Install OpenCV
OpenCV (Open Source Computer Vision Library) is an open-source computer vision and machine learning software library.
OpenCV Features​
  • High Performance
    Optimized with C++ under the hood, it provides interfaces for Python, Java, and other languages, balancing speed and usability. Supports GPU acceleration (CUDA, OpenCL).
  • Cross-Platform
    Supports Windows, Linux, macOS, Android, and iOS, and can run on various hardware architectures including x86 and ARM.
  • Multi-language Support
    Offers interfaces for C++, Python, Java, and more, catering to different development needs. Compatible with deep learning frameworks like TensorFlow and PyTorch.
  • Rich Functionality
    OpenCV provides a wide range of computer vision algorithms, including image processing, feature detection, object detection, and machine learning.
Installing OpenCV​
This guide covers two different methods to install OpenCV: binary installation and source code compilation. Choose the one that best suits your needs.
Installation MethodAdvantagesDisadvantagesBest For
Binary Installation- Quick and easy installation
- No need to compile from source
- Easy to maintain and upgrade
- May lack some features
- Less customizable
Beginners, daily development, Python users
Source Installation- Customizable compilation parameters and modules
- Access to latest/specific versions
- Supports multiple languages
- Complex process
- Requires build environment
- Time-consuming compilation
Advanced users, C++ developers, special requirements
Binary Installation​
You can install the Python version of OpenCV using pip, or the C++ version using apt.
pip3 install opencv-python opencv-contrib-python
  • Verify OpenCV Installation
python3
Once in the Python interactive mode, enter the following commands to verify OpenCV installation:
import cv2
print(cv2.__version__)
If the OpenCV version number is displayed, the installation was successful.
Source Installation​
This method involves compiling OpenCV from source.
Install Build Dependencies​
sudo apt install cmake gcc g++ python3-dev python3-numpy libavcodec-dev libavformat-dev libswscale-dev libgstreamer-plugins-base1.0-dev libgstreamer1.0-dev libgtk-3-dev -y
Install Optional Dependencies​
sudo apt install libpng-dev libjpeg-dev libopenexr-dev libtiff-dev libwebp-dev -y
Download OpenCV Source Code​
Use git to download the OpenCV source code.
sudo apt install git -y
git clone https://github.com/opencv/opencv.git
Compile OpenCV​
Navigate to the OpenCV source directory and run the following commands to compile OpenCV:
cd opencv
mkdir build
cd build
cmake ../
make -j4
sudo make install
Verify OpenCV Installation​
python3
import cv2
