40 Pin GPIO Interface
Radxa Cubie A7A features an onboard 40-Pin GPIO (General Purpose Input/Output) interface, providing highly flexible support for hardware expansion.
Users can connect various sensors, actuators, communication modules, displays, and other embedded peripherals to the 40-Pin GPIO interface, enabling rapid prototyping and functional verification for IoT, robotics control, industrial automation, and other fields.
danger
When using the 40-Pin GPIO interface, please pay attention to the wiring of the pins and peripherals. Make sure the pin connections are correct, as improper operation may cause hardware damage to the device.
GPIO Functions​
Cubie A7A supports connecting external devices to the onboard GPIO pins, supporting UART, SPI, I2C, ADC, and more.
FUNC9FUNC8FUNC7FUNC6FUNC5FUNC4FUNC3FUNC2FUNC1Pin#Pin#FUNC1FUNC2FUNC3FUNC4FUNC5FUNC6FUNC7FUNC8FUNC9
+3.3V
1
2
+5.0V
PJ-EINT23TWI11-SDATWI3-SDATWI7-SDAUART2-CTSUART3-RXPWM1-5PJ23
3
4
+5.0V
PJ-EINT22TWI11-SCKTWI3-SCKTWI7-SCKUART2-RTSUART3-TXPWM1-4PJ22
5
6
GND
PB-EINT0JTAG-MSSPI2-CS0UART0-TXUART2-TXPB0
7
8
PB9UART0-TXI2S0-DIN2I2S0-DOUBT2PWM1-1WATCHDOG-SIGTWI8-SCKTWI0-SCKPB-EINT9
GND
9
10
PB10UART0-RXI2S0-DIN3I2S0-DOUBT3PWM1-2PLL-LOCK-DBGTWI8-SDATWI0-SDAPB-EINT10
PB-EINT1JTAG-CKSPI2-CLKUART0-RXUART2-RXPB1
11
12
PK0MCSIA-D0NUART6-DCDI2S4-BCLKHDMI-CECTWI1-SDANCSI1-HSYNCSGPIO-SLOADPK-EINT0
PL-EINT6S-PWM0-4S-IR-RXS-SPI0-MOSIS-UART0-TXS-JTAG-DOPL6
13
14
GND
PL-EINT7S-PWM0-5S-SPI0-MISOS-UART0-RXS-JTAG-DIPL7
15
16
PJ24PWM1-6UART4-TXTWI4-SCKSPI3-CLKPJ-EINT24
+3.3V
17
18
PJ25PWM1-7UART4-RXTWI4-SDASPI3-MOSIPJ-EINT25
PD-EINT12PWM1-2SPI1-MOSIEINK-D12DSI1-D1PLVDS1-D1PPD12
19
20
GND
PD-EINT13PWM1-3SPI1-MISOEINK-D13DSI1-D1NLVDS1-D1NPD13
21
22
PL10S-UART0-TXS-TWI2-SCKS-UART1-TXS-PWM0-8PL-EINT10
PD-EINT11PWM1-1SPI1-CLKEINK-D11DSI1-D0NLVDS1-D0NPD11
23
24
PD10LVDS1-D0PDSI1-D0PEINK-D10SPI1-CS0PWM1-0PD-EINT10
GND
25
26
PD14LVDS1-D2PDSI1-CKPEINK-D14SPI1-HOLDUART3-RTSPD-EINT14
PD-EINT1UART3-RXTWI2-SDAEINK-LEHDSI1-D2NLVDS1-CKNPD17
27
28
PD16LVDS1-CKPDSI1-D2PEINK-OEHTWI2-SCKUART3-TXPD-EINT16
PK-EINT5JTAG-MAS-CKNCSI1-D14SPI3-CLKPWM1-9PWM1-8PCIE-CLKREQNMCSIA-CKPPK5
29
30
GND
PK-EINT6JTAG-MAS-DONCSI1-D13SPI3-MOSIUART2-RTSUART4-TXTWI2-SCKMCSIA-D2NPK6
31
32
PD20TWI0-SCKEINK-CKVPCIE-CLKREQNUART4-TXTWI3-SCKPWM0-2
PK-EINT7JTAG-MAS-DINCSI1-D12SPI3-MISOUART2-CTSUART4-RXTWI2-SDAMCSIA-D2PPK7
33
34
GND
PK-EINT2SGPIO-SDATAINNCSI1-PCLKTWI5-SDAHDMI-SDAI2S4-LRCKUART6-DTRMCSIA-D1NPK2
35
36
PK1MCSIA-D0PUART6-DSRI2S4-MCLKHDMI-SCLTWI1-SCKNCSI1-VSYNCSGPIO-SCLKPK-EINT1
PK-EINT8JTAG-MAS-NTRSTNCSI1-D11SPI3-CS1UART2-TXUART4-RTSMCSI0-MCLKMCSIA-D3NPK8
37
38
PK3MCSIA-D1PUART6-RII2S4-DIN0I2S4-DOUBT1TWI5-SCKNCSI1-MCLKSGPIO-SDATAOUTPK-EINT3
GND
39
40
PK4MCSIA-CKNPCIE-WAKENI2S4-DOUBT0I2S4-DIN1SPI3-CS0NCSI1-D15JTAG-MAS-MSPK-EINT4
GPIO Pin Numbering​
To control a specific pin, you need to calculate the pin number using the following formula:
GPIO ChipPin RangeCalculation Formula
GPIOCHIP0A ~ KNUM + 32 * (A ~ K)
GPIOCHIP1L ~NUM + 32 * (L ~ )
Calculation Example:
  • PB10
GPIOCHIP0 -> 10 + 32 * (A ~ K) -> 10 + 32 * 1 -> 42
  • PK4
GPIOCHIP1 -> 4 + 32 * (A ~ K) -> 4 + 32 * 10 -> 324
GPIO Usage​
Through the 40-Pin GPIO interface, demonstrate common GPIO usage.
Install python-periphery​
Use the python-periphery library to control GPIO pins.
radxa@cubie-a7a$
sudo pip3 install python-periphery
GPIO Input​
Hardware Preparation​
  • Board
  • Dupont wire
Software Preparation​
The following code is used to read the high and low level of the PK4 pin using the python-periphery library.
gpio_input.py
from periphery import GPIO
import time
def read_gpio_input():
# Configure GPIO input (modify pin number according to actual hardware)
# Using pin 324 of /dev/gpiochip0 here (corresponds to PK4)
try:
# Initialize GPIO in input mode
gpio_in = GPIO("/dev/gpiochip0", 324, "in")
print("Starting GPIO input reading (press Ctrl+C to exit)")
while True:
# Read pin value
value = gpio_in.read()
print(f"GPIO input value: {value} (True=High, False=Low)")
time.sleep(1) # Read once per second
except KeyboardInterrupt:
print("\nProgram exited")
except Exception as e:
print(f"Error occurred: {e}")
finally:
# Ensure resources are released
try:
gpio_in.close()
except:
pass
if __name__ == "__main__":
read_gpio_input()
Test Steps​
  1. Connect the PK4 pin to the GND or 3.3V pin
  2. Save the code as gpio_input.py
  3. Run the test code using python3 gpio_input.py
Experimental Phenomenon​
The terminal will output False or True information.
False represents a low level, True represents a high level.
GPIO Output​
  • Board
  • Dupont wire
Test Code​
The following code is used to control the PK3 pin to output high and low levels, and then read the high and low levels of the PK3 pin through the PK4 pin.
gpio_output.py
import time
# PK3 (output) → maps to pin 323 of /dev/gpiochip0
# PK4 (input) → maps to pin 324 of /dev/gpiochip0
OUTPUT_PIN_CHIP = "/dev/gpiochip0"
OUTPUT_PIN_NUMBER = 323 # PK3 (output pin, controlled by the script)
INPUT_PIN_NUMBER = 324 # PK4 (input pin, reads PK3's output state)
gpio_out = None
gpio_in = None
try:
# Initialize PK3 as OUTPUT mode
# Initialize PK4 as INPUT mode
print(f"Controlled Pin (PK3): {OUTPUT_PIN_CHIP} - Pin {OUTPUT_PIN_NUMBER} (OUTPUT)")
print(f"Monitoring Pin (PK4): {OUTPUT_PIN_CHIP} - Pin {INPUT_PIN_NUMBER} (INPUT)")
print("Test Behavior: PK3 toggles HIGH/LOW every 1s; PK4 verifies PK3's state")
# Main loop: Toggle PK3 and read PK4 feedback
while True:
# 1. Set PK3 to HIGH level
gpio_out.write(True)
pk4_reading = gpio_in.read()
print(f"PK3 Output: HIGH (True) | PK4 Reading: {pk4_reading}")
# Keep PK3 HIGH for 1 second
time.sleep(1)
# 2. Set PK3 to LOW level
gpio_out.write(False)
print(f"PK3 Output: LOW (False) | PK4 Reading: {pk4_reading}")
# Keep PK3 LOW for 1 second
time.sleep(1)
finally:
# Safely close PK3 (set to LOW first to avoid residual high level)
if gpio_out:
try:
gpio_out.close()
print(f"Successfully closed PK3 (Pin {OUTPUT_PIN_NUMBER})")
print(f"Failed to close PK3 (Pin {OUTPUT_PIN_NUMBER}): {str(close_err)}")
# Safely close PK4
if gpio_in:
try:
gpio_in.close()
print(f"Successfully closed PK4 (Pin {INPUT_PIN_NUMBER})")
print(f"Failed to close PK4 (Pin {INPUT_PIN_NUMBER}): {str(close_err)}")
Test Steps​
  1. Short the PK3 pin and PK4 pin
  2. Save the code as gpio_output.py
  3. Run the test code using sudo python3 gpio_output.py
PWM Output​
  • Board
  • LED
  • Dupont wire
Test Code​
The following code is used to test PWM output using the python-periphery library.
pwm_output.py
from periphery import PWM
import time
def pwm_test():
try:
# Configure PWM parameters - modify according to your hardware
# Common PWM paths: /sys/class/pwm/pwmchip0/pwm0, etc.
PWM_CHIP = 10 # PWM chip number
PWM_CHANNEL = 2 # PWM channel number
# Initialize PWM
pwm = PWM(PWM_CHIP, PWM_CHANNEL)
print(f"PWM Test: Using PWM{PWM_CHIP}.{PWM_CHANNEL} (Pin: PD12)")
# Set PWM frequency to 1kHz
frequency = 1000 # 1000 Hz
pwm.frequency = frequency
print(f" Set frequency: {frequency} Hz")
# Enable PWM output
pwm.enable()
print(" PWM enabled")
# Test different duty cycles (0% to 100%)
duty_cycles = [0.0, 0.25, 0.5, 0.75, 1.0]
for duty in duty_cycles:
pwm.duty_cycle = duty
print(f" Set duty cycle: {duty*100:.1f}%")
time.sleep(1) # Maintain current duty cycle for 1 second
# Cleanup
pwm.disable()
pwm.close()
print(" PWM disabled and closed")
print("PWM Test completed successfully")
print(f"PWM Test failed: {e}")
print("Starting PWM Signal Test...\n")
pwm_test()
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable PWM1-2 option, then restart the system
  2. Connect the positive terminal of the LED to the PD12 pin
  3. Connect the negative terminal of the LED to the GND pin
  4. Save the code as pwm_output.py
  5. Run the test code using sudo python3 pwm_output.py
The connected LED will flash with different brightness, from bright to dark.
UART Usage​
UART(Universal Asynchronous Receiver/Transmitter) is a widely used serial communication protocol, used for asynchronous serial data transmission between embedded systems, computers, and peripherals.
  • Board
  • Dupont wire
Test Code​
The following code is used to test UART4 loopback communication using the python-periphery library.
uart_example.py
from periphery import Serial
import time
def uart_test():
try:
# Modify the serial device path according to your hardware, common paths include /dev/ttyS0, /dev/ttyS1, /dev/ttyUSB0, etc.
# PJ24(TX) PJ25(RX)
UART_DEVICE = "/dev/ttyAS4"
BAUDRATE = 115200
# Initialize serial port
serial = Serial(UART_DEVICE, BAUDRATE)
print(f"UART Test: Opening serial port {UART_DEVICE}, baud rate {BAUDRATE}")
# Send test data
test_message = "Hello, UART Test!\n"
serial.write(test_message.encode())
print(f" Sent data: {test_message.strip()}")
# Wait for data transmission
time.sleep(0.1)
# Try to read data (if loopback or other device responds)
if serial.input_waiting() > 0:
received_data = serial.read(serial.input_waiting())
print(f" Received data: {received_data.decode().strip()}")
else:
print(" No data received (normal unless loopback is connected)")
serial.close()
print("UART test completed")
print(f"UART test failed: {e}")
uart_test()
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable UART4 option, then restart the system
  2. Short the PJ24 pin and PJ25 pin
  3. Save the code as uart_example.py
  4. Run the test code using sudo python3 uart_example.py
The terminal will output the sent and received information, and you can judge whether the UART loopback test is successful based on the terminal output information.
I2C Usage​
I2C is a widely used synchronous serial communication protocol developed by Philips (now NXP), mainly used for short-distance chip-to-chip communication.
  • Board
  • I2C device (e.g., OLED display, its corresponding I2C address is 0x3C)
  • Dupont wire
Test Code​
The following code is used to test I2C communication using the python-periphery library.
i2c_example.py
from periphery import I2C
def i2c_device_detection():
"""I2C Test - Check if device exists
Pin reference: PJ23 (SDA), PJ22 (SCL)
# Modify according to your hardware connection
# Common I2C bus devices: /dev/i2c-0, etc.
I2C_BUS = "/dev/i2c-7"
TARGET_ADDR = 0x3C # Target address to check
i2c = None # Initialize I2C object reference
try:
i2c = I2C(I2C_BUS)
# Attempt a simple read/write operation to detect device
# Sending a single 0x00 byte as test communication
msgs = [I2C.Message([0x00])]
i2c.transfer(TARGET_ADDR, msgs)
print(f"I2C Test: Device found at address 0x{TARGET_ADDR:02X}")
return True
# Exception (e.g., IOError) usually indicates no device or no response
print(f"I2C Test: No device or no response at address 0x{TARGET_ADDR:02X}: {e}")
return False
finally:
# Ensure I2C resources are released
if i2c is not None:
try:
i2c.close()
except:
pass
print("Starting I2C Device Detection...")
print("I2C Test completed")
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable TWI7 option, then restart the system
  2. Connect the SCL pin of the OLED display to the PJ22 pin, connect the SDA pin of the OLED display to the PJ23 pin, connect the VCC to 5V, and connect the GND to GND
  3. Save the code as i2c_example.py
  4. Run the test code using sudo python3 i2c_example.py
The script function is to check if a specific I2C device exists on the specified I2C bus, and can determine if the I2C device is working normally.
SPI Usage​
SPI (Serial Peripheral Interface) is a high-speed, full-duplex, synchronous serial communication protocol developed by Motorola (now NXP), mainly used for short-distance chip-to-chip communication, commonly used in data transmission between sensors, storage devices (such as Flash), and displays.
  • Board
  • Dupont wire
Test Code​
The following code is used to test SPI loopback communication using the python-periphery library.
spi_example.py
from periphery import SPI
def spi_communication_test():
# Data to be transmitted (4 bytes)
transmit_data = [0xAA, 0xBB, 0xCC, 0xDD]
try:
# Initialize SPI resource
# Parameters: SPI device path, mode 0, 1MHz clock frequency
spi = SPI("/dev/spidev3.0", 0, 1000000)
# Transmit data and receive response simultaneously
# SPI is full-duplex, so data is sent and received at the same time
received_data = spi.transfer(transmit_data)
# Print test results
print("SPI Test:")
print(" Transmitted data: [0x{:02x}, 0x{:02x}, 0x{:02x}, 0x{:02x}]".format(*transmit_data))
print(" Received data: [0x{:02x}, 0x{:02x}, 0x{:02x}, 0x{:02x}]".format(*received_data))
print(f"SPI Test failed: {e}")
finally:
# Ensure SPI resource is released
try:
spi.close()
except:
pass
print("Starting SPI Communication Test...\n")
print("\nSPI Test completed")
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable spidev on SPI3 option, then restart the system
  2. Connect the PK6 pin and PK7 pin
  3. Save the code as spi_example.py
  4. Run the test code using sudo python3 spi_example.py
The terminal will output the sent and received information, and you can judge whether the SPI loopback test is successful based on the terminal output information.
