Pin GPIO interface on the board, demonstrate common GPIO usage.
Install python-periphery​
Use python-periphery library to control GPIO pins.
radxa@cubie-a5e$
sudo pip3 install python-periphery
GPIO Input​
Hardware Preparation​
  • Board
  • Dupont wire
Software Preparation​
Test Code​
The following code uses the python-periphery library to read the high and low level of the PI4 pin.
gpio_input.py
from periphery import GPIO
import time
def read_gpio_input():
# Configure GPIO input (modify pin number according to actual hardware)
# Using pin 260 of /dev/gpiochip1 here (corresponds to PI4)
try:
# Initialize GPIO in input mode
gpio_in = GPIO("/dev/gpiochip1", 260, "in")
print("Starting GPIO input reading (press Ctrl+C to exit)")
while True:
# Read pin value
value = gpio_in.read()
print(f"GPIO input value: {value} (True=High, False=Low)")
time.sleep(1) # Read once per second
except KeyboardInterrupt:
print("\nProgram exited")
except Exception as e:
print(f"Error occurred: {e}")
finally:
# Ensure resources are released
try:
gpio_in.close()
except:
pass
if __name__ == "__main__":
read_gpio_input()
Test Steps​
  1. Connect the PI4 pin to the GND or 3.3V pin
  2. Save the code as gpio_input.py
  3. Run the test code using sudo python3 gpio_input.py
Experimental Phenomenon​
Terminal will output False or True information.
False represents low level, True represents high level.
GPIO Output​
  • Board
  • Dupont wire
Test Code​
The following code uses the python-periphery library to control PI4 pin output high and low level, then read the high and low level of PI4 pin through PI5 pin.
gpio_output.py
import time
# PI4 (output) → maps to pin 260 of /dev/gpiochip1
# PI5 (input) → maps to pin 261 of /dev/gpiochip1
OUTPUT_PIN_CHIP = "/dev/gpiochip1"
OUTPUT_PIN_NUMBER = 260 # PI4 (output pin, controlled by the script)
INPUT_PIN_NUMBER = 261 # PI5 (input pin, reads PI4's output state)
gpio_out = None
gpio_in = None
try:
# Initialize PI4 as OUTPUT mode
# Initialize PI5 as INPUT mode
print(f"Controlled Pin (PI4): {OUTPUT_PIN_CHIP} - Pin {OUTPUT_PIN_NUMBER} (OUTPUT)")
print(f"Monitoring Pin (PI5): {OUTPUT_PIN_CHIP} - Pin {INPUT_PIN_NUMBER} (INPUT)")
print("Test Behavior: PI4 toggles HIGH/LOW every 1s; PI5 verifies PI4's state")
# Main loop: Toggle PI4 and read PI5 feedback
while True:
# 1. Set PI4 to HIGH level
gpio_out.write(True)
pi5_reading = gpio_in.read()
print(f"PI4 Output: HIGH (True) | PI5 Reading: {pi5_reading}")
# Keep PI4 HIGH for 1 second
time.sleep(1)
# 2. Set PI4 to LOW level
gpio_out.write(False)
print(f"PI4 Output: LOW (False) | PI5 Reading: {pi5_reading}")
# Keep PI4 LOW for 1 second
time.sleep(1)
finally:
# Safely close PI4 (set to LOW first to avoid residual high level)
if gpio_out:
try:
gpio_out.close()
print(f"Successfully closed PI4 (Pin {OUTPUT_PIN_NUMBER})")
print(f"Failed to close PI4 (Pin {OUTPUT_PIN_NUMBER}): {str(close_err)}")
# Safely close PI5
if gpio_in:
try:
gpio_in.close()
print(f"Successfully closed PI5 (Pin {INPUT_PIN_NUMBER})")
print(f"Failed to close PI5 (Pin {INPUT_PIN_NUMBER}): {str(close_err)}")
Test Steps​
  1. Short the PI4 pin and PI5 pin
  2. Save the code as gpio_output.py
  3. Run the test code using sudo python3 gpio_output.py
PWM Output​
  • Board
  • LED
  • Dupont wire
Test Code​
The following code uses the python-periphery library to test PWM output.
pwm_output.py
from periphery import PWM
import time
def pwm_test():
try:
# Configure PWM parameters - modify according to your hardware
# Common PWM paths: /sys/class/pwm/pwmchip0/pwm0, etc.
PWM_CHIP = 0 # PWM chip number
PWM_CHANNEL = 7 # PWM channel number
# Initialize PWM
pwm = PWM(PWM_CHIP, PWM_CHANNEL)
print(f"PWM Test: Using PWM{PWM_CHIP}.{PWM_CHANNEL} (Pin: PI6)")
# Set PWM frequency to 1kHz
frequency = 1000 # 1000 Hz
pwm.frequency = frequency
print(f" Set frequency: {frequency} Hz")
# Enable PWM output
pwm.enable()
print(" PWM enabled")
# Test different duty cycles (0% to 100%)
duty_cycles = [0.0, 0.25, 0.5, 0.75, 1.0]
for duty in duty_cycles:
pwm.duty_cycle = duty
print(f" Set duty cycle: {duty*100:.1f}%")
time.sleep(1) # Maintain current duty cycle for 1 second
# Cleanup
pwm.disable()
pwm.close()
print(" PWM disabled and closed")
print("PWM Test completed successfully")
print(f"PWM Test failed: {e}")
print("Starting PWM Signal Test...\n")
pwm_test()
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable PWM0-7 option, then restart the system
  2. Connect the positive terminal of the LED to the PI6 pin
  3. Connect the negative terminal of the LED to the GND pin
  4. Save the code as pwm_output.py
  5. Run the test code using sudo python3 pwm_output.py
The external LED will flash with different brightness, from bright to dark.
UART Usage​
UART (Universal Asynchronous Receiver/Transmitter) is a widely used serial communication protocol, used for asynchronous serial data transmission between embedded systems, computers, and peripherals.
  • Board
  • Dupont wire
Test Code​
The following code uses the python-periphery library to test UART4 loopback communication.
uart_example.py
from periphery import Serial
import time
def uart_test():
try:
# Modify the serial device path according to your hardware, common paths include /dev/ttyS0, /dev/ttyS1, /dev/ttyUSB0, etc.
# PI11(TX) PI31(RX)
UART_DEVICE = "/dev/ttyAS3"
BAUDRATE = 115200
# Initialize serial port
serial = Serial(UART_DEVICE, BAUDRATE)
print(f"UART Test: Opening serial port {UART_DEVICE}, baud rate {BAUDRATE}")
# Send test data
test_message = "Hello, UART Test!\n"
serial.write(test_message.encode())
print(f" Sent data: {test_message.strip()}")
# Wait for data transmission
time.sleep(0.1)
# Try to read data (if loopback or other device responds)
if serial.input_waiting() > 0:
received_data = serial.read(serial.input_waiting())
print(f" Received data: {received_data.decode().strip()}")
else:
print(" No data received (normal unless loopback is connected)")
serial.close()
print("UART test completed")
print(f"UART test failed: {e}")
uart_test()
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable UART3 option, then restart the system
  2. Short the PI11 pin and PI31 pin
  3. Save the code as uart_example.py
  4. Run the test code using sudo python3 uart_example.py
Terminal will output sent and received information, and you can judge whether the UART loopback test is successful based on the terminal output information.
I2C Usage​
I2C (Inter-Integrated Circuit) is a widely used synchronous serial communication protocol developed by Philips (now NXP), mainly used for short-distance chip-to-chip communication.
  • Board
  • I2C device (e.g., OLED display, its corresponding I2C address is 0x3C)
  • Dupont wire
Test Code​
The following code uses the python-periphery library to test I2C communication.
i2c_example.py
from periphery import I2C
def i2c_device_detection():
"""I2C Test - Check if device exists
Pin reference: PB5 (SDA), PB4 (SCL)
# Modify according to your hardware connection
# Common I2C bus devices: /dev/i2c-0, etc.
I2C_BUS = "/dev/i2c-1"
TARGET_ADDR = 0x3C # Target address to check
i2c = None # Initialize I2C object reference
try:
i2c = I2C(I2C_BUS)
# Attempt a simple read/write operation to detect device
# Sending a single 0x00 byte as test communication
msgs = [I2C.Message([0x00])]
i2c.transfer(TARGET_ADDR, msgs)
print(f"I2C Test: Device found at address 0x{TARGET_ADDR:02X}")
return True
# Exception (e.g., IOError) usually indicates no device or no response
print(f"I2C Test: No device or no response at address 0x{TARGET_ADDR:02X}: {e}")
return False
finally:
# Ensure I2C resources are released
if i2c is not None:
try:
i2c.close()
except:
pass
print("Starting I2C Device Detection...")
print("I2C Test completed")
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable TWI1 option, then restart the system
  2. Connect the SCL pin of the OLED display to the PB4 pin, connect the SDA pin of the OLED display to the PB5 pin, connect the VCC to 5V, and connect the GND to GND
  3. Save the code as i2c_example.py
  4. Run the test code using sudo python3 i2c_example.py
The script function is to check if there is an I2C device that can respond to the specified I2C bus address, which can be used to determine if the I2C device is working normally.
SPI Usage​
SPI (Serial Peripheral Interface) is a high-speed, full-duplex, synchronous serial communication protocol developed by Motorola (now NXP), mainly used for short-distance chip-to-chip communication, commonly used in sensor, storage (like Flash), display, etc. device data transmission between microcontrollers.
  • Board
  • Dupont wire
Test Code​
The following code uses the python-periphery library to test SPI loopback communication.
spi_example.py
from periphery import SPI
def spi_communication_test():
# Data to be transmitted (4 bytes)
transmit_data = [0xAA, 0xBB, 0xCC, 0xDD]
try:
# Initialize SPI resource
# Parameters: SPI device path, mode 0, 1MHz clock frequency
spi = SPI("/dev/spidev1.0", 0, 1000000)
# Transmit data and receive response simultaneously
# SPI is full-duplex, so data is sent and received at the same time
received_data = spi.transfer(transmit_data)
# Print test results
print("SPI Test:")
print(" Transmitted data: [0x{:02x}, 0x{:02x}, 0x{:02x}, 0x{:02x}]".format(*transmit_data))
print(" Received data: [0x{:02x}, 0x{:02x}, 0x{:02x}, 0x{:02x}]".format(*received_data))
print(f"SPI Test failed: {e}")
finally:
# Ensure SPI resource is released
try:
spi.close()
except:
pass
print("Starting SPI Communication Test...\n")
print("\nSPI Test completed")
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable spidev on SPI1 option, then restart the system
  2. Connect the PI4 pin and PI5 pin
  3. Save the code as spi_example.py
  4. Run the test code using sudo python3 spi_example.py
Terminal will output sent and received information, and you can judge whether the SPI loopback test is successful based on the terminal output information.
