USB Type-C Port
Overview​
The USB Type-C port on Radxa Cubie A7A provides the following features:
  • Power Supply: Supports 5V power input
  • Data Transfer: Supports USB OTG (USB0 port)
  • System Flashing: Supports USB flashing functionality
Port Location
For the exact location of the USB Type-C port, please refer to the interface description section in the Hardware Interfaces document.
Power Requirements​
  • Flashing Mode: The board can be powered directly via the USB Type-C port from a PC for flashing operations.
  • Normal Use: It is recommended to use a USB adapter with an output current of 3A or above to ensure stable operation of all peripherals.
Recommended Power Accessories
Usage Guide​
  1. Connect the power adapter to the USB Type-C port of the Cubie A7A.
  2. Observe the onboard indicator light status:
    • Power On Successfully: The power indicator lights up green.
    • Power Issue: The indicator does not light up or blinks abnormally.
Port Specifications​
Technical Reference
For complete technical specifications and pin definitions, please refer to the Hardware Design: Schematic document in the
