ROS1 Example (Turtlesim)
Experience the basic concepts and functionalities of ROS1 quickly using the Turtlesim example.
This tutorial is based on the ROS1 Noetic Docker image but is not limited to the Docker environment. It can be performed in any ROS1 environment.
If you are using a Docker environment, it is recommended to first learn how to use Docker.
Start the Docker Script
Use the following command to start the Docker script: ros_noetic.sh
is a script created during the ROS1 environment setup.
bash ros_noetic.sh
It is recommended to use multiple terminals to access the same Docker container for easier subsequent operations.
Start the Master Node
ROS1 requires starting the Master node before launching the Turtlesim node.
roscore
Start Turtlesim
Use the following command to start Turtlesim:
rosrun turtlesim turtlesim_node
This command will create the /turtlesim
node and display a window containing a turtle.
Control Turtlesim
Use the following command to control the turtle's movement:
rosrun turtlesim turtle_teleop_key
This command will create the /teleop_turtle
node.
Click and focus on the terminal window running this command. You can control the turtle's movement using the arrow keys on your keyboard.
ROS1 Basic Concepts
Through the Turtlesim example, you can further understand and use the basic concepts and commands of ROS1.
To stop a running ROS1 command, use the Ctrl + C
keyboard shortcut.
ROS1 Nodes
Nodes are the basic communication units in ROS1. They interact with other nodes through publishers and subscribers.
Key Components:
- Publisher: Interface for publishing messages to a topic.
- Subscriber: Interface for receiving messages from a topic.
View Nodes
Use the rosnode list
command to view nodes. Currently, only the command to start Turtlesim is running.
rosnode list
ROS1 Topics
Topics are the publish/subscribe communication mechanism in ROS1, enabling asynchronous data transfer between nodes.
Communication Roles:
- Publisher: Sends messages to a specific topic.
- Subscriber: Subscribes to a topic to receive messages.
View Topics
Use the rostopic list
command to view topics:
rostopic list
Publish a Topic
Use the rostopic pub
command to publish a velocity control message to move the turtle:
rostopic pub -r 10 /turtle1/cmd_vel geometry_msgs/Twist "{linear: {x: 0.5, y: 0.0, z: 0.0}, angular: {x: 0.0, y: 0.0, z: 0.5}}"
This command will move the turtle at a linear velocity of 0.5 and an angular velocity of 0.5 at a frequency of 10 Hz.
Subscribe to a Topic
Use the rostopic echo
command to subscribe to a topic and view its messages:
rostopic echo -n 1 /turtle1/pose
This command will print the turtle's position once in the terminal.
ROS1 Services
Services are the request/response communication mechanism in ROS1, used for synchronous calls between nodes (e.g., remote function calls).
Interaction Flow:
- Client: Sends a request.
- Server: Processes the request and returns a response.
View Services
Use the rosservice list
command to view services:
rosservice list
Call a Service
Use the rosservice call
command to call a service and clear the screen:
rosservice call /clear
This command will clear the background in the Turtlesim window.
