Wired Network
This guide explains how to connect to a wired network and test network bandwidth.
Wired Network​
Connect the board's Gigabit Ethernet port to a router using an Ethernet cable. Once connected, the router will automatically assign an IP address to the board.
Connect the board's Ethernet port to a router using an Ethernet cable. Once connected, the router will automatically assign an IP address to the board.
  1. Click the network icon
  2. Select the Details option to view network connection details such as IP address, subnet mask, gateway address, etc.
For example, 192.168.4.129 is the IP address assigned by the router.
Testing Network Bandwidth Performance​
Use the iperf tool to test network bandwidth (throughput) performance. It is recommended to run multiple tests and take the average.
  • Hardware Requirements
You will need two devices: one to act as the server and the other as the client.
Server: Can be a PC, server, or similar device.
Client: The device to be tested, such as a Cubie A7A.
  • Same Local Network
The server and client must be on the same local network and able to ping each other.
Installing iperf​
Both the server and client need to have iperf installed.
radxa@device & Linux@host$
sudo apt install iperf
Testing Steps​
Server (PC)​
Open a terminal and enter the following command to start the server:
Linux@host$
iperf -s
After successful startup, the terminal will display output similar to the following:
Client (Board)​
  1. Upload Test
Open a terminal and enter the following command to test the client's upload bandwidth. Replace <server_ip> with the actual server IP address (you can check it using the ip a command).
radxa@cubie-a5e$
# Example
iperf -c 192.168.2.104 -t 60
Parameter explanation:
  • <server_ip>: Server IP address.
  • <time>: Test duration in seconds.
  1. Download Test
Open a terminal and enter the following command to test the client's download bandwidth. Replace <server_ip> with the actual server IP address (you can check it using the ip a command).
radxa@cubie-a5e$
# Example
iperf -c 192.168.2.104 -t 60 -R
  • -R: Reverse test, where the client acts as the server and the server acts as the client.
