Using Radxa eMMC/UFS Combo Module Reader
This guide explains how to use the Radxa eMMC/UFS combo module reader to install the system onto an eMMC module.
warning
Installing the system will format the eMMC module. Please back up any important data in advance!
Hardware Requirements​
Prepare the following hardware in advance:
  • Boot media: eMMC module
  • Card reader: eMMC/UFS combo module reader
Hardware Connection​
Install the eMMC module into the reader, then connect the reader to a USB port on your PC.
caution
eMMC Module Installation Steps:​
  1. Ensure the notch on the eMMC module aligns with the notch on the reader
  2. Align the bottom edge connector of the eMMC module with the reader's interface
  3. Gently press down on one end of the eMMC module until you hear a "click" sound, then repeat the process for the other end to ensure the module is properly seated.
eMMC module installation with reader
Software Preparation​
Use the open-source image flashing tool Etcher to write the system image to the eMMC module.
Download System Image​
Go to the Downloads page to download and extract the system image file to your PC.
Download Etcher​
Download the appropriate version of Balena Etcher for your operating system from the official website: balenaEtcher.
Balena Etcher download page
Download the software package that matches your system platform and architecture.
Etcher download options
Using Etcher​
After downloading, double-click to open the Etcher application.
  • Windows
    • The downloaded file will be an *.exe installer. Double-click to run the program.
  • Linux
    • It's recommended to download the *.zip archive. After extraction, double-click the program to run it.
  • macOS
    • Download the appropriate *.dmg file for your system architecture. After opening, drag the application to your Applications folder to install. Then double-click the app icon to run it.
Etcher installation instructions
Installing the System Image​
  1. Select the system image
    • Click the Flash from file button
    • Choose the downloaded and extracted system image file
Selecting system image in Etcher
  1. Select the target device
    • Click the Select target button
    • Choose the disk device corresponding to your connected card reader
danger
Be extremely careful to select the correct disk! Etcher will format the selected disk, which could result in permanent data loss if you choose the wrong one!
Selecting target disk in Etcher
① Select the disk device where you want to install the system image
② Click Select 1 to confirm your device selection
Confirming disk selection in Etcher
  1. Write the system image
    • Click the Flash! button
    • Wait for the software to write and verify the system image
Starting the flash process in Etcher
Writing system image...
Writing system image progress
Verifying system image...
Verification in progress
  1. After successfully writing the system image, close the Etcher application.
System Information​
When using our provided system image for the first time, you'll need to log in with the following default credentials:
  • Username: radxa
  • Password: radxa
