Audio Management
This guide explains how to use audio devices on Radxa boards.
Audio Devices​
The default audio output priority is: Bluetooth Audio > Headphones > HDMI Audio.
After manually selecting an audio output device, that device will have the highest priority.
Audio Configuration​
You can configure audio devices through either the graphical interface or the command line.
Click the audio icon in the bottom-right corner of the desktop, select your desired audio output device, and adjust the volume by dragging the volume slider.
①. Click the audio icon
②. Select the audio output device
③. Adjust the volume by dragging the slider
