MobileNetV1
This document describes how to run MobileNetV1 on NPU.
info
Refer to Model Zoo Download for the example.
MobileNetV1 Example Directory Structure:
$ tree ./
├── class_post.cpp
├── class_pre.cpp
├── CMakeLists.txt
├── convert_model
│ ├── config_yml.py
│ ├── convert_model_env.sh
│ └── inputs_outputs.txt
├── label.h
├── main.cpp
├── model
└── README.md
Model Conversion
Download Model
Click to download mobilenet_v1_1.0_224_frozen.pb.
Then move the model to the convert_model/ directory.
X86 Linux PC
cd convert_model/
./convert_model_env.sh
Model Import/Quantization/Conversion
You need to enter the container development environment first. Refer to the Create Container section in Model Zoo Download.
info
Different platforms use corresponding Docker images:
  • A733: ubuntu-npu:v2.0.10.2
  • T527: ubuntu-npu:v1.8.13
X86 Linux PC
After entering the container, navigate to the corresponding directory and run the script.
X86 Linux PC
cd /workspace/examples/mobilenetv1_tensorflow/convert_model/
X86 Linux PC
./pegasus_import.sh mobilenet_v1_1.0_224_frozen
./pegasus_quantize.sh mobilenet_v1_1.0_224_frozen uint8 10
X86 Linux PC
./pegasus_export_ovx_nbg.sh mobilenet_v1_1.0_224_frozen uint8 a733
The exported model files are stored in the ../model directory.
Compile Example
Now you can compile the example. First exit the container, then execute the following command to compile the example.
First, you need to configure third-party libraries and cross-compilation toolchain.
info
You can skip this step if you have already configured third-party libraries and cross-compilation toolchain in other examples.
X86 Linux PC
cd ../../../3rdparty/opencv/
cd ../../0-toolchains/
You need to manually download via this link first, then place it in 0-toolchains/ before executing the following command:
X86 Linux PC
X86 Linux PC
cd ../examples/mobilenetv1_tensorflow/
X86 Linux PC
Model Deployment
After compilation, the example will be installed in the install directory. You can use scp to transfer it to the board.
Configure NPU Driver
info
You can skip this step if you have already configured NPU driver in other examples.
Transfer the driver library to the board's lib directory via scp.
  • A733 corresponds to the common/lib_linux_aarch64/A733 directory
  • T527 corresponds to the common/lib_linux_aarch64/T527 directory
Then execute the following command to export to environment variables.
Radxa SBC
Run Example
After configuring the driver, you can run the example.
For T527 platform, you need to first enable NPU by referring to the A5E's "Enable NPU on Board" documentation, then use the following command to grant the current user permission to use /dev/vipcore.
Radxa SBC
sudo chmod 777 /dev/vipcore
Radxa SBC
cd mobilenetv1_demo_linux_a733/
Radxa SBC
chmod +x ./mobilenetv1_demo_a733
./mobilenetv1_demo_a733 -nb model/mobilenet_v1_1.0_224_frozen_uint8_a733.nb -i model/space_shuttle_224x224.jpg
The running result is as follows:
$ ./mobilenetv1_demo_a733 -nb model/mobilenet_v1_1.0_224_frozen_uint8_a733.nb -i model/space_shuttle_224x224.jpg
model_file=model/mobilenet_v1_1.0_224_frozen_uint8_a733.nb, input=model/space_shuttle_224x224.jpg, loop_count=1, malloc_mbyte=10
input 0 dim 3 224 224 1, data_format=2, quant_format=0, name=input/output[0], none-quant
output 0 dim 1001 1 0 0, data_format=0, name=uid_20000_sub_uid_1_out_0, none-quant
nbg name=model/mobilenet_v1_1.0_224_frozen_uint8_a733.nb, size: 3182272.
create network 0: 5661 us.
prepare network: 1085 us.
network: 0, loop count: 1
run time for this network 0: 1845 us.
class_postprocess.cpp run.
========== top5 ==========
class id: 813, prob: 0.993652, label: space shuttle
class id: 868, prob: 0.001479, label: trailer truck, tractor trailer, trucking rig, rig, articulated lorry, semi
class id: 405, prob: 0.000976, label: airliner
class id: 406, prob: 0.000561, label: airship, dirigible
class id: 628, prob: 0.000370, label: limousine, limo
destroy npu finished.
~NpuUint.
This performance data only calculates the time consumption of model inference. Unless otherwise specified, it does not include the time consumption of pre-processing and post-processing.
SoCNPUModelInput ResolutionNetwork Creation TimeNetwork Preparation TimeSingle Frame Inference TimePost-processing TimeTotal TimeFrame Rate
Allwinner A733Vivante VIP9000mobilenetv1224×2245.7 ms1.1 ms1.8 ms8.6 ms555.6 FPS
